Home » Archived » BIRT » How to change image based on row value?
How to change image based on row value? [message #222964] Wed, 07 March 2007 17:47 Go to next message
Originally posted by: eric.garrett.sybase.com
I've got some images in a directory and I'd like to know how I can insert an
image into a column of my table based on a value in another column of that
row? or in other words, if column value is 'success' then I'd like a smiley
face image to be shown and if the column value is 'failure', I'd like to sad
face. From the palette, I dragged the image icon over to my table cell and
chose URI and expression builder and coded the following:
if (row["status"]=="success"){
"file:///c:/images/smiley.gif"
else {
"file:///c:/images/sad.gif"
I get the following error:
org.eclipse.birt.report.service.api.ReportServiceException: Error happened
while running the report
I would think there is a way to dynamically serve up an image based on
another column value.
Any help would be greatly appreciated, as I'm out of ideas.
Thanks!
NEVERMIND - How to change image based on row value? [message #222989 is a reply to message #222964] Wed, 07 March 2007 19:36 Go to previous messageGo to next message
I got it figured out...
used Text from palette and then coded up HTML type as:
<IMG src="
<VALUE-OF>
if ((row["type"] == "ASE") && (row["state"] == "Active")){
"/WebReport/images/aseicon.gif"
else if ((row["type"] == "Replication Server") && (row["state"] ==
"Active")) {
"/WebReport/images/rsicon.gif"
"Suspect")) {
"/WebReport/images/rsinfoicon.gif"
else if (row["type"] == "Replication Agent") {
"/WebReport/images/raicon.gif"
</VALUE-OF>
" alt="" >
"Eric Garrett" <eric.garrett@sybase.com> wrote in message
news:esnfdc$mp1$1@utils.eclipse.org...
> an image into a column of my table based on a value in another column of
> that row? or in other words, if column value is 'success' then I'd like a
> smiley face image to be shown and if the column value is 'failure', I'd
> like to sad face. From the palette, I dragged the image icon over to my
> table cell and chose URI and expression builder and coded the following:
> else {
> Thanks!
Re: How to change image based on row value? [message #223037 is a reply to message #222964] Wed, 07 March 2007 20:18 Go to previous messageGo to next message
> else {
> Thanks!
What version of Birt are you using?
I just did this expression in 2.1.2 and it works.
if(row["PRODUCTCODE"] == "S18_2248"){
"file:///c:/temp/down.jpg"
}else{
"file:///c:/temp/up.jpg"
Jason
Re: How to change image based on row value? [message #223176 is a reply to message #223037] Thu, 08 March 2007 09:07 Go to previous messageGo to next message
I'm using 2.1.1.v2006092*. Was this a known bug that has been fixed?
Eric.
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:esno97$vib$1@utils.eclipse.org...
>> a smiley face image to be shown and if the column value is 'failure', I'd
>> else {
>> happened while running the report
>> Thanks!
> }else{
> Jason
Re: How to change image based on row value? [message #223915 is a reply to message #223176] Fri, 09 March 2007 18:29 Go to previous message
> Eric.
>>> else {
>>> Thanks!
>> }else{
>> Jason
I thought this was a bug, but I thought it was fixed before 2.1.1.
Jason
Previous Topic:Path to libraries in the report design.
Next Topic:Problem with frameset viewer in iframe and Firefox
Current Time: Wed Nov 05 10:45:03 EST 2025
Powered by FUDForum. Page generated in 0.03349 seconds
