Home » Language IDEs » ServerTools (WTP) » How do I include external files in dynamic web project?
How do I include external files in dynamic web project? [message #222721] |
Sun, 19 October 2008 19:16 |
Originally posted by: erics.nospam.com
I'm specifically thinking about Dojo, but this question pertains to any
external script or html file.
I'm working in Eclipse 3.3 on a dynamic web project destined for Tomcat
server. The external files are on the server in a subdirectory of
"webapps". Let's call it "common". If I refer to it like this in an HTML
file in my project, I know it will load fine when my project is copied over
to the server:
<script language="javascript" src="/common/script1.js"></script>
<a href="/common/page2.html">External HTML file</a>
But how do I get it to work when I'm debugging in Eclipse? It seems that
when I do "debug on server" in Eclipse, it copies my project files to a
temporay directory and runs from there. The problem is that the "common"
subdirectory doesn't exist in that temporary directory. So the scripts in
script1.js don't get loaded and page2.html is not found. Is there some way
to tell the Eclipse project to point to the "common" subdirectory in the
server installation when I'm debugging?
Thanks.
- Eric S.
Re: How do I include external files in dynamic web project? [message #222849 is a reply to message #222791] |
Tue, 21 October 2008 02:37 |
When I said external, I meant external to my Eclipse project. I don't
really need to put the common directory under webapps. It just needs to be
somewhere on the server where multiple applications can access it. Are you
saying it would be better to be under ROOT?
I guess it would work to create another project and copy the common files
there. But then when I publish/debug, they'll get copied to the temp
directory that Eclipse uses for the server, won't they? So I'll have copies
of those files in 3 places. I was hoping to just have one copy, though. No
way around having mutliple copies?
Thanks.
- Eric S.
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:gdhv2h$9ms$1@build.eclipse.org...
> By putting the files under a subdirectory of Tomcat's "webapps" folder,
> those files aren't really "external". You have used a convenience feature
> of Tomcat where Tomcat automatically tries to serve subdirectories of
> "webapps" as if they were Web applications. If you want to serve these
> "external" files in the same fashion in Eclipse, create a second dynamic
> web project called "common" and put the Dojo files in its "WebContent"
> folder. Then add this "common" project to the Tomcat server that is
> serving your first project.
> Cheers,
> Larry
> were Web
>> HTML file in my project, I know it will load fine when my project is
>> copied over to the server:
>> in script1.js don't get loaded and page2.html is not found. Is there
>> some way to tell the Eclipse project to point to the "common"
>> subdirectory in the server installation when I'm debugging?
>> Thanks.
>> - Eric S.
Re: How do I include external files in dynamic web project? [message #222880 is a reply to message #222849] |
Tue, 21 October 2008 14:01 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
To be shared by multiple applications implies they need to be in their
own webapp, "common" or "ROOT" doesn't really matter. Because Eclipse
is big on separating source from build artifacts, a "publish" is
necessary to get the webapp into a form that can be served, which
requires an additional copy of the resource. Since disk space is cheap,
this shouldn't be a problem.
You do have the option of enabling the "Serve modules without
publishing" option found in the Options section of the server editor
(double-click on the server to open). This uses a "trick" to serve the
projects directly from the workspace. You also have the option of
selecting "Use Tomcat installation..." in the Server Locations section
of the server editor. You could leave the "common" folder under the
webapp's directory of your Tomcat installation, but Eclipse would now
"own" the installation. For details, see the Tomcat FAQ[1].
Larry
[1] http://wiki.eclipse.org/WTP_Tomcat_FAQ
> Thanks.
> - Eric S.
>> Cheers,
>> Larry
>> were Web
>>> Thanks.
>>> - Eric S.
Re: How do I include external files in dynamic web project? [message #222915 is a reply to message #222880] |
Tue, 21 October 2008 21:17 |
Originally posted by: ericsn.nospam.no
Thanks. Those sound like pretty good options.
You're right that disk space is cheap. But the Dojo toolkit is large and
the time to copy it is significant. I want to keep those copy operations to
a minimum.
- Eric S.
news:gdknb7$b3a$1@build.eclipse.org...
> To be shared by multiple applications implies they need to be in their own
> webapp, "common" or "ROOT" doesn't really matter. Because Eclipse is big
> on separating source from build artifacts, a "publish" is necessary to get
> the webapp into a form that can be served, which requires an additional
> copy of the resource. Since disk space is cheap, this shouldn't be a
> problem.
> You do have the option of enabling the "Serve modules without publishing"
> option found in the Options section of the server editor (double-click on
> the server to open). This uses a "trick" to serve the projects directly
> from the workspace. You also have the option of selecting "Use Tomcat
> installation..." in the Server Locations section of the server editor.
> You could leave the "common" folder under the webapp's directory of your
> Tomcat installation, but Eclipse would now "own" the installation. For
> Cheers,
> Larry
>> be somewhere on the server where multiple applications can access it.
>> Are you saying it would be better to be under ROOT?
>> copies of those files in 3 places. I was hoping to just have one copy,
>> though. No way around having mutliple copies?
>> Thanks.
>> - Eric S.
>>> feature of Tomcat where Tomcat automatically tries to serve
>>> subdirectories of "webapps" as if they were Web applications. If you
>>> want to serve these "external" files in the same fashion in Eclipse,
>>> create a second dynamic web project called "common" and put the Dojo
>>> files in its "WebContent" folder. Then add this "common" project to the
>>> Tomcat server that is serving your first project.
>>> Cheers,
>>> Larry
>>> were Web
>>>> that when I do "debug on server" in Eclipse, it copies my project files
>>>> to a temporay directory and runs from there. The problem is that the
>>>> "common" subdirectory doesn't exist in that temporary directory. So
>>>> the scripts in script1.js don't get loaded and page2.html is not found.
>>>> Is there some way to tell the Eclipse project to point to the "common"
>>>> Thanks.
>>>> - Eric S.
Current Time: Tue Sep 24 17:02:01 GMT 2024
Powered by FUDForum. Page generated in 0.04318 seconds
