gdb debugger connection error in parallel debugging mode [message #1303542] |
Sat, 19 April 2014 09:55 |
R Su Messages: 4 Registered: April 2014 |
I installed gdb by macports in /opt/local/bin/, and codesigned in mac os mavericks system. when I use it to debug c++ project, there is no problem, but when I debug mpi c++ project in parallel mode, I got a connection error shown bellow:
Message:cannot connect to debugger
Exception Stack Trace:
org.eclipse.core.runtime.CoreException: Cannot connect to debugger
at org.eclipse.ptp.internal.debug.core.PSession.connectToDebugger(PSession.java:127)
atorg.eclipse.ptp.launch.ParallelLaunchConfigurationDelegate$DebuggerSession.run(ParallelLaunchConfigurationDelegate.java:84)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Session Data:
eclipse.buildId=4.3.2.M20140221-1700
java.version=1.8.0_05
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.parallel.product -keyring /Users/sur/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.parallel.product -keyring /Users/sur/.eclipse_keyring -showlocation
I was stuck with the problem couple of days , and tried hard to solve it by following the guide and searching online information, but failed.
Your timely assistance will be much appreciated!
Thanks!
[Updated on: Tue, 22 April 2014 00:05] Report message to a moderator
FUDForum. Page generated in 0.07433 seconds
