| Replacing One Class With Another [message #217345] |
Fri, 22 June 2007 04:19  |
Originally posted by: hal.thresholddigital.com
I have a number of classes that used the class DataTables. I copied
DataTables and named the copy DataCore since it was handling a lot of data
tracking other than the tables it originally was dealing with. When I
finish with DataCore, I'd like to be able to tell all the other
classes, "Use DataCore now instead of DataTables." Is there a way to
replace one class with another by refactoring?
I figure I can copy DataTables to another package, open the original
DataTables and DataCore, copy the entire contents of DataCore to inside
DataTables, then use CTRL-F to rename all references in the text from
DataCore to DataTables, save it, then rename it through refactoring. That
seems a round about way to do it.
I'd rather be able to somehow just have all references to DataTables in all
classes (other than DataTables) changed to DataCore. Is that possible?
Thanks!
Hal
| Re: Replacing One Class With Another [message #217360 is a reply to message #217345] |
Fri, 22 June 2007 05:00  |
I don't know, if there is a better way, but this works:
1. Create your own class DataTable in your project, in the same Package
as the original.
2. Copy the code of the original into this class.
3. Rename the class to DataCore, using the Rename-Refactoring.
4. Change the package name or move the class to another package.
Greetings,
Michael
FUDForum. Page generated in 0.08522 seconds
