Re: How to load resources stored in a plug-in ? [message #1312690 is a reply to message #1297453] |
Thu, 24 April 2014 12:47 |
The contract to for setting the context of the ResourceSet is Object but
what it needs is a IJavaElement or a classloader to load classes.
This is how we do it in the StandaloneBuilder shipped with Xtext's maven
support.
def protected void installTypeProvider(Iterable<String> classPathRoots,
XtextResourceSet resSet,
IndexedJvmTypeAccess typeAccess) {
val classLoader = createURLClassLoader(classPathRoots)
new ClasspathTypeProvider(classLoader, resSet, typeAccess)
resSet.setClasspathURIContext(classLoader);
def private URLClassLoader createURLClassLoader(Iterable<String>
classPathEntries) {
val classPathUrls = classPathEntries.map[str|new
File(str).toURI().toURL()]
return new URLClassLoader(classPathUrls)
Holger
On 15.04.14 19:41, Gregoire Dupe wrote:
> Hello,
> I have an XText grammar referring to a java classes. I've tried to use
> JvmType and JvmTypeReference.
> For my existing Ecore model "MyDsl", here is bellow my XText grammar :
> grammar com.myCompany.myapp.metamodel.xtext.MyDsl with
> org.eclipse.xtext.xbase.Xbase
> import "http://www.eclipse.org/xtext/common/JavaVMTypes" as jvmTypes
> import "http://www.myCompany.com/myapp/myDsl/0.1/myDsl" import
> "http://www.eclipse.org/emf/2002/Ecore" as ecore
> Action returns Action:
> {Action}
> 'Action'
> name=ID
> ('javaClassName' javaClassName=QualifiedName)?
> ('javaClass'
> javaClassJvmType=[jvmTypes::JvmType|QualifiedName])?
> ('javaClassR' javaClassTypeRef=JvmTypeReference)?
> Here is a sample of an MyDsl file conforming to my grammar:
> Action MyAction {
> javaClass com.mycompany.myapp.tests.internal.sample1.MyAction
> javaClassR com.mycompany.myapp.tests.internal.sample1.MyAction
> The XText editor resolves the reference to the Java class, hyperlink
> navigation is possible by "ctrl + left click".
> I'm trying to load an XText resource (conforming to the previous
> grammar) embedded in a plug-in with the following code :
> private static ClassLoader getClassLoader() throws ClassNotFoundException {
> Bundle bundle = Activator.getDefault().getBundle();
> // Activator is the activator class of the bundle containing the MyDsl
> file.
> Class<?> objectClass = bundle.loadClass("java.lang.Object");
> return objectClass.getClassLoader();
> public Resource loadXtextResouce() throws Exception {
> WorkflowStandaloneSetup wfStandaloneSetup = new
> WorkflowStandaloneSetup();
> Injector injector =
> wfStandaloneSetup.createInjectorAndDoEMFRegistration();
> XtextResourceSet resourceSet =
> injector.getInstance(XtextResourceSet.class);
> ClassLoader classLoader = getClassLoader();
> IJvmTypeProvider.Factory classpathTypeProviderFactory = new
> ClasspathTypeProviderFactory(classLoader);
> IJvmTypeProvider createTypeProvider =
> classpathTypeProviderFactory.createTypeProvider(resourceSet);
> resourceSet.setClasspathURIContext(createTypeProvider);
> resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL,
> Boolean.TRUE);
> URI uri =
> URI.createURI("platform:/plugin/com.mycompany.myapp.tests/model/myWorkflow1.workflow");
> return resourceSet.getResource(uri, true);
> My problem is that my action references to:
> - An instance of JvmVoidImplCustom through the reference
> 'javaClassJvmType'
> - Null through the reference 'javaClassTypeRef'
> Notice that the referred class is embedded in the same plug-in than the
> MyDsl file.
> I assume that my XTextResourceSet is not initialized properly. Can
> anybody explain how to initialize an XTextResouceSet to be able to load
> resources stored in a plug-in?
> Regards,
> Grégoire
Re: How to load resources stored in a plug-in ? [message #1312691 is a reply to message #1297453] |
support.
classPathEntries) {
Holger
> Hello,
> {Action}
> 'Action'
> name=ID
> ('javaClass'
> Action MyAction {
> file.
> Injector injector =
> Boolean.TRUE);
> URI uri =
> 'javaClassJvmType'
> MyDsl file.
> Regards,
> Grégoire
FUDForum. Page generated in 0.03332 seconds
