Home » Eclipse Projects » GEF » Cannot delete an object???
Cannot delete an object??? [message #221353] Fri, 11 August 2006 15:39 Go to next message
Originally posted by: guerreroderrick.gmail.com
The delete key has no effect in my project.
I have been creating a graph editor using the ShapesEditor as an
example. However, I do not seem to be able to delete any nodes. In my
GraphNodeEditPart class I have installed a new NodeComponentEditPolicy,
in which I create a new GraphNodeDeleteCommand. Stepping through the
project in debug, I have noticed that when I select a node, the
GraphNodeDeleteCommand is created with the correct graph and graphNode
variables. It also calls my canExecute() method which returns true when
the graph and graphNode variables are not null (they are not null when I
step through with debug). But hitting the delete key does absolutely
nothing. (Neither execute() nor redo() is called).
I assumed I was missing something in the key handler, but I use
GraphicalViewerKeyHandler(viewer) exactly like the ShapesEditor example.
And I cannot find any other differences involving delete.
Am I missing some fundamental step in deleting an object? Or do I need
to do anything to configure the GraphicalViewerKeyHandler.
Any help would be greatly appreciated.
Thanks in advance,
Guerrero
Re: Cannot delete an object??? [message #221387 is a reply to message #221353] Fri, 11 August 2006 16:49 Go to previous message
I figured it out. Apparently I needed to also create an
ActionBarContributor and include it in the contributorClass extension
for the editor. I also needed to override the protected method
buildActions(), and add the line
addRetargetAction(new DeleteRetargetAction());
Since the class extending ActionBarContributor wasn't mentioned anywhere
in code, only in the plugin extension, this took forever to find.
Guerrero.
> Thanks in advance,
> Guerrero
Previous Topic:UndoablePropertySheetPage and Wrapped/Unwrapped Property Values (EMF.Edit)
Next Topic:no 3.3 integration builds?
Current Time: Fri Sep 26 21:06:21 EDT 2025
Powered by FUDForum. Page generated in 0.03637 seconds
