Home » Modeling » GMF (Graphical Modeling Framework) » How to call own layoutProvider from "Arrange All"
Re: How to call own layoutProvider from "Arrange All" [message #216644 is a reply to message #216637] |
Thu, 29 January 2009 09:15 |
Martin Jacob Messages: 191 Registered: July 2009 |
Hi Mariot,
the package and class name in plugin.xml is correct. (I just delete some parts for posting it here)
And yes u are right system.out is evil, its just a old habit from C programming....
Now I used the debugger but got the same result. My layout provider will not be called :(
Any other suggestions?
Cheers, Martin
Mariot Chauvin wrote, On 29.01.2009 09:49:
> Hi Martin,
> It seems to me that your class value in plugin.xml is not the right one :
> <layoutProvider class="ui.diagram.providers.LayoutProvider">
> should be :
> <layoutProvider class="yourcompany.yourpackage.PscViewerLayoutProvider">
> BTW debugging with system.out is evil :P, why you do not simply add breakpoints ?
> Regards,
> Mariot
> Martin Jacob a écrit :
>> Hi everyone,
>> I was searching on the mailing list but did not find a sufficient
>> answer fop my problem.
>> I want to use my own layoutProvider while using the already existing
>> menu item "Arrange All".
>> I did the following things so far:
>> 1. Add the extension point, see below:
>> <extension name="PSC Viewer Layout Provider"
>> point="org.eclipse.gmf.runtime.diagram.ui.layoutProviders">
>> <Priority name="Highest">
>> </Priority>
>> </layoutProvider>
>> </extension>
>> 2. Create a class derived from
>> org.eclipse.gmf.runtime.diagram.ui.services.layout.AbstractL ayoutNodeProvider
>> public class PscViewerLayoutProvider extends AbstractLayoutNodeProvider {
>> public Runnable layoutLayoutNodes(List layoutNodes,
>> boolean offsetFromBoundingBox, IAdaptable layoutHint) {
>> System.out.println("layoutNodes: "+layoutNodes.toString());
>> System.out.println("offsetFromBoundingBox: "+offsetFromBoundingBox);
>> System.out.println("layoutHint: "+layoutHint.toString());
>> return null;
>> public boolean provides(IOperation operation) {
>> System.out.println(""+operation.toString());
>> if (operation instanceof
>> org.eclipse.gmf.runtime.diagram.ui.services.layout.ILayoutNo deOperation) {
>> System.out.println("true");
>> return true;
>> System.out.println("false");
>> return false;
>> I would expect to see at least the println while calling "Arrange All".
>> But I don't see any thing at System.out!
>> Does any one could please give me a hint how to solve the problem?
>> Thanks, Martin
Re: How to call own layoutProvider from "Arrange All" [message #216652 is a reply to message #216644] |
Thu, 29 January 2009 09:46 |
Mariot Chauvin Messages: 174 Registered: July 2009 |
Martin,
Is there another layout defined with the highest priority ?
If you externalize your layout in a plug-in check that you plug-in started without errors ("Show View" -> "Other" -> "Plug-in Registry").
If you install GMF sdk there is also an example of layout provider ("New" -> "Example/ GMF PLugins/Square layout provider") to compare.
Mariot
> Hi Mariot,
> programming....
> not be called :(
> Cheers, Martin
>> Hi Martin,
>> should be :
>> breakpoints ?
>> Regards,
>> Mariot
>>> Hi everyone,
>>> </Priority>
>>> </layoutProvider>
>>> </extension>
>>> return null;
>>> return true;
>>> return false;
>>> Thanks, Martin
Re: How to call own layoutProvider from "Arrange All" [message #216658 is a reply to message #216652] |
Thu, 29 January 2009 10:08 |
Hi Mariot,
thanks for the hint!
In fact the plugin could not be loaded because a ClassNotFoundException was thrown...
Now I copied the package name and class name to the extension point in plugin.xml. And it works! There must be a typo some where...
Regards, Martin
Mariot Chauvin wrote, On 29.01.2009 10:46:
> Martin,
> Regards,
> Mariot
>> Hi Mariot,
>> programming....
>> not be called :(
>> Cheers, Martin
>>> Hi Martin,
>>> should be :
>>> breakpoints ?
>>> Regards,
>>> Mariot
>>>> Hi everyone,
>>>> </Priority>
>>>> </layoutProvider>
>>>> </extension>
>>>> return null;
>>>> return true;
>>>> return false;
>>>> Thanks, Martin
Current Time: Fri Apr 26 12:50:10 GMT 2024
Powered by FUDForum. Page generated in 0.03479 seconds
