Home » Language IDEs » C / C++ IDE (CDT) » Debug Hello World Tutorial - no work - help
Debug Hello World Tutorial - no work - help [message #217259] Tue, 10 June 2008 23:42 Go to next message
Originally posted by: markg.vpieng.com
I am using
Eclipse Platform version 3.3.2 Build Id: M20080221-1800
CDT = 4.0.3.200802251018 Build Id: 200802251018
gdb 6.8.0.20080328-cvs(cygwin-special)
Window XP
cygwin
I can build and execute the hello tutorial, but when I go use the debugger I
get the below info.
What am I misunderstanding or not setting up properly from the tutorial?
Mark
Launching HelloWorld Debug( Time of error: June 10, 2008 9:38:14 PM MDT)
Reason: Exec error: Launching failed
<<Details
Error creating sesion
!ENTRY org.eclipse.cdt.debug.mi.core 4 150 2008-06-10 21:03:45.541
!MESSAGE Error creating session
!STACK 0
java.io.IOException: Exec error:Launching failed
at org.eclipse.cdt.utils.spawner.Spawner.exec(Spawner.java:243)
at org.eclipse.cdt.utils.spawner.Spawner.<init>(Spawner.java:57)
at org.eclipse.cdt.utils.spawner.Spawner.<init>(Spawner.java:85)
at org.eclipse.cdt.utils.spawner.Spawner.<init>(Spawner.java:77)
org.eclipse.cdt.utils.spawner.ProcessFactory.exec(ProcessFac tory.java:59)
org.eclipse.cdt.debug.mi.core.MIProcessAdapter.getGDBProcess (MIProcessAdapter.java:52)
org.eclipse.cdt.debug.mi.core.MIProcessAdapter.<init>(MIProcessAdapter.java:39)
org.eclipse.cdt.debug.mi.core.CygwinMIProcessAdapter.<init>(CygwinMIProcessAdapter.java:31)
org.eclipse.cdt.debug.mi.core.command.factories.win32.Cygwin CommandFactory.createMIProcess(CygwinCommandFactory.java:54)
at org.eclipse.cdt.debug.mi.core.MIPlugin.createSession(MIPlugi n.java:448)
org.eclipse.cdt.debug.mi.core.AbstractGDBCDIDebugger.createG DBSession(AbstractGDBCDIDebugger.java:109)
org.eclipse.cdt.debug.mi.core.AbstractGDBCDIDebugger.createS ession(AbstractGDBCDIDebugger.java:66)
org.eclipse.cdt.launch.internal.LocalCDILaunchDelegate.launc hDebugSession(LocalCDILaunchDelegate.java:314)
org.eclipse.cdt.launch.internal.LocalCDILaunchDelegate.creat eCDISession(LocalCDILaunchDelegate.java:439)
org.eclipse.cdt.launch.internal.LocalCDILaunchDelegate.launc hLocalDebugSession(LocalCDILaunchDelegate.java:140)
org.eclipse.cdt.launch.internal.LocalCDILaunchDelegate.launc hDebugger(LocalCDILaunchDelegate.java:107)
org.eclipse.cdt.launch.internal.LocalCDILaunchDelegate.launc h(LocalCDILaunchDelegate.java:67)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:759)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
!SUBENTRY 1 org.eclipse.cdt.debug.mi.core 4 150 2008-06-10 21:03:45.541
!MESSAGE Exec error:Launching failed
!STACK 0
from the log file
!STACK 0
!STACK 0
Re: Debug Hello World Tutorial - no work - help [message #217301 is a reply to message #217259] Thu, 12 June 2008 02:38 Go to previous messageGo to next message
I had a very similar problem and got the following fix for the debug
dialog from Derek:
In the "Startup" tab put "b main" into the "Initialization commands"
field. This sets a breakpoint on main. Next, put "continue" into the "Run
commands" field.
This did a great job in my case. Hope it does the same for you.
Robert
Re: Debug Hello World Tutorial - no work - help [message #217348 is a reply to message #217259] Thu, 12 June 2008 10:02 Go to previous message
thunder2007 wrote:
> Hello,
> I am using
> Window XP
> cygwin
> get the below info.
> Mark
> <<Details
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> from the log file
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
This looks like gdb is not in the system PATH.
Either configure the environment so that gdb is found or enter an
absolute path to the gdb executable in the launch configuration.
HTH
Anton Leherbauer
Wind River CDT Team, Austria
Previous Topic:Eclipse with Cygwin - Troublesome Exe
Next Topic:linking between html files in different help plugin jar file
Current Time: Sun Nov 02 21:34:02 EST 2025
Powered by FUDForum. Page generated in 0.03405 seconds
