[NullPointerException],at org.eclipse.ui.internal.menus.WorkbenchMenuService.releaseContributions() [message #220669] |
Fri, 06 March 2009 01:57 |
Allen Wang Messages: 28 Registered: July 2009 |
Dears,
I developed a multipage editor with both GMF editor and EMF editor
following TopicMap example, and after each time workbench exit, I will
receive NPE as following. My eclipse version is Version: 3.4.1, Build
id: M20080911-1700. You can easily reproduced this exception using
TopicMap example, it also has such a problem.
I searched in newsgroup and found a bug report BUG[173657]
[https://bugs.eclipse.org/bugs/show_bug.cgi?id=173657], it shows the
same problem which I met but have no detailed solutions for this.
Anybody knows how to resolve or avoid this problem? Any suggestion is
welcome, thanks!
at
org.eclipse.ui.internal.menus.WorkbenchMenuService.releaseCo ntributions(WorkbenchMenuService.java:869)
at
org.eclipse.ui.internal.menus.WorkbenchMenuService.releaseCo ntributions(WorkbenchMenuService.java:875)
at
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1598)
at
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:722)
at
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:698)
at org.eclipse.ui.internal.WorkbenchWindow$3.run(WorkbenchWindo w.java:814)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:812)
at org.eclipse.jface.window.WindowManager.close(WindowManager.j ava:109)
at org.eclipse.ui.internal.Workbench$16.run(Workbench.java:912)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:9 09)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:8 38)
at org.eclipse.ui.internal.Workbench$23.run(Workbench.java:1082 )
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1080)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1052)
at
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:719)
at
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:741)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:68 7)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:92)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:307)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1643)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3789 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:337)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1576)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:1937)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4528 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2366 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:477)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3877 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:23 71)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3420)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at
org.eclipse.ui.internal.views.log.EventDetailsDialog.open(Ev entDetailsDialog.java:170)
at
org.eclipse.ui.internal.views.log.EventDetailsDialogAction.r un(EventDetailsDialogAction.java:98)
at
org.eclipse.ui.internal.views.log.LogView$15.doubleClick(Log View.java:513)
at
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:799)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:797)
at
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1419)
at
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1173)
at
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:237)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:234)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:295)
Best Regards,
Hexise
FUDForum. Page generated in 0.02805 seconds
