| Connection line visible at PolygonDecoration arrow point [message #215548] |
Thu, 04 May 2006 14:32  |
Originally posted by: ben.vitale.precipia.com
--------------080405060600040608000305
I've attached a screenshot of the behavior I'm about to describe.
I have a PolygonDecoration.TRIANGLE_TIP for my connection line target
decoration. If my connection line is of width 1, then the point of the
arrow looks perfect.
But if I set the connection width to a larger value (say, 8), then I can
start to see pieces of the connection line appear around the point of
the arrow. It is clear in the attached screenshot, where the arrow and
the connection line are different colors.
The only solution I can think of is..
1) Instead of a PolygonDecoration, use a figure with an endpointlocator
which is a square and then add a triangle-shaped child figure. The
square would be opaque (to cover the pieces of connection line that are
showing up), and the triangle would mimick the arrow decoration.
Are there other suggestions?
Ben
Content-Type: image/gif;
name="arrowhead.GIF"
Content-Disposition: inline;
filename="arrowhead.GIF"
R0lGODlhCAF1APcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A
/wD//////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAz AAAzMwAzZgAz
mQAzzAAz/wBmAABmMwBmZgBmmQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDM AADMMwDMZgDM
mQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD//zMAADMAMzMAZjMAmTMAzDMA/zMz ADMzMzMzZjMz
mTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZMzOZZjOZmTOZzDOZ/zPM ADPMMzPMZjPM
mTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYAmWYAzGYA/2Yz AGYzM2YzZmYz
mWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ/2bM AGbMM2bMZmbM
mWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kz AJkzM5kzZpkz
mZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nM AJnMM5nMZpnM
mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wz AMwzM8wzZswz
mcwzzMwz/8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zM AMzMM8zMZszM
mczMzMzM/8z/AMz/M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8z AP8zM/8zZv8z
mf8zzP8z//9mAP9mM/9mZv9mmf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///M AP/MM//MZv/M
mf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAAAIAXUAAAj/ AP8JHEiwoMGD
CBMqXMiwIUN8uSJKnAjMocWLGDNq3Mixo8ePIDNCnEiyYsiTKFOqXMmypcWR JCWadEmzps2b
OFfCjJlrZs6fQIMKxbkzps+hSJMqXdqwaEmmUKNKReqU4tSrWLOqrCpTq9ev YB1yjXg0rNmz
Wsf2RMu27VS1Zd3KnUuUZ1e6ePPShKu3r9+TfP8KHowxMOHDiA8aTswY8eLG kP8+jkwZ7+TK
mNtezsw57ObOoLN+Dk066ujSqJOeTs0a6OrWsG2+jg0bhe3buHPr3s27t+/f wG1PoT04VfDj
yJMrv+0nFfHBU5ZLny7dz/DngqlR386995Qp1LAX/+9OnrwfP+IJRy/Pfrn1 9IS1t58f/Ht4
