Home » Newcomers » Newcomers » Reading files within workspace
Reading files within workspace [message #216895] Wed, 20 June 2007 00:54 Go to next message
I am working on an RCP project, and plan to have a very extensive GUI.
The scenario I have is: A user fires up the project and sees a dialog
box that asks him/her to select a profile. What is the best way to
store a bunch of profile settings that the program can read on startup
based on selection of the user?
I am thinking of storing a file within the workspace and reading it. I
can read the file by setting appropriate working directory thru Eclipse
Run settings, but that requires me to be running the project from
within Eclipse. What should I do to make this independent?
-- Hamid
Re: Reading files within workspace [message #217392 is a reply to message #216895] Fri, 22 June 2007 08:04 Go to previous message
Hamid,
It sounds like Plugin.getStateLocation should be used (or
Plugin.getPreferences).
Syed Tirmizi wrote:
> Eclipse Run settings, but that requires me to be running the project
> from within Eclipse. What should I do to make this independent?
> -- Hamid
Previous Topic:java.lang.OutOfMemoryError: Java heap space
Next Topic:Goober question: no updates work because of dependency failures
Current Time: Sun Jul 27 12:49:32 EDT 2025
Powered by FUDForum. Page generated in 0.08176 seconds
