Home » Archived » XML Schema Definition (XSD) » Empty Closed Element(Eclipse - XML Editor - How to get Empty Closed Element)
Empty Closed Element [message #1310228] Wed, 23 April 2014 00:39 Go to next message
Am pretty new to Eclipse and XSDs. I have couple of questions
1. When I add an Element in Design view while creating an XSD, I need to have empty Closed Element rather than Non-Empty Closed element by Default. Any clue on where to change the setting in Eclipse to accomplish this?For example am getting the below source when I add an element in Design view
<xs:element name="NewElement" type="xs:string"></xs:element>
However I want it be like
<xs:element name="NewElement" type="xs:string" />
2. When I add multiple elements into a Type via Design view, the code is getting generated on the same line continuously without a line break. Am getting like this
<xs:complexType name="RootElementType"><xs:sequence><xs:element name="Element1" type="commonids:Element1Type" maxOccurs="1" minOccurs="0"></xs:element>
but I need it to be like
<xs:sequence>
<xs:element name="Element1" type="commonids:Element1Type" maxOccurs="1" minOccurs="0" />
I appreciate any help on the above.
Karthik
Re: Empty Closed Element [message #1310940 is a reply to message #1310228] Wed, 23 April 2014 09:48 Go to previous message
Karthik,
You should direct questions about the XML Schema editor to the Web Tools
newsgroup.
> <xs:sequence>
> Thanks
> Karthik
Previous Topic:XSD Help
Next Topic:A diagram of XMI
Current Time: Thu Nov 06 13:52:02 EST 2025
Powered by FUDForum. Page generated in 0.03712 seconds
