Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215513 is a reply to message #215505] |
Mon, 16 June 2008 20:00 |
John J Barton wrote:
> In Version: 3.4.0
> Build id: I20080523-0100
> I get a popup error message and several stack traces in Error Log when
> I click on index.html in my project. Any ideas?
Is this a new installation with all of the right prerequisites? Are
you at least using Java5?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215537 is a reply to message #215529] |
Mon, 16 June 2008 20:42 |
>>> In Version: 3.4.0
>>> when I click on index.html in my project. Any ideas?
> I'm not sure which day I installed, maybe 5/28/2008.
> Sorry, prerequistes for what? I installed eclipse-SDK-3.4RC2-win32 and
> added j2ee 3.0.0 and wst 3.0.0
> Are you
> yes, 5.0
The download page should have a section labeled "Required
Prerequisites and Handy Extras" that links to the additional
downloads you'll need.
Nitin Dahyabhai
IBM Rational
_
Nitin Dahyabhai
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215599 is a reply to message #215561] |
Tue, 17 June 2008 14:31 |
>> Alternately you can just grab a pre-assembled Java EE package (the
>> " Eclipse IDE for Java EE Developers") from
>> http://www.eclipse.org/downloads/packages/ .
> Thanks, but I tried that first, but it does not have source or PDE so I
> can't use it.
John, you should be able to use the latest Eclipse 3.4 RC4 SDK, and
install the J2EE component as well as the Web Tools 3.0 components. I
believe there were some issues with the earlier Eclipse 3.4 RC2 and RC3
builds that didn't resolve all the required dependencies. In addition,
you can also select from the Ganymede update site to install, GMF, EMF,
and XSD Runtimes from the Modeling Project.
But I would try with a newer build, and as for the J2EE Developer
Version, you should be able to add the PDE package from Ganymede.
Dave
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215615 is a reply to message #215599] |
Tue, 17 June 2008 17:26 |
John J. Barton Messages: 311 Registered: July 2009 |
>> I can't use it.
Thanks David...are you suggesting that 3.4 RC2 will not upgrade to RC4?
But this would still not have the source correct? Using PDE without the
source isn't fun.
> Dave
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215639 is a reply to message #215615] |
Tue, 17 June 2008 19:31 |
>>> I can't use it.
I personally still just install a clean version. Old habits die hard,
but I think you have to have a special update site included in order for
it to detect that it needs to upgrade from RC 2 to RC 4.
> source isn't fun.
You can always get the source from the PDE website, and extract the ZIP
file into your dropins folder. Some distributions are including the SDK
as an update site as well.
Dave
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215670 is a reply to message #215662] |
Wed, 18 June 2008 00:28 |
You can get the Eclipse JEE developers edition, and then from within the
Ganymede update site, under Java Tools, add the Eclipse Plugin
Development Environment.
or
Download the Eclipse for Plugin / RCP Developers and then through the
ganymede update site, under Web Tools and Java EE install the select the
Eclipse XML Editors, Java EE Developers, Java Persistence, JavaScript
Developer Tools, Web Developer Tools and Web Page Editor.
That should get you everything in one environment.
Dave
FUDForum. Page generated in 0.04407 seconds
