Unhandled event loop exception [message #21348] |
Mon, 09 June 2008 19:44 |
Originally posted by: tcelvis.gmail.com
I am trying to follow the guidelines in the IMP users guide (May 2008).
I have sucessfully created an IMP project, but I get an error "Unhandled
event loop exception" when I attempt to use the Language description
wizard.
Error details:
eclipse.buildId=M20071023-1652
java.version=1.6.0_10-beta
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=da_DK
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file K:\Eclipse RCP
Workspace\.metadata\.bak_0.log
Created Time: 2008-04-26 00:33:58.718
Error
Mon Jun 09 21:42:26 CEST 2008
java.lang.NoSuchMethodError:
org.eclipse.pde.internal.core.PluginModelManager.getAllPlugi ns()[Lorg/eclipse/pde/core/plugin/IPluginModelBase;
at
org.eclipse.imp.wizards.IMPWizardPage.getPluginModel(IMPWiza rdPage.java:694)
at
org.eclipse.imp.wizards.CodeServiceWizard.getStandardSubstit utions(CodeServiceWizard.java:311)
at
org.eclipse.imp.wizards.CodeServiceWizard.getStandardSubstit utions(CodeServiceWizard.java:287)
at org.eclipse.imp.wizards.NewLanguage.performFinish(NewLanguag e.java:189)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:182)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Any hints on what I need to do to resolve this ?
Thomas Christensen
Re: Unhandled event loop exception [message #21444 is a reply to message #21429] |
Wed, 11 June 2008 20:41 |
Hi Robert,
It was on:
Eclipse RCP
Version: 3.3.1.1
Build id: M20071023-1652
I have swtched to:
Eclipse
Version: 3.2.1
Build id: M20060921-0945
Using 3.2, I have managed to get as far as using the
New LPG Grammar with Parser Wrapper for IMP wizard
sucessfully, and created a lexer and parser with the
sample grammar.
So I guess it seems to be working :-)
Thomas
Re: Unhandled event loop exception [message #21459 is a reply to message #21451] |
Fri, 13 June 2008 17:37 |
My IMP-related plugins in my Eclipse RCP are a mix of versions 1.0.72,
1.0.73 and 3.2.72.
The IMP-plugins in my Eclipse 3.2 are versions 0.1.73 and 0.1.74
FUDForum. Page generated in 0.04231 seconds
