Arrow icon in the Java editor [message #215744] |
Thu, 14 June 2007 14:37 |
Originally posted by: gd.bill.com
Stupid question: I see a yellow arrow in the margin of the Java editor.
Sometimes it obscures a breakpoint marker, for example. Could someone tell
me what this icon indicates, or, better yet, where in the help I might find
an answer to this question (I've gotten nowhere finding anything about this
in the help).
Any info appreciated.
TIA
Greg Safford
Re: Arrow icon in the Java editor [message #215759 is a reply to message #215744] |
Thu, 14 June 2007 14:44 |
Greg,
You mean the "yield sign" marker that indicates a warning in the Java
code? If you hover over it, it will tell you what it's for...
> in the help).
> TIA
> Greg Safford
Re: Arrow icon in the Java editor [message #215791 is a reply to message #215744] |
Thu, 14 June 2007 15:45 |
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> in the help).
Sounds like an instruction pointer. I.d. you have a debug process
running, and the arrow indicates where in the code you are. If the
process stops at a breakpoint, then it might be over the breakpoint
symbol. Hovering over the symbol will show you all markers in the margin.
H.
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGcWKse+7xMGD3itQRAlKPAJwPjbO9+SiAH6oc+H337WnCjjgkkQCf eEel
aL/oH9nrWtra8A3i0/EmdYs=
=j9Er
-----END PGP SIGNATURE-----
Re: Arrow icon in the Java editor [message #216290 is a reply to message #215744] |
Sat, 16 June 2007 03:05 |
> in the help).
If you open Help Contents and search for "icons" it returns several
pages that describe the various groups of icons. The one you're talking
about might be there. If you can't find it, post a small image of it and
I'm sure someone can identify it for you.
Hope this helps,
Eric
Re: Arrow icon in the Java editor [message #216720 is a reply to message #216290] |
Tue, 19 June 2007 17:13 |
Thanks much. In searching previously, I made the stupid error of forgetting
to change the scope to 'All', but now I see that you are right.
The yellow arrow is indeed the search results icon.
Greg
"Eric Rizzo" <eclipse5@rizzoweb.com> wrote in message
news:f4vk0v$i8m$1@build.eclipse.org...
>> tell me what this icon indicates, or, better yet, where in the help I
>> might find an answer to this question (I've gotten nowhere finding
>> anything about this in the help).
> If you open Help Contents and search for "icons" it returns several pages
> that describe the various groups of icons. The one you're talking about
> might be there. If you can't find it, post a small image of it and I'm
> Hope this helps,
> Eric
Re: Arrow icon in the Java editor [message #216728 is a reply to message #215759] |
Tue, 19 June 2007 17:16 |
Plausible, but turns out to be the search results marker.
Thanks for the suggestion.
Greg
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:f4rk81$fmq$2@build.eclipse.org...
> Greg,
>> TIA
>> Greg Safford
Re: Arrow icon in the Java editor [message #216736 is a reply to message #216584] |
Tue, 19 June 2007 17:18 |
You are correct Sir.
Thanks much.
Greg
"Carl Manaster" <manaster@pobox.com> wrote in message
news:d49876a1f6f6719b7060e195f9d6c7d0$1@www.eclipse.org...
> Hi, Greg,
> I think it's probably a search result indicator. If you do a multifile
> search, or a Find References, it gives you the list of results in the
> Search pane and it also puts a yellow arrow in the margin beside each
> found occurrence. It's easy to forget that you have an active search and
> so those arrows can seem to appear out of nowhere. To dismiss them, just
> close the Search pane.
> Peace,
> --Carl
Re: Arrow icon in the Java editor [message #216744 is a reply to message #215791] |
Tue, 19 June 2007 17:19 |
As it happens, the arrow is the search results pointer.
But I've run into the debug indicator as well. Thanks for the suggestion.
Greg
"Hendrik Maryns" <hendrik_maryns@despammed.com> wrote in message
news:f4rnou$oq9$1@build.eclipse.org...
> Hash: SHA1
>> tell
>> find
>> this
>> in the help).
> H.
> Hendrik Maryns
> http://aouw.org
> =j9Er
FUDForum. Page generated in 0.09279 seconds
