Re: Build Publisher 1.11 [message #1322156 is a reply to message #1315130] |
Tue, 29 April 2014 18:17 |
Terry Wright Messages: 4 Registered: April 2014 |
Here is a log from a minimal install. The only plugin I added in addition to the default plugins was the build-publisher. The log shows 6 builds and although they are accepted by the public facing server (hudson-dashboard) the build history does not get updated on this server. The RunMap.xml file does not get updated after the first published build (build #1 did not have publishing enabled).
Hudson log from building server:
Apr 27, 2014 1:52:23 PM hudson.plugins.build_publisher.PublisherThread run
INFO: Build #6 of project test was published.
Apr 27, 2014 1:52:23 PM hudson.model.Run run
INFO: Build test #6 main build action completed: SUCCESS
Apr 27, 2014 1:52:11 PM hudson.plugins.build_publisher.PublisherThread run
INFO: Build #5 of project test was published.
Apr 27, 2014 1:52:11 PM hudson.model.Run run
INFO: Build test #5 main build action completed: SUCCESS
Apr 27, 2014 1:51:34 PM hudson.plugins.build_publisher.PublisherThread run
INFO: Build #4 of project test was published.
Apr 27, 2014 1:51:34 PM hudson.model.Run run
INFO: Build test #4 main build action completed: SUCCESS
Apr 27, 2014 1:51:16 PM hudson.plugins.build_publisher.PublisherThread run
INFO: Build #3 of project test was published.
Apr 27, 2014 1:51:16 PM hudson.model.Run run
INFO: Build test #3 main build action completed: SUCCESS
Apr 27, 2014 1:50:48 PM hudson.plugins.build_publisher.PublisherThread run
INFO: Build #2 of project test was published.
Apr 27, 2014 1:50:46 PM hudson.model.Run run
INFO: Build test #2 main build action completed: SUCCESS
Apr 27, 2014 1:49:59 PM hudson.model.Run run
INFO: Build test #1 main build action completed: SUCCESS
Hudson log from server receiving build:
Apr 27, 2014 1:52:23 PM hudson.plugins.build_publisher.ExternalProjectProperty doAcceptBuild
INFO: Renaming: D:\hudson-dashboard\jobs\test\builds\2014-04-27_13-52-23 to D:\hudson-dashboard\jobs\test\builds\2014-04-27_13-52-23
INFO: Got remote timezone Europe/London
Apr 27, 2014 1:52:11 PM hudson.plugins.build_publisher.ExternalProjectProperty doAcceptBuild
INFO: Renaming: D:\hudson-dashboard\jobs\test\builds\2014-04-27_13-52-11 to D:\hudson-dashboard\jobs\test\builds\2014-04-27_13-52-11
Apr 27, 2014 1:51:34 PM hudson.plugins.build_publisher.ExternalProjectProperty doAcceptBuild
INFO: Renaming: D:\hudson-dashboard\jobs\test\builds\2014-04-27_13-51-34 to D:\hudson-dashboard\jobs\test\builds\2014-04-27_13-51-34
Apr 27, 2014 1:51:16 PM hudson.plugins.build_publisher.ExternalProjectProperty doAcceptBuild
INFO: Renaming: D:\hudson-dashboard\jobs\test\builds\2014-04-27_13-51-16 to D:\hudson-dashboard\jobs\test\builds\2014-04-27_13-51-16
Apr 27, 2014 1:50:48 PM hudson.plugins.build_publisher.ExternalProjectProperty doAcceptBuild
INFO: Renaming: D:\hudson-dashboard\jobs\test\builds\2014-04-27_13-50-46 to D:\hudson-dashboard\jobs\test\builds\2014-04-27_13-50-46
RunMap.xml file:
<?xml version='1.0' encoding='UTF-8'?>
<buildHistory>
<builds>
<build>
<number>2</number>
<displayName>#2</displayName>
<fullDisplayName>test #2</fullDisplayName>
<buildDir>2014-04-27_13-50-46/</buildDir>
<state>COMPLETED</state>
<result>SUCCESS</result>
<building>false</building>
<logUpdated>false</logUpdated>
<timestamp>1398603046000</timestamp>
<duration>218</duration>
<url>job/test/2/</url>
<builtOn></builtOn>
</build>
</builds>
<markers>
<LAST__STABLE>2</LAST__STABLE>
<LAST__COMPLETED>2</LAST__COMPLETED>
<LAST__SUCCESSFUL>2</LAST__SUCCESSFUL>
</markers>
</buildHistory>
FUDForum. Page generated in 0.02838 seconds
