Build Targets Disapear after Workbench restart [message #222823] |
Mon, 01 September 2008 12:45 |
Originally posted by: thomas.tc-schobers.de
i configured a C make Project, and everything is running fine. I create
Targets for compiling, Misra checks and so on. All works fine until i
restart the Eclipse IDE. After the restart alle targets have been deleted
and i only have the standard target "Debug". Is there something i can do to
change this ?
Thank you
Tom
PS: i am using Eclipse Ganymede and cdt 5.0
Re: Build Targets Disapear after Workbench restart [message #224066 is a reply to message #224061] |
Thu, 25 September 2008 22:44 |
Originally posted by: jamesblackburn+eclipse.mac.com
Yevgeny Shifrin wrote:
> I've encountered the same problem, it is really annoying. But it is not
> consistent ... I'm working with CDT 5, did anyone encounter this problem
> on earlier versions or this a new regression?
Yes, there are a worrying number of oddities with the project model. At
the moment there are a few known issues with corruption and race
conditions -- see bugzilla for more. I too have seen settings magically
revert when users do things like change an option, press Apply, change
another option and press OK.
> I've seen additional
> strange (non consistent) behavior: When new build configuration is being
> created it is possible to use existing build configuration as a
> "template" and then modifying it. After Eclipse restart it appears to be
> 2 original configurations (that was used as a template).
That sounds odd. If you can provide clear reproduction steps please file
a bug.
James
FUDForum. Page generated in 0.03946 seconds
