On startup eclipse uses all the memory [message #219612] |
Thu, 01 April 2004 01:47  |
I am trying to run eclipse 2.1.3rc2-linux-motif on box running
Debian/Testing and it doesn't complete the startup. I couldn't find this
issue in the FAQ.
It shows the splash screen and then uses all the CPU and eats memory,
both phyiscal and virtual until after about 10 minutes all the memory is
used up and the jvm exits. This happens with java 1.4.1 and 1.3.
Is there something fundamental that I missed here?
Here is some debug output:
$ /usr/local/eclipse/eclipse -debug -vm /usr/local/j2re1.4.1/bin/java
-consoleLog -data /home/glenn/eclipse
Start VM: /usr/local/j2re1.4.1/bin/java
-cp /usr/local/eclipse/startup.jar org.eclipse.core.launcher.Main
-os linux
-ws motif
-arch x86
-showsplash /usr/local/eclipse/eclipse -showsplash 600
-debug
-consoleLog
Startup: using configuration
file:/home/glenn/eclipse/.metadata/.config/platform.cfg
Boot URL:
file:/usr/local/eclipse/plugins/org.eclipse.core.boot_2.1.3/ boot.jar
Startup: splash path =
/usr/local/eclipse/plugins/org.eclipse.platform_2.1.3/splash .bmp
Workspace location:
/home/glenn/eclipse
Debug-Options:
file:/home/glenn/eclipse/.options
Install URL:
Warning: XmParseMappingCreate() is not implemented yet!
Warning: XtRemoveGrab asked to remove a widget not on the list
Re: On startup eclipse uses all the memory [message #219776 is a reply to message #219625] |
Thu, 01 April 2004 09:19  |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
>> this issue in the FAQ.
>> is used up and the jvm exits. This happens with java 1.4.1 and 1.3.
> By accident I found the solution to this problem here:
> http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#usingLessTif
> Even though the FAQ says it should work fine with lessTif, in my case it
> doesn't work at all. FYI the lessTif versions installed on my system are
> ii lesstif1 0.93.18-4 OSF/Motif implementation released
> under LGPL
> ii lesstif2 0.93.41-1 OSF/Motif 2.1 implementation released
> under
> Maybe the FAQ could be updated?
> g
put in a bug report.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
FUDForum. Page generated in 0.05781 seconds
