WST Validation framework uses 160-200% CPU for 5-10 minutes [message #218668] |
Sun, 03 August 2008 19:26 |
Originally posted by: rosec.messagingdirect.com
I'm running the Ganymede release of Eclipse/WST, and I'm getting
situations where -- and this is happening as I type this -- Eclipse is
simply sitting here using between 160-200% of the CPU to run a
"Validation Monitor" whose status in the progress monitor indicates that
it's blocked on something. I was going to copy the message, but in the
time it took for the UI to repaint when I moved this mail windows out of
the way (2 minutes, if you're counting) the progress operation had
cleared itself, and now I can't get the message back.
I have gotten to the point where step one of any project creation for me
is to disable all validation tools; they do this for each and every
project for which I've enabled them. I don't lack for processor
resources or RAM -- Eclipse is run with -Xmx2048m and I have a dual-core
2.66Ghz CPU -- but I cannot consistently get validation to work any
faster than "wait 10 minutes for any part of your machine to respond"
which seems... inconvenient. I haven't managed to find a consistent
trigger for this.
I'm certainly willing to try some test cases if anyone thinks it will
help. As it is, some days it'd be faster to edit my java code in emacs,
and that's just madness :)
Chris Rose
Developer Planet Consulting Group
(780) 577-8433
crose@planetci.com
Re: WST Validation framework uses 160-200% CPU for 5-10 minutes [message #218694 is a reply to message #218668] |
Mon, 04 August 2008 04:33 |
Originally posted by: dcarver.starstandard.org
I've noticed some similar things, but mostly if I have a large number of
XSDs, and XML files in a project. The more HTML files, and items one
has in a project the longer it can take for the validation to complete.
What I've taken to doing is setting up Include and Exclude rules to help
control what gets validated and when. This significantly seems to
help. By setting them up as project specific settings, they can be
controled on a project by project basis. If you have a team of
developers, make sure you check in your .settings folder for the
project, this way your other team members will pickup the changes.
With this said, it sounds like this could be one of those "real world"
situations that might not be tested as well as it should be from a
performance stand point. I would recommend opening up a bug report
with steps on how to reproduce the issue.
Dave
> trigger for this.
Re: WST Validation framework uses 160-200% CPU for 5-10 minutes [message #218773 is a reply to message #218694] |
Mon, 04 August 2008 14:46 |
> Dave
>> that it's blocked on something. I was going to copy the message, but
>> in the time it took for the UI to repaint when I moved this mail
>> windows out of the way (2 minutes, if you're counting) the progress
>> operation had cleared itself, and now I can't get the message back.
>> me is to disable all validation tools; they do this for each and every
>> dual-core 2.66Ghz CPU -- but I cannot consistently get validation to
>> work any faster than "wait 10 minutes for any part of your machine to
>> respond" which seems... inconvenient. I haven't managed to find a
>> consistent trigger for this.
>> emacs, and that's just madness :)
I haven't seen where such rules are set up. Would this speed up Seam?
Seam seems to knock Eclipse down on the ground and kick it unmercifully.
It can take 20-30 seconds to change focus from one type of file to
another (open a different file for editing). I don't know what's going
on, but it strikes me as validation slowness. This may or may not be a
Ganymede problem; I haven't upgraded from 3.3.2 yet.
Russ Bateman
Re: WST Validation framework uses 160-200% CPU for 5-10 minutes [message #218795 is a reply to message #218773] |
Mon, 04 August 2008 16:17 |
The include/exclude is only available in Ganymede and with Web Tools
3.0. It may or may not speed up the validation, but the more
validators you have running, the more threads it kicks off for the
validators, and depending on your system it can become very slow.
I've had a project take as long as 30 minutes to complete validation
without first going through and including/excluding items. Mostly I
use the exclude functionality at the project level.
Dave
Re: WST Validation framework uses 160-200% CPU for 5-10 minutes [message #218838 is a reply to message #218795] |
Mon, 04 August 2008 18:11 |
I'll bite; how can I disable this? It's worth noting, the project is
NOT a dynamic web project or any of the WST project types, it's just a
plain old java project (build infrastructure gets in the way... don't
ask ;) ) that contains a lot of J2EE artifacts. I can't find an option
to disable validation other than the one in the project validation
settings to 'suspend all validators' but that didn't help with the issue
I was describing until I restarted Eclipse.
> Dave
Chris Rose
(780) 577-8433
crose@planetci.com
Re: WST Validation framework uses 160-200% CPU for 5-10 minutes [message #218860 is a reply to message #218838] |
Mon, 04 August 2008 20:06 |
If you want to disable validation for validators on a global basis, you
can go into Preferences -> Validation and deselect the validators you
don't need.
On a project by project basis it's under Project->Properties->Validation
Dave
Re: WST Validation framework uses 160-200% CPU for 5-10 minutes [message #218973 is a reply to message #218876] |
Tue, 05 August 2008 15:57 |
I'll do that the next time it occurs. From what I recall, there was
only one validator in there. I'm sure it'll happen again, so I'll
report back at that time.
> If you have time, could you open Windows->Show View->Progress and post the
> names of the validators that seem to be long running when you have this
> problem? This might help us narrow down which validators are causing the
> problems.
> Cameron
Chris Rose
(780) 577-8433
crose@planetci.com
FUDForum. Page generated in 0.04817 seconds
