Home » Eclipse Projects » Nebula » java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Canvas
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Canvas [message #21270] |
Tue, 26 December 2006 20:33 |
Originally posted by: ira.greenstein.austin.rr.com
OK, i need to eat some humble pie on this one. (newbie alert)
I am running Eclipse 3.2 within a Callisto distro. If i run any of the
Nebula widget example snippets, everything works as specified. However,
as i write a simple RCP application, and i run it from the IDE, i get the
error message
Such as when i execute the lines:
public class FilterView extends ViewPart {
public void createPartControl( Composite parent )
PShelf shelf = new PShelf(parent, SWT.BORDER);
What do i need to include in the run time plug-ins or classpath to get by
this error. I have already selected all plug-ins and this error was still
generated. Obviously, i am missing something simple.
Thanks!
Re: java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Canvas [message #21300 is a reply to message #21289] |
Fri, 29 December 2006 15:51 |
Originally posted by: ira.greenstein.realtimerecovery.com
Chris Gross wrote:
> Hi Ira,
> This is a strange error. Did you get any errors about not loading the
> SWT plugin? I'm not sure how you would get this error if the SWT plugin
> was loaded successfully.
> -Chris
>> the error message
>> by this error. I have already selected all plug-ins and this error was
>> still generated. Obviously, i am missing something simple.
>> Thanks!
Hello Chris,
I just found a work qround to this issue, though i'm not sure if it is
correct. My apologies, but I had not fully stated all of my steps. I
went ahead and created a plug-in from the nebula jar file, as outlined in
the book, "Eclipse Rich Client Platform". From there, i added this new
plug-in to my RCP application via the "Dependencies" form. In the "Run"
form, i added the plug-in to the application. Actually, just allowing it
to "Add Required Plug-Ins" handled that for me. When i ran the app, i
then received the error
Just a few minutes ago, i went ahead and in the "Nebula" plug-in, on the
"Dependencies" form, i added
org.eclipse.swt
as an experiment.
This seems to have done the trick, though i'm not sure if this is correct.
- Ira
Re: java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Canvas [message #21309 is a reply to message #21300] |
Fri, 29 December 2006 16:30 |
Chris Gross Messages: 253 Registered: July 2009 |
Hi Ira,
What you did is correct. In the future, we will produce plugin/jars for
each widget that won't require you to wrap them as you've done. So
you'll just be able to use the widget as you would any other Eclipse plugin.
-Chris
Ira wrote:
> Chris Gross wrote:
>> Hi Ira,
>> plugin was loaded successfully.
>> -Chris
>>> the Nebula widget example snippets, everything works as specified.
>>> However, as i write a simple RCP application, and i run it from the
>>> IDE, i get the error message
>>> get by this error. I have already selected all plug-ins and this
>>> error was still generated. Obviously, i am missing something simple.
>>> Thanks!
> Hello Chris,
> in the book, "Eclipse Rich Client Platform". From there, i added this
> new plug-in to my RCP application via the "Dependencies" form. In the
> "Run" form, i added the plug-in to the application. Actually, just
> allowing it to "Add Required Plug-Ins" handled that for me. When i ran
> the app, i then received the error
> org.eclipse.swt
> as an experiment.
> - Ira
Re: java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Canvas [message #573302 is a reply to message #21289] |
Chris Gross wrote:
> Hi Ira,
> -Chris
>> the error message
>> Thanks!
Hello Chris,
org.eclipse.swt
as an experiment.
- Ira
Re: java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Canvas [message #573334 is a reply to message #21300] |
Chris Gross Messages: 471 Registered: July 2009 |
Hi Ira,
-Chris
Ira wrote:
> Chris Gross wrote:
>> Hi Ira,
>> -Chris
>>> Thanks!
> Hello Chris,
> org.eclipse.swt
> as an experiment.
> - Ira
Current Time: Sun Sep 22 03:25:20 GMT 2024
Powered by FUDForum. Page generated in 0.04202 seconds
