Home » Language IDEs » ServerTools (WTP) » New to JSP +
New to JSP + [message #223930] Tue, 18 November 2008 11:12 Go to next message
I have a website already, it uses Tomcat, and I want to add some .jsp to
facilitate some simple dynamic content.
The production server does/will not have a JDK on it.
On my PC, I can run a sample .jsp, but the generated .java and .class are
placed in Tomcat's "work" directory.
I need to provide a .jar or .class file(s) to the production server so
that the .jsp will work.
I've learned about editing the web.xml file, but still no joy.
Now I'm trying to use Eclipse to create the .jsp and run the page, but no
joy there either. I know I'm probably missing a lot some where, but I'd
rather not spend months studying to figure out what I'm doing wrong.
From within Eclipse I can successfully run my index.html page which
creates three frames, and the title and footer seconds properly display
their .html content. Just the middle.jsp doesn't fly, and it currently as
simple "Hello World" thing.
I'm having some difficulty finding the right place for help.
Help?
Re: New to JSP + [message #223949 is a reply to message #223930] Tue, 18 November 2008 14:27 Go to previous messageGo to next message
If you're going to use JSPs Tomcat requires a JDK as your JSPs need to be
compiled into Java classes (specifically, servlets). Alternatively, you
can precompile your JSPs using Tomcat's JSPC [1].
[1] http://tomcat.apache.org/tomcat-5.5-doc/jasper-howto.html#We b
Application Compilation
Lawrence
Re: New to JSP + [message #223956 is a reply to message #223930] Tue, 18 November 2008 14:41 Go to previous messageGo to next message
I don't know what I did, but the .jsp page is now displaying properly.
But, I cannot seem to find the .class and .java files associated with it.
That is, the generated servlet app.
I set the output path, but nothing is showing up there, and I'm not
finding anything under the Tomcat webapps nor work directories.
Re: New to JSP + [message #223962 is a reply to message #223949] Tue, 18 November 2008 14:46 Go to previous messageGo to next message
Yes, I found that out last week. That is why I downloaded JDK, ANT,
Tomcat and Eclipse to my workstation specifically to create the .java and
class files.
When I ran the webpage on Tomcat directly, it created the .java and .class
files in the Tomcat work directory, and everything seemed to function.
But, I would prefer to put the .class file in WEB-INF/classes or a .jar
file in WEB-INF/lib. I tried a simple manual method and it wasn't
working. So I assumed I was missing important pieces. So, I thought if I
created/ran the same thing within Eclipse, it would generate what I needed
and would build a complete .jar file for me. That doesn't seem to be
happening.
Re: New to JSP + [message #223969 is a reply to message #223949] Tue, 18 November 2008 15:32 Go to previous messageGo to next message
Actually, Tomcat 5.5 and later include a copy of Eclipse's JDT compiler
and thus by default don't use the JDK's tools.jar. A JRE is sufficient
for these Tomcat versions.
Alternatively, you
Since the JSPC Ant script uses the javac task, a JDK would be required
for the script to run.
Larry
> Lawrence
Re: New to JSP + [message #223985 is a reply to message #223930] Tue, 18 November 2008 15:52 Go to previous messageGo to next message
Well, I've got an ugly work around for now.
1) create the .jsp page and let Tomcat create the servlet.
2) create a normal java project
3) create a new class in the java project
4) paste the .java contents created by Tomcat into the new class file.
5) remove (or update) the generated package statement.
6) Save the class file, which causes an automatic build.
7) Copy the new class file to WEB-INF/classes.
8) make the appropriate <servlet> and <servlet-mapping> entries in web.xml
For play_middle.jsp, the generated .java and .class files are
play_middle_jsp
The web.xml servlet entries are then
<servlet>
<servlet-name>play_middle_jsp</servlet-name>
<servlet-class>play_middle_jsp</servlet-class>
</servlet>
<servlet-mapping>
<url-pattern>/Web/IT_Techs/play_middle.jsp</url-pattern>
</servlet-mapping>
The page that src's play_middle.jsp is in the /Web/IT_Techs subdirectory
below the context root.
Eventually, I expect I'll figure out how to make more efficient use of
Eclipse for this.
Re: New to JSP + [message #223991 is a reply to message #223969] Tue, 18 November 2008 15:59 Go to previous messageGo to next message
Thanks.
Right now I'm stuck with 4.1 as the "production" server is using 4.0?
Once I get the have-to's done, I hope to learn how to have two flavors of
Tomcat on my box -- 4.1 and 6.x -- and then be able to work on qualifying
an application to work on 6.x.
Also, as noted in a different post, after the have-to's I'll figure out
how I can properly use Eclipse for a complete Tomcat based website
development platform. My workaround for now is rather ugly.
I will always be open for suggestions as I move along.
Re: New to JSP + [message #223999 is a reply to message #223969] Tue, 18 November 2008 16:08 Go to previous messageGo to next message
Thanks.
Right now I'm stuck with 4.1 as the "production" box is using 4.0x
Once I get the have-to's done, I'm hoping I can learn/figure out how to
have 2 flavors of Tomcat running -- 4.1 and 6.x -- so that I can work on
qualifying than an app will work with/on 6.x
Also after the have-to's, I hope to be able to spend the time learning how
to use Eclipse properly for dynamic web development and J2EE work. All of
my previous Java work on Eclipse have been for stand alone purely Java
applications -- like a Sudoku solver I created in 2006 (it doesn't solve
all of them, but it does most of them).
As I keep moving along, I'll always be open for suggestions.
Re: New to JSP + [message #224007 is a reply to message #223985] Tue, 18 November 2008 16:47 Go to previous messageGo to next message
Well, crud.
The "production" environment is Tomcat 4.0.3 using jre 1.4.2.
My dev environment is 4.1 and 1.5.0_07.
The resulting servlet major.minor level (49.0) is unsupported by the
"production" system. nuts.
guess I need to back up, if I can.
I don't find anything in text that set the version level.
Re: New to JSP + [message #224023 is a reply to message #224007] Tue, 18 November 2008 18:27 Go to previous messageGo to next message
Chuck Moore wrote:
> Well, crud.
It's in the Java Compiler property page for your project; check the
Project menu in the menu bar.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: New to JSP + [message #224031 is a reply to message #224023] Wed, 19 November 2008 08:03 Go to previous message
! Thanks !
All I needed to do was set the compliance level to 1.4, rebuild, copy the
class file to WEB-INF/classes, restart Tomcat, and waza! .jsp displays,
without an actual .jsp file, and nothing in "work".
Thanks for the help.
Now I can concentrate on producing that actual .jsp I really need to have
work.
Previous Topic:Extending Axis 2 Webservice Wizards
Next Topic:Can not install WTP 3.0.2, version problem
Current Time: Tue Sep 23 13:15:08 EDT 2025
Powered by FUDForum. Page generated in 0.04535 seconds
