Home » Archived » BIRT » BIRT 2.1.2 and MAXIMO 7.1.4 : org.xml.sax.SAXParseException: Premature end of file.
icon9.gif  BIRT 2.1.2 and MAXIMO 7.1.4 : org.xml.sax.SAXParseException: Premature end of file. [message #1298936] Wed, 16 April 2014 12:09 Go to next message
Hi everyone.
I'm having a strange problem with one machine in our environment(with windows 8.1 and IE11) that when i try to run (preview) any Birt report the exception "org.xml.sax.SAXParseException: Premature end of file" is raised. I can't view the loading bar neither. All the other client machines (all with windows 7 and IE11) can run the reports (so its not a problem of xml). Also, i can direct print the report using a java applet in this machine.
We are using BIRT 2.1.2 because its the last supported version for our maximo 7.1.1.4.
We are currently migrating to MAXIMO 7.5 with a newer version of BIRT, but this is not an option for the current year.
With Firefox and Chrome, since i remember, the same exception is raised, but that browsers are not an option in our network.
Anyway to debug this or anyone with the same problem?
Thank You for your time.
Re: BIRT 2.1.2 and MAXIMO 7.1.4 : org.xml.sax.SAXParseException: Premature end of file. [message #1724945 is a reply to message #1298936] Sat, 27 February 2016 08:37 Go to previous messageGo to next message
hi Paulo
could you try commenting out lines 668 and 669 of webcontent/birt/ajax/lib/prototype.js
i think this may help
check in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=310512#c6
cheers Smile
Re: BIRT 2.1.2 and MAXIMO 7.1.4 : org.xml.sax.SAXParseException: Premature end of file. [message #1834262 is a reply to message #1724945] Fri, 06 November 2020 03:01 Go to previous message
I also encountered this problem. Maximo7.1.0.0 will report this error when using Birt on IE11 of Windows 10 system. However, there is no problem with IE11 on Windows 7 system and it can be used normally.
I can't solve the problem by commenting 668 lines above.
Previous Topic:Expression always returns true
Next Topic:Birt - Insert Dynamic text box with script
Current Time: Tue Mar 25 09:04:34 EDT 2025
Powered by FUDForum. Page generated in 0.03653 seconds
