Re: Problem with the demo setup script [message #1834 is a reply to message #1798] |
Mon, 26 February 2007 16:47 |
Marcin Okraszewski Messages: 32 Registered: July 2009 |
Member |
On Friday (Feb 23), we have released next milestone. We probably won't
support the setup script any more but use the Europa (Eclipse 3.3)
update site.
http://www.eclipse.org/projects/europa.php
Note, it may mean that Corona no longer works on Eclipse 3.2, but I
think it still should.
Marcin Okraszewski
Bryan Hunt napisał(a):
> And here is the next problem. The setupCorona.*.plutins.txt is not
> compatible with OS X. Whe the files get untar'd, the Eclipse.app
> directory is not fully populated on the server install, and the eclipse
> link in the root directory (on both the client and server install) does
> not point to the binary inside the Eclipse.app directory.
> Here is the workadound:
> cd install_client/eclipse
> rm eclipse
> ln -s Eclipse.app/Contents/MacOS/eclipse .
> cd ../install_server/eclipse
> rmdir Eclipse.app
> rm eclipse
> cp -R ../../install_client/eclipse/Eclipse.app .
> Bryan
> On 2007-02-09 16:35:47 -0600, Bryan Hunt <bhunt@mac.com> said:
>> I just found a second problem ... in the <target
>> name="load.mac.properties" ...> unpack.eclipse.task.prefix is set to
>> "untar.eclipse" which should be "untar"
>> Bryan
>> On 2007-02-09 16:16:31 -0600, Bryan Hunt <bhunt@mac.com> said:
>>> The demo script does not work properly on OS X. The problem is with
>>> the os conditionals. On OS X, both <os family="mac"> and <os
>>> family="unix"> evaluate to true. The result is that WTP for linux is
>>> downloaded instead of WTP for OS X. I worked around the problem by
>>> deleting the condition <os family="unix">.
>>> Bryan
FUDForum. Page generated in 0.03885 seconds
