Home » Archived » BIRT » Legend entries
Legend entries [message #222788] Wed, 07 March 2007 07:14 Go to next message
Originally posted by: Ninja_Bunny.lycos.de
Hello!
I've a problem and it seems that I'm not able to solve it alone.
I've created a chart and want to group it by a value from the data set
called "Layer ID" but want to show the value "Layer Name" in the legend.
If I order by "Layer Name" the order is wrong, if I order by "Layer ID"
the legend shows -2 , -1, 0, 1 ...
I'm searching for a solution to say ' "sortBy(row["Layer ID"]);
legend.setText(row["Layer Name"]); '.
Does anyone of you have any suggestions?
Thank you!
Regards Nina
Re: Legend entries [message #223009 is a reply to message #222788] Wed, 07 March 2007 19:48 Go to previous message
Nina,
The grouping in the chart itself cannot sort on another row. However you can
solve that issue by grouping in the sql query, as sql should allow you this
kind of grouping/sorting. Then you won't need to group in the chart, just
put one value series for each group.
David
"Nina" <Ninja_Bunny@lycos.de> wrote in message
news:b1b65733c0495e8f12d8cdd4c43ad87b$1@www.eclipse.org...
> Hello!
> Thank you!
> Regards Nina
Previous Topic:Difference Chart Area Color Error
Next Topic:unable to run chart example using birt 2.1.2
Current Time: Sun Nov 09 06:06:05 EST 2025
Powered by FUDForum. Page generated in 0.02978 seconds
