Re: Ocl question- check string is an integer similar to Integer.parseInt(myString)? [message #217480 is a reply to message #217449] |
Fri, 06 February 2009 13:31 |
Originally posted by: cdamus.zeligsoft.com
Hi, Achilleas,
Try this:
not self.value.toInteger().oclIsInvalid()
This should check that conversion from String to Integer is feasible.
cW
Achilleas wrote:
> I would like to ask if there is any way to check if a String is an
> Integer using an Ocl constraint.
> For example in java you can do something like:
> 1. Integer.parseInt(myString) and catch the exception or 2. boolean
> isInteger = Pattern.matches("^\d*$", myString)
> Is there any way to perform something similar to the above in OCL?
> I tried to use something like self.value.oclIsTypeOf(Integer) but the
> oclIsTypeOf property deals with the direct type of an object.
> e.g. context Person
> inv: self.oclIsTypeOf( Person ) -- is true
> inv: self.oclIsTypeOf( Company) -- is false
> I tried to use something like self.value.oclIsKindOf(Integer) but the
> oclIsKindOf property determines whether value is either the direct type
> or one of the supertypes of an object.
> Any suggestions how this can be done?
> Achilleas
FUDForum. Page generated in 0.04480 seconds
