Home » Eclipse Projects » GEF » Problem using tool in view
Problem using tool in view [message #221643] Wed, 16 August 2006 12:24 Go to next message
Originally posted by: guerreroderrick.gmail.com
I'm trying to use GEF with a view. In createPartControl(), I use:
viewer = new GraphicalViewerImpl();
viewer.createControl(parent);
viewer.setEditPartFactory(new MyEditPartFactory());
viewer.setContents(gameBoard);
EditDomain domain = new EditDomain();
domain.setDefaultTool(new ConnectionCreationTool());
viewer.setEditDomain(new EditDomain());
I also have several GamePieces already established that extends
NodeEditPart. In isntallEditPolicies() of GamePieceEditPart, I have:
installEditPolicy(EditPolicy.NODE_ROLE, new GamePieceEditPolicy());
and all of the functions in my GamePieceEditPolicy simply output to
System.out...
I assumed that setting a ConnectionCreationTool was all I needed for the
GEF framework to call the functions in my GamePieceEditPolicy, but
nothing is being called in my GamePieceEditPolicy. Can anybody tell me
what I am missing?
Guerrero
Re: Problem using tool in view [message #221651 is a reply to message #221643] Wed, 16 August 2006 13:59 Go to previous messageGo to next message
A small fix, I changed viewer.setEditDomain(new EditDomain()); to
viewer.setEditDomain(domain); (A stupid error on my part) but I still
can't get GEF to call the functions in GamePieceEditPolicy...?
Guerrero
> System.out...
> what I am missing?
> Guerrero
Re: Problem using tool in view [message #221667 is a reply to message #221651] Wed, 16 August 2006 14:53 Go to previous messageGo to next message
Got it, apparently, I needed domain.setActiveTool(...) instead of
setDefaultTool, Ooops!
Guerrero
> Guerrero
>> System.out...
>> the GEF framework to call the functions in my GamePieceEditPolicy, but
>> me what I am missing?
>> Guerrero
Re: Problem using tool in view [message #221675 is a reply to message #221667] Wed, 16 August 2006 23:18 Go to previous messageGo to next message
Originally posted by: dstamkokeng.gmail.com
I am just stuck with trying to display my GEF editor in a single view and
I saw your thread! May I know how do you embed your editor into the view?
Or did you go about it in another method? Thanks in advance!
Re: Problem using tool in view [message #221680 is a reply to message #221675] Wed, 16 August 2006 23:28 Go to previous messageGo to next message
Actually I am extending the Shapes Editor example in GEF, whose
ShapeEditor extends the GraphicalEditor.
Do I have to let it extend a viewPart etc? Thanks alot
Re: Problem using tool in view [message #221705 is a reply to message #221680] Thu, 17 August 2006 10:06 Go to previous messageGo to next message
I extend ViewPart because I was making a simple game in a view and I
didn't have any need for saving or loading. I also use new
GraphicalViewerImpl() to display the GEF part. To get it working, I
first used Draw2d to figure out how to make my display, and then used
what I learned to implement the GEF framework. The following lines
should be able to display the GEF model:
in createPartControl(Composite parent) ...
viewer.setEditPartFactory(new MyEditPartFactory()); // your factory
viewer.setContents(gameBoard); // your model root
Guerrero
Re: Problem using tool in view [message #221758 is a reply to message #221705] Thu, 17 August 2006 21:48 Go to previous messageGo to next message
What if I am already using editorPart? Is it possible to embed my whole
editor into a view? I will need that for my application. Thanks
Re: Problem using tool in view [message #221796 is a reply to message #221758] Fri, 18 August 2006 11:52 Go to previous messageGo to next message
I may be wrong, but I don't think you can embed a editor into a view or
a view into an editor... What is preventing you from just using an
editor instead of a view?
Guerrero
Meo Kok Eng wrote:
Re: Problem using tool in view [message #221934 is a reply to message #221796] Mon, 21 August 2006 23:14 Go to previous message
Originally posted by: meokoken.gmail.com
Its because my module is part of a project and will require only a single
view for each module. Thanks for the help! :) I will look for other
methods. Thanks alot
Previous Topic:How to add the align left, align middle and align right actions to the shapeEditor example
Next Topic:Ruler+Guide+Property
Current Time: Thu Nov 06 18:59:07 EST 2025
Powered by FUDForum. Page generated in 0.07463 seconds
