Re: GMF/Recipes: Reorder... [message #218946 is a reply to message #217066] |
Mon, 16 February 2009 14:05  |
Marcel Bootsma Messages: 11 Registered: July 2009 |
I solved this problem.
The eraseLayoutTargetFeedback method should be called during execution of
the reposition commmand.
Finaly because the eraseLayoutTargetFeedback method is protected you
should override it in the CustomCompartmentEditPolicy.
A reference to policy the is needed in the
CompartmentRepositioneObjectCommand.
Implementing this on the code from the GMF/Recipes results in:
______________________________________________
public class CompartmentEditPolicy
extends org.eclipse.gef.editpolicies.FlowLayoutEditPolicy
private EStructuralFeature feature = null;
protected Command createAddCommand(EditPart child, EditPart after) {
int index = getHost().getChildren().indexOf(after);
TransactionalEditingDomain editingDomain = ((IGraphicalEditPart)
getHost()).getEditingDomain();
AddCommand command = new AddCommand(editingDomain, new
EObjectAdapter((View)getHost().getModel()),
new EObjectAdapter((View)child.getModel()), index);
return new ICommandProxy(command);
protected EditPolicy createChildEditPolicy(EditPart child) {
ResizableEditPolicyEx policy = new ResizableEditPolicyEx();
policy.setResizeDirections(0);
return policy;
protected Command createMoveChildCommand(EditPart child, EditPart after)
int newIndex;
int displacement;
int childIndex = getHost().getChildren().indexOf(child);
int afterIndex = getHost().getChildren().indexOf(after);
if(afterIndex == -1) {
newIndex = getHost().getChildren().size()-1;
displacement = newIndex - childIndex;
} else {
newIndex = afterIndex;
displacement = afterIndex - childIndex;
if (childIndex <= afterIndex) {
newIndex--;
displacement--;
* Added reference to this policy to enable calling of
* myEraseLayoutTargetFeedback from command
RepositionEObjectCommand command = new
CompartmentRepositionEObjectCommand(child, editingDomain, "",
(EList)((View)child.getParent().getModel()).getElement().eGe t(feature),
((View)child.getModel()).getElement(),
displacement, newIndex,
this);
* these 2 lines can be removed
//TODO ev. reintroduce target feedback (actual problem: line is not
deleted after dropping)
//eraseLayoutTargetFeedback(null);
protected Command getCreateCommand(CreateRequest request) {
return null;
protected Command getDeleteDependantCommand(Request request) {
return null;
protected Command getOrphanChildrenCommand(Request request) {
return null;
* @param feature has to be an EList
public CompartmentEditPolicy(EStructuralFeature feature) {
super();
this.feature = feature;
* Will be called from Repostion Command execution
* to remove feedback line
public void myEraseLayoutTargetFeedback() {
super.eraseLayoutTargetFeedback(null);
public class CompartmentRepositionEObjectCommand extends
RepositionEObjectCommand {
EditPart childToMove = null;
int newIndex = 0;
CustomCompartmentEditPolicy policy;
public CompartmentRepositionEObjectCommand(
TransactionalEditingDomain editingDomain, String label,
EList elements, EObject element, int displacement) {
super(editingDomain, label, elements, element, displacement);
* Added a reference to the creating policy to enalbe calling
* from command execution
public CompartmentRepositionEObjectCommand(EditPart childToMove,
EList elements, EObject element, int displacement, int newIndex,
this.childToMove = childToMove;
this.newIndex = newIndex;
public CommandResult doExecuteWithResult(
IProgressMonitor progressMonitor, IAdaptable info)
throws ExecutionException {
CommandResult rs = super.doExecuteWithResult(progressMonitor, info);
* This line will erase the feedback line
policy.eraseLayoutTargetFeedback(null);
EditPart compartment = childToMove.getParent();
ViewUtil.repositionChildAt((View)compartment.getModel(),
(View)childToMove.getModel(), newIndex);
compartment.refresh();
return rs;
FUDForum. Page generated in 0.02336 seconds
