JDBC vs JNDI [message #216713] |
Fri, 02 February 2007 11:18  |
I want to be able to preview same report in Designer
and (render it) in application server. How can I achieve
such effect? I use JDBC properties in the Designer,
but I will have to use JNDI string in appserver. How will
it work, if both settings (JNDI, JDBC) are specified?
Do you have best practices / tips?
Thank you
Leos
Re: JDBC vs JNDI [message #217120 is a reply to message #217031] |
Tue, 06 February 2007 11:07  |
Leos,
Thanks for posting this. I will talk with the developers to review.
Jason
"Leos Literak" <literakl@centrum.cz> wrote in message
news:eq9ca6$si4$1@utils.eclipse.org...
> Thanks Jason, it really works this way. Unfortunatelly
> I have not found this information when searching BIRT web
> or in the designer. So I written small FAQ entry:
> http://wiki.eclipse.org/index.php/BIRT/FAQ/Data_Access#Suppo rted_Data_Sources
> Could you please review it, I am not native speaker.
> Leos
> Jason Weathersby napsal(a):
>> The JNDI connection will be attempted first.
>> If it fails the JDBC connection will be used.
>> Jason
>> news:epvo9d$ocj$1@utils.eclipse.org...
>>> Hi,
>>> Thank you
>>> Leos
FUDForum. Page generated in 0.08621 seconds
