3.3 / Ganymed: can't create Tomcat 5.5 server configuration [message #216066] |
Wed, 25 June 2008 18:20 |
Originally posted by: onlineguyse.gmx.de
I just downloaded Ganymed in its JEE package (32 bit) and tried to
create a new server configuration for a local Tomcat 5.5. The problem is
that I cannot get past the window labeled "New Server" because the 5.0
and the 5.5 configurations aren't selectable. The error at the top of
the window reads:"Cannot create a server using the selected type". Any
idea what causes this?
Maik
Re: 3.3 / Ganymed: can't create Tomcat 5.5 server configuration [message #216185 is a reply to message #216160] |
Thu, 26 June 2008 16:22 |
Hi Larry,
it seemed to be a workspace-related problem, I can create all Tomcat
configurations in a new workspace. To answer your question: a 6.0 Tomcat
configuration was possible. Thank you for your effort.
Maik
Larry Isaacs schrieb:
> Maik wrote:
>> is that I cannot get past the window labeled "New Server" because the
>> 5.0 and the 5.5 configurations aren't selectable. The error at the top
>> of the window reads:"Cannot create a server using the selected type".
>> Any idea what causes this?
>> Regards,
>> Maik
> Is this happening, or does this happen, in a new workspace? Does the
> Tomcat v6.0 Server selection allow you to click Next?
> Cheers,
> Larry
Re: 3.3 / Ganymed: can't create Tomcat 5.5 server configuration [message #216208 is a reply to message #216185] |
Thu, 26 June 2008 17:41 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
I would guess that there are existing Tomcat runtimes defined in the
problem workspace and something amiss with them causes problems when
trying to create a new server from those runtimes. If the problem
workspace is important to you, you could try recreating those Tomcat
runtimes and see if that improves the behavior when trying to create a
new server.
Larry
Maik wrote:
> Hi Larry,
> Maik
>> Maik wrote:
>>> Hi,
>>> top of the window reads:"Cannot create a server using the selected
>>> type". Any idea what causes this?
>>> Regards,
>>> Maik
>> Cheers,
>> Larry
FUDForum. Page generated in 0.03068 seconds
