Home » Eclipse Projects » Mylyn » Using Mylyn with sourceforge trackers
Re: Using Mylyn with sourceforge trackers [message #23864 is a reply to message #21757] |
Mon, 27 August 2007 05:38 |
Originally posted by: beatmik.acm.org
Erik,
If you haven't yet looked at the following entry you should do so:
http://wiki.eclipse.org/Using_Sourceforge_with_Mylyn
If you have already looked at that, first try to see if you can get it
to work with the template without modifying the template, then modify
the template adding your projects' parameters.
Mik
Erik Norvelle wrote:
> Greetings all,
> Has anyone successfully gotten Mylyn to work with Sourceforge trackers via the
> generic Web connecter? I have followed the FAQ available on Eclipsepedia, but
> was unable to even get the basic task query to work, much to be able to create
> new tasks on the sourceforge server.
> Any help appreciated... TKA!
> Erik Norvelle
> TextCite Project
> http://sourceforge.net/projects/textcite
Re: Using Mylyn with sourceforge trackers [message #69452 is a reply to message #23864] |
Mon, 15 June 2009 13:08 |
Andreas Goetz Messages: 110 Registered: July 2009 |
Hi Mik,
I've configured SF according to the Wiki but have the issue that only
the first bug is retrieved
group_id: 88349
atid: 586362
url:
${serverUrl}/tracker2/?group_id=${group_id}&atid=${atid} &set=custom&_status=1
pattern: <a
href=" /tracker/\?func=detail&aid=(.+?)&group_id=${group_id }&atid=${atid} ">(.+?)</a>
Doesn't seem to matter if tracker or tracker2. I'm suspecting this might
be an issue with the mylyn regexp?
I'm running Mylyn Connector: Web Templates (Advanced)
3.2.0.I20090614-2300-e3x org.eclipse.mylyn.web.tasks_feature.feature.group
Andreas
On 27.08.2007 07:38, Mik Kersten wrote:
> Erik,
> Mik
>> Greetings all,
>> via the generic Web connecter? I have followed the FAQ available on
>> Eclipsepedia, but was unable to even get the basic task query to work,
>> much to be able to create new tasks on the sourceforge server.
>> Erik Norvelle
>> TextCite Project
Re: Using Mylyn with sourceforge trackers [message #69470 is a reply to message #69452] |
Tue, 16 June 2009 15:46 |
Originally posted by: dcarver.starstandard.org
Actually, if I were you I would consider migrating to one of the other
Hosted App solutions that Sourceforge now offers. You can then use the
Trac, or Mylyn-Mantis connectors to connect.
Sourceforge is going to be removing the current Tracker feature soon
anyways.
Dave
Andreas Goetz wrote:
> Hi Mik,
> group_id: 88349
> atid: 586362
> url:
> pattern: <a
> Best regards,
> Andreas
>> Erik,
>> Mik
>>> Greetings all,
>>> Erik Norvelle
>>> TextCite Project
Re: Using Mylyn with sourceforge trackers [message #69687 is a reply to message #69470] |
Mon, 22 June 2009 09:37 |
Hi David,
as far as I know this is not an option for open source/ free of charge
services yet.
Anyway- I believe I'm seing a problem with the web based connector, or
rather cannot get it working with SF.
Any idea where I could poke into?
Andreas
> anyways.
> Dave
>> Hi Mik,
>> group_id: 88349
>> atid: 586362
>> url:
>> pattern: <a
>> might be an issue with the mylyn regexp?
>> Best regards,
>> Andreas
>>> Erik,
>>> Mik
>>>> Greetings all,
>>>> Erik Norvelle
>>>> TextCite Project
Re: Using Mylyn with sourceforge trackers [message #69707 is a reply to message #69687] |
Mon, 22 June 2009 22:36 |
Eugene Kuleshov Messages: 504 Registered: July 2009 |
Andreas,
The web connector is just a simple regexp-based screen scrapper, so it
is sensitive to the web page changes, but then regexps can be easily
adjusted to the new page. You can open "advanced settings" on query
configuration dialog and use Open action to see a downloaded web page in
a web browser where you can also see its source html and then adjust
regexp accordingly.
regards,
Eugene
> Hi David,
> services yet.
> Best regards,
> Andreas
>> anyways.
>> Dave
>>> Hi Mik,
>>> group_id: 88349
>>> atid: 586362
>>> url:
>>> pattern: <a
>>> Best regards,
>>> Andreas
>>>> Erik,
>>>> Mik
>>>>> Greetings all,
>>>>> trackers
>>>>> work,
>>>>> Erik Norvelle
>>>>> TextCite Project
Re: Using Mylyn with sourceforge trackers [message #597810 is a reply to message #23864] |
Hi Mik,
group_id: 88349
atid: 586362
url:
pattern: <a
Andreas
> Erik,
> Mik
>> Greetings all,
>> Erik Norvelle
>> TextCite Project
Re: Using Mylyn with sourceforge trackers [message #597818 is a reply to message #69452] |
anyways.
Dave
> Hi Mik,
> group_id: 88349
> atid: 586362
> url:
> pattern: <a
> Best regards,
> Andreas
>> Erik,
>> Mik
>>> Greetings all,
>>> Erik Norvelle
>>> TextCite Project
Re: Using Mylyn with sourceforge trackers [message #597877 is a reply to message #69470] |
Hi David,
services yet.
Andreas
> anyways.
> Dave
>> Hi Mik,
>> group_id: 88349
>> atid: 586362
>> url:
>> pattern: <a
>> Best regards,
>> Andreas
>>> Erik,
>>> Mik
>>>> Greetings all,
>>>> Erik Norvelle
>>>> TextCite Project
Re: Using Mylyn with sourceforge trackers [message #597883 is a reply to message #69687] |
Andreas,
regexp accordingly.
regards,
Eugene
> Hi David,
> services yet.
> Best regards,
> Andreas
>> anyways.
>> Dave
>>> Hi Mik,
>>> group_id: 88349
>>> atid: 586362
>>> url:
>>> pattern: <a
>>> Best regards,
>>> Andreas
>>>> Erik,
>>>> Mik
>>>>> Greetings all,
>>>>> trackers
>>>>> work,
>>>>> Erik Norvelle
>>>>> TextCite Project
Current Time: Sat Apr 27 04:55:05 GMT 2024
Powered by FUDForum. Page generated in 0.04054 seconds
