Home » Eclipse Projects » Plugin Development Environment (PDE) » Running inside Eclipse and Exporting (Import-Package: Conflicts)
Running inside Eclipse and Exporting (Import-Package: Conflicts) [message #21242] Fri, 12 September 2008 07:40 Go to next message
I have a strange problem. I have a medium sized project which use a lot
bundles (Eclipse-RCP, Spring-OSGi and Repacked Bundles from SpringSource
(=Hibernate+Dependencies)).
When I run my application and or validate it inside the Run-Dialog all
dependencies are resolved and the application starts with problems.
Now when I create a .product-File from them I suddenly get
Import-Package: xxx conflicts. Why does that happen only on export and
not when I validate the bundles in side the Run-Dialog?
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Running inside Eclipse and Exporting (Import-Package: Conflicts) [message #55283 is a reply to message #21242] Wed, 15 April 2009 10:50 Go to previous messageGo to next message
Originally posted by: gaston.tonietti.teracode.com
I have a similar problem, I have a product configuration for my application and running it form product form is working perfect but I
get an error while exporting, with a very poor message by the way (It may have which exported package is having the problem at least):
Bundle com.xxx_1.0.0 failed to resolve.:
Package uses conflict: Require-Bundle: org.springframework.osgi.extender; bundle-version="1.1.2"
I was able to solve it some days ago, removing all entries in dependencies tab, then adding my application bundle and clicking "Add
required plug-ins" button, but the error appeared again and I cannot resolve it the same way this time. Very strange.
I would appreciate a lot your help. I must export the product as soon as possible and I'm having problems with the headless build as
well, but lets discus it in a separate thread.
Thanks a lot
Gaston.
Tom Schindl wrote:
> Tom
Re: Running inside Eclipse and Exporting (Import-Package: Conflicts) [message #55722 is a reply to message #55283] Thu, 16 April 2009 09:22 Go to previous message
It seems that it is caused for some bugs in PDE. Maybe related to:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=269110 or
https://bugs.eclipse.org/bugs/show_bug.cgi?id=267562
I have tried with last nightly build and it worked for me.
Gaston.
Gaston M. Tonietti wrote:
> application and running it form product form is working perfect but I get
> tab, then adding my application bundle and clicking "Add required
> possible and I'm having problems with the headless build as well, but lets
> Thanks a lot
> Gaston.
> Tom Schindl wrote:
>> Tom
Re: Running inside Eclipse and Exporting (Import-Package: Conflicts) [message #595239 is a reply to message #21242] Wed, 15 April 2009 10:50 Go to previous message
Thanks a lot
Gaston.
Tom Schindl wrote:
> Tom
Re: Running inside Eclipse and Exporting (Import-Package: Conflicts) [message #595419 is a reply to message #55283] Thu, 16 April 2009 09:22 Go to previous message
Gaston.
> Thanks a lot
> Gaston.
> Tom Schindl wrote:
>> Tom
Previous Topic:Plugin Development Process
Next Topic:Retrieve activated plugins for extension id
Current Time: Wed Nov 05 07:47:12 EST 2025
Powered by FUDForum. Page generated in 0.03940 seconds