+OPp6+fdHP/h9fsFiMJ7/sUnYID2FXiYcQfSd56CiAHYoHnXQWjghOQlaOGC GHbX34YRdkgd
gSD+sw0X2YkonYYgnhhDfioi92CJ1XARw4vQxXgciRtWg8ONOKao428sWkgN kDhUw+GQvX24
ISxIKhkik7rxCCGUN3KxDWPyUXlbkQoaAqSWkDHo5YDobShmlpVJOKSVBa4Z A4qVdTkkmP7J
SSdmZuropII23mgIaG52CCd+gcYwKGh2dohnei4KWlqfGM5YYKQxwJJaoQIe Kl6NQGqaWqMC
PooZNRUy5COQ97FGaYB/Ev+KQqoJHXljkrRxOp+np365EJYx4EobqfOZipmE aR4ELJnPvdqe
paRVeZAqY24pnq4e0gqaH7s5R5Ce+BHbnbGY9dYquP45y12soKlrW3joFoht ddqC9lsKWwC5
qILirgheau7iJumGAScHbbTBpbDvhvPuWG9nBeP2sH/9HkfusQaX+E/EvrHL 6HLegthwkxNz
NnK3JVbs3b+jUteqhRzndjBpJ5tbYs228cqZysCxbCRyF2NM3Xclpxezx6FN N4V1S79s4cg6
c8atckt/F7LGKjPhc2rJVT1FKk5rvLFvcSQLsMVMXy12QUzwFgcTsfXMtB9h r01QLrsxwUQu
sAX/7LXadh+USxy6xREH363x9nfdgRsUUdu3vR1Ra6/+3bhFEt2mt0StSUg0 3ZdfJBHhKBjO
eWqq2JbCC1aHntFEeu99emnVpICC7aC3debuvPeOAloo3CL88MQXb/zxyCev /PLMN+/889BH
L/30x/9+VvDbZK/99tx37/3335MG/vjklz9+NdVQox3wt5jv/vvZiw///PSj r771ZmFP//7b
y8///+Czn/rWd732AXB//jugArMnwPuxb4EIxMht5ALBCm6jgQPEX1j0lz1q TG1AqUiFBfsn
QdtQcIQKbCDYCJg/A3qwNyi01kUmeJYYLhCDA2ThBttXjfWkohodVEV0/2KY ERqaxYYpTJ/6
wMZEDYIFewyiRveq4YcRbsSIX0HiATGoClWE0IEF3MZ6tEjCIpowLGT8nwq7 +EXjPPA25oPj
9uSYPThSg0G5G8gE72gbsBVkglNzGuNykkYF5nCJIVyhE7+CvfVIkXx0rKNt 5mib1OXmZbex
JG4waUL5mO0fnwxKIQ84QCYmsonsqwYeyxfJbURykx0UDkE2KRD5pIqGWPzH Igk5yv8dkhps
PKUbC5i+9XwNFo/sXitf+a7tMShkt3lZFPV4xmnWcpc46aUvc5iKYJ4Sm1kJ nv3c1BwgUhIF
3GMmOrcnH2iecSCepKb14ikQbiFFm/z7pTATCf9OrIjTnC/MDSzOmc5Jaq+V upyVPA0iS4EY
0ZH/kM898Um/Q+6Tn6k0p/bU98FkLtOgklynDI2Yy4Tiz4jyCY9ERUnR/enz ov28yj+/t8qQ
FlSkrgTpQh36zp2aFJ6ynJpQWupSbl50mC1E3/eqQceP4hSOf3xnSUna0yj2 EShEzadFYZpR
8DUVpDY96CQJQs+fkvWqPNVgowbZkqwWtZRHjelUxCnC7/VRrDjN6VN7GtFK +vSaKGhVLiX2
E7dq1aj7lKtUxImCunLPkqrQXiA3qs6CBPKvoHwXZs3E1pUY9q2I5CoxhaO+ DtY0lo3Nnib3
GlglbeOZs9SsQGCL2S6b8fKzFd1qCJvTHMVGha5NSmb23NSlc0ortihDbkHK ahPcgvaOwuSt
b6Hyz/RZ5zZg854q+yhFdfJxQGGLJh7Dy9fLZtO583vpblPR266OsKQM5atF Gnpe9L5Pt4mU
rnshmFaGwJchtG2ufdOLX94idYdKrWB/F/LfhUD0JgMmMFxPqV9iavSAymWw fBnCXJdEOLeI
Za+IpwuSgAAAOw==
--------------080405060600040608000305--
| Re: Connection line visible at PolygonDecoration arrow point [message #215616 is a reply to message #215548] |
Fri, 05 May 2006 09:48  |
The best solution would be to not paint the line there, rather than erase
it. You could subclass polylineconnection and stop short of drawing the line
all the way, based on the decoration's needs. You could create an anchor
whichs returns a location further out, and then put the base of the triangle
at the end of the line instead of the tip.
"Ben Vitale" <ben.vitale@precipia.com> wrote in message
news:e3dhbi$234$1@utils.eclipse.org...
> Thanks
> Ben
FUDForum. Page generated in 0.05766 seconds
