Home » Eclipse Projects » Eclipse Scout » Scout server running under special account
Scout server running under special account [message #1299944] Thu, 17 April 2014 04:07 Go to next message
are there ways to run my Scout server application under a special account (I am using Windows / Tomcat). I need this because I need the server application to be able to access certain directories that are restricted for most users.
Regards bertin
Re: Scout server running under special account [message #1302346 is a reply to message #1299944] Fri, 18 April 2014 13:34 Go to previous message
Hi Bertin
If you have a Tomcat default installation on Windows, Tomcat is registered as a Windows Service. In the Service properties you can specify the account under which the service is running. By default this is the local system account, but you can change it to any user you like.
Open the Windows Services Console (type "services" in the start menu search field), you should see a service listed as "Apache Tomcat 7" or similar.
Open the Service properties (right click -> Properties), switch to Tab "Log On". Change the logon user from local system account to a specific user and provide username and password.
Alternatively you can access the Service properties via the tomcat7w.exe (note the w in the file name!) from the Tomcat installation folder.
Maybe you find the following links helpful:
http://tomcat.apache.org/tomcat-7.0-doc/windows-service-howto.html
http://msdn.microsoft.com/en-us/library/windows/desktop/ms677948%28v=vs.85%29.aspx
Lukas
Previous Topic:Parameterising LookupCalls
Next Topic:Permissions on Tomcat
Current Time: Thu Nov 06 12:36:21 EST 2025
Powered by FUDForum. Page generated in 0.03831 seconds
