Home » Language IDEs » ServerTools (WTP) » Re: Scripting headless export of WAR file
Re: Scripting headless export of WAR file [message #221071] |
Tue, 09 September 2008 13:29 |
Originally posted by: eclipse-news.rizzoweb.com
Copying this to the eclipse.webtools newsgroup where it might get more
attention.
Jacob wrote:
> Hello all,
> I am currently using Eclipse's built-in, automated build tools to build
> my workspace which is comprised of several interdependent projects. This
> works fine for the moment, but I'd like to migrate to a headless,
> automated build system. One solution would be to use ANT, but I would
> prefer to continue using Eclipse's build tools, and I have found some
> documentation that seems to indicated that it is possible to run Eclipse
> headless and have it build the build the workspace
> [http://help.eclipse.org/ganymede/index.jsp]. In addition to building my
> projects' class files, I need to be able to export a WAR using Eclipse's
> built-in WAR exporter, and I was wondering if it would be possible to
> script this from the command-line in a similar manner as above, by
> simply executing Eclipse and passing in command-line arguments?
> If not, would the WAR exporter and jdt.apt.core.aptBuild be fairly
> well-exposed to an external script running on the JVM (for example Rhino
> or Jython)? Is there any sample code that implements something similar
> to this?
> I would greatly appreciate any guidance anyone can offer. Thanks,
> Jacob Beard
Re: Scripting headless export of WAR file [message #221087 is a reply to message #221071] |
Tue, 09 September 2008 15:56 |
Originally posted by: dcarver.starstandard.org
You might be interested in Ant 4 Eclipse:
http://ant4eclipse.sourceforge.net/ant-for-eclipse-home.html
It'll allow you to write Ant scripts that leverage your existing eclipse
configuration files.
Dave
> attention.
> Jacob wrote:
>> Hello all,
>> build my workspace which is comprised of several interdependent
>> projects. This works fine for the moment, but I'd like to migrate to a
>> headless, automated build system. One solution would be to use ANT,
>> but I would prefer to continue using Eclipse's build tools, and I have
>> found some documentation that seems to indicated that it is possible
>> to run Eclipse headless and have it build the build the workspace
>> my projects' class files, I need to be able to export a WAR using
>> Eclipse's built-in WAR exporter, and I was wondering if it would be
>> possible to script this from the command-line in a similar manner as
>> above, by simply executing Eclipse and passing in command-line arguments?
>> Rhino or Jython)? Is there any sample code that implements something
>> similar to this?
>> Jacob Beard
Re: Scripting headless export of WAR file [message #221153 is a reply to message #221087] |
Tue, 09 September 2008 21:36 |
Jacob Messages: 7 Registered: July 2009 |
David, thank you for the link. Unfortunately, despite a recent series of
commits, the project does not appear to be maintained (last release was in
January, 2007). I understand the idea behind it, though, and it does seem
to be the best way to fulfill my requirements, so I spent some time testing
it today to see if it would be able to build any of my projects.
Unfortunately, it did not succeed. I was wondering if anyone might be able
to point me to a similar project that might allow easy integration of
Eclipse building with Ant?
Thanks again, and I look forward to hearing what you think,
Jacob
> Dave
>> attention.
>> Jacob wrote:
>>> Hello all,
>>> arguments?
>>> similar to this?
>>> Jacob Beard
Re: Scripting headless export of WAR file [message #221161 is a reply to message #221087] |
Tue, 09 September 2008 22:05 |
Also, I was wondering if the WAR exporter was fairly well exposed to other
Eclipse plugins. Any information on the exporter class (for instance, where
in webtools it lives; a link to the javadoc would be fantastic) would be
greatly appreciated.
Thanks again,
Jacob
> Dave
>> attention.
>> Jacob wrote:
>>> Hello all,
>>> arguments?
>>> similar to this?
>>> Jacob Beard
Current Time: Wed Sep 18 19:42:20 GMT 2024
Powered by FUDForum. Page generated in 0.04172 seconds
