| null PerProjectInfo causing exception [message #220523] |
Tue, 13 December 2005 13:31  |
I have some code that uses JavaCore.create() to create a IJavaProject from
a dynamic web project. The code then attempts to get the classpath from
that Java project using getRawClasspath(). The JavaProject object seems
to be created ok but an exception is thrown in the process of retrieving
the classpath. The jdt portion of the exception is shown below.
Debugging this, I've traced to
JavaModelManager.getPerProjectInfoCheckExistence().
The PerProjectInfo returned by getPerProjectInfo is null so
the newNotPresentException is thrown.
Does anyone have an idea why the PerProjectInfo might be coming back as
null?
thanks, Joan.
IWAB0503E Unable to update Java build path. Please check your system
environment.
Java Model Exception: Java Model Status [Servers does not exist]
at
org.eclipse.jdt.internal.core.JavaElement.newNotPresentExcep tion(JavaElement.java:468)
at
org.eclipse.jdt.internal.core.JavaModelManager.getPerProject InfoCheckExistence(JavaModelManager.java:1223)
at
org.eclipse.jdt.internal.core.JavaProject.getPerProjectInfo( JavaProject.java:1792)
at
org.eclipse.jdt.internal.core.JavaProject.getRawClasspath(Ja vaProject.java:1849)
at
org.eclipse.jdt.internal.core.JavaProject.getRawClasspath(Ja vaProject.java:1835)
FUDForum. Page generated in 0.04169 seconds
