Insert node on the point where I clicked [message #216537] |
Fri, 19 May 2006 13:38 |
Originally posted by: alissonbn.frb.br
hi, guys! I'm making my first project in GEF, so I'm a newbie here. I took as point of start the schema editor example, that you can find in the GEF homepage.
The project is almost ready, but I got a problem. When I add a new node, it appears in the top-left corner. I would like it to appear in the point where the mouse clicked. can someone help me?
thanks in advance,
Alisson
Re: Insert node on the point where I clicked [message #216789 is a reply to message #216537] |
Wed, 24 May 2006 13:20 |
Originally posted by: cmahoney.ca.ibm.com
Alisson,
Are you adding the new node from a palette? Are you using GEF's
CreationTool?
- Cherie
"Alisson" <alissonbn@frb.br> wrote in message
news:28869837.1148045962861.JavaMail.root@cp1.javalobby.org...
homepage.
> thanks in advance,
> Alisson
Re: Insert node on the point where I clicked [message #216830 is a reply to message #216789] |
Thu, 25 May 2006 11:31 |
Originally posted by: eclipse.chris-lott.org
The out-of-the-box behavior of the database table schema editor example is
to place newly added tables at 0,0. I considered this a bug. If we were
in school I think this would be marked "left as an exercise for the
reader" :-)
Anyhow I'm not in school anymore, so here's how I fixed it:
1. TableAddCommand needs a private field of type Point, and a setter
method:
private Point location;
* Sets the desired location of the new item
* @param location
* the location to use
public void setLocation(Point location)
this.location = location;
2. The execute() method of TableAddCommand needs to use the Point data to
set the bounds of the newly added table object:
Line 43:
// -1 for width, height means "resize to accomodate contents"
this.table.modifyBounds(new Rectangle(location.x, location.y, -1, -1));
3. SchemaContainerEditPolicy.getCreateCommand has to pass the point
(location) on to the table add command object:
Line 55: tableAddCommand.setLocation(location);
Hope this helps.
chris...
FUDForum. Page generated in 0.03036 seconds
