Home » Newcomers » Newcomers » redirect eclipse console to file
redirect eclipse console to file [message #217932] Mon, 25 June 2007 22:58 Go to next message
Originally posted by: go.away.com
hi-
i made a batch file called rundebug.bat
this is what i start eclipse with.
i'd like it to go to a file in the c:/eclipse directory.
something like console.txt
i am using windows xp.
can someone please share the line in the batch
file that will work. i tried a couple and
it starts to capture information but not the actual
println or print statements from my groovy scripting
program.
i am recursing lots of directories and the console
buffer gets too full. i need to check for certain error
messages using a find next feature on a text editor.
so i can go to the error message, read what file
and directory, and go preview what went wrong.
i am quite certain the program works. i just cant
redirect! it was ok for 83 files [console] but now were talking
800 :-)
it would be a huge help.
thanks,
jim
Re: redirect eclipse console to file [message #217947 is a reply to message #217932] Mon, 25 June 2007 23:05 Go to previous messageGo to next message
3rdshiftcoder wrote:
> hi-
> program.
> 800 :-)
> thanks,
> jim
I don't know if you can re-direct Eclipse output. Is this a Java
program? If so, perhaps you should try running it from the CMD prompt in
Windows and then re-direct the output there the normal way (>
file.out). Hope this helps. Mark Dexter
Re: redirect eclipse console to file [message #217954 is a reply to message #217947] Mon, 25 June 2007 23:15 Go to previous messageGo to next message
> I don't know if you can re-direct Eclipse output. Is this a Java program?
> If so, perhaps you should try running it from the CMD prompt in Windows
> and then re-direct the output there the normal way (> file.out). Hope this
> helps. Mark Dexter
mark -
eclipse thinks of everything .
i just found it.
it is under common tab in the launch configuration window.
thanks very much,
jim
Re: redirect eclipse console to file [message #987360 is a reply to message #217932] Mon, 26 November 2012 04:56 Go to previous message
I understood how to redirect the console text into a log/text file under eclipse,but I want to read a file and print it on eclipse console window
How is it possible..Please help!!
Previous Topic:Accidentally deleted files
Next Topic:Use UISynchronize via Depenency Injection
Current Time: Sun Oct 26 06:56:08 EDT 2025
Powered by FUDForum. Page generated in 0.10924 seconds
