Re: Announcing IAM 0.10.0 [message #480362 is a reply to message #21752] |
Sun, 16 August 2009 08:15 |
Originally posted by: ls-test1.hotmail.com
How to get a fresh install on eclipse 3.5 ?
I only saw http://q4e.googlecode.com/svn/trunk/updatesite-iam/
is it update or install ? It always complains (from eclipse install) as:
Cannot complete the install because one or more required items could not
be found.
Software being installed: Eclipse IAM Team Support
0.10.0.20090627114955616-179-311A1738225A66727
(org.eclipse.iam.feature.teamsupport.feature.group
0.10.0.20090627114955616-179-311A1738225A66727)
Missing requirement: Eclipse IAM Team Support
0.10.0.20090627114955616-179-311A1738225A66727) requires
'org.eclipse.team.svn.ui [0.7.7,0.8.0)' but it could not be found
Another question, the url includes Maven 2.1 when I install it to eclipse,
How do I change it to other Maven version ?
Re: Announcing IAM 0.10.0 [message #480369 is a reply to message #480362] |
Sun, 16 August 2009 09:42 |
Abel Mui Messages: 247 Registered: July 2009 |
Hi L,
> be found.
You are trying to install IAM's support for subversive, but you do not
have a compatible version of subversive installed. Unckeck it.
> eclipse, How do I change it to other Maven version ?
Is there any reason you would like to change it? I mean, any
incompatibilities with the provided version? IAM uses the maven embedder
to do its internal work, so it can not be changed.
You can launch the goals with special requirements using any maven
version you have installed from the eclipse External Tools, and rely on
the embedder only for your IDE work.
Yours,
Abel Muiño
Re: Announcing IAM 0.10.0 [message #570367 is a reply to message #21752] |
be found.
Re: Announcing IAM 0.10.0 [message #570380 is a reply to message #480362] |
Hi L,
> be found.
Yours,
Abel Muiño
FUDForum. Page generated in 0.03689 seconds
