RAP - Doesn't Start Application [message #1287246] |
Mon, 07 April 2014 15:18 |
Hi all,
I have the following problem: my scout applycation doesn't start in RAP mode.
When I start the server-side, the console show me the following messages:
!SESSION 2014-04-07 17:07:36.565 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_24
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=it_IT
Framework arguments: -product org.zeiss.mo.scout.CZVEDIController.server.product
Command-line arguments: -product org.zeiss.mo.scout.CZVEDIController.server.product -data C:\Projects\scout/../runtime-CZVEDIController-server-dev.product -dev file:C:/Projects/scout/.metadata/.plugins/org.eclipse.pde.core/CZVEDIController-server-dev.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.zeiss.mo.scout.CZVEDIController.server 1 0 2014-04-07 17:07:38.708
!MESSAGE org.zeiss.mo.scout.CZVEDIController.server.ServerApplication.start(ServerApplication.java:44) CZVEDIController server initialized
When I start the RAP-side, the console show me the following messages:
2014-04-07 17:07:56.880:INFO:oejs.Server:jetty-8.1.3.v20120522
2014-04-07 17:07:56.961:INFO:oejs.AbstractConnector:Started SelectChannelConnector@0.0.0.0:8082
But after that nothing happens.
I try to launch my application directly from IE, but IE return to me the message "Impossible show the web page".
I think that the problem is located on the config.ini of RAP or/and Server side, but this error escapes me.
I use "Eclipse Scout Juno 3.8"
Any suggestions or advices are appreciated. If you need other information not reported here, free to ask.
Thanks in advance
Attachment: img.png
(Size: 13.29KB, Downloaded 926 times)
[Updated on: Tue, 08 April 2014 10:43] Report message to a moderator
Re: RAP - Doesn't Start Application [message #1295435 is a reply to message #1295397] |
Mon, 14 April 2014 09:05 |
Thanks Claudio for your suggestion.
Now start but after logic return to me an error on web-page
Quote:Problem accessing /web. Reason:
oracle.jdbc.OracleDriver
and in the console report the following messages:
!ENTRY org.eclipse.scout.http.servletfilter 4 0 2014-04-14 10:57:47.084
!MESSAGE org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter.isValidUser(DataSourceSecurityFilter.java:168) Cannot SELECT user/pass.
!STACK 0
java.lang.ClassNotFoundException: oracle.jdbc.OracleDriver
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter.createJdbcDirectConnection(DataSourceSecurityFilter.java:222)
at org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter.isValidUser(DataSourceSecurityFilter.java:162)
at org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter.negotiate(DataSourceSecurityFilter.java:124)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.doFilter(AbstractChainableSecurityFilter.java:119)
at org.eclipse.scout.http.servletfilter.internal.FilterChainImpl.doFilter(FilterChainImpl.java:41)
at org.eclipse.scout.http.servletfilter.ServletFilterDelegate.delegateServiceMethod(ServletFilterDelegate.java:57)
at org.eclipse.scout.rt.ui.rap.internal.servletfilter.DelegateFilter.doFilter(DelegateFilter.java:48)
at org.eclipse.equinox.http.registry.internal.FilterManager$FilterWrapper.doFilter(FilterManager.java:173)
at org.eclipse.equinox.http.servlet.internal.FilterRegistration.doFilter(FilterRegistration.java:81)
at org.eclipse.equinox.http.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:35)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:132)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:386)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
at org.eclipse.jetty.server.Server.handle(Server.java:350)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:890)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:944)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:630)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
I use a "DataSourceSecurityFilter" with SQL to validate login and password.
If I understand correctly, the error message says me that the class "oracle.jdbc.OracleDriver" isn't defined in RAP context.
I need to check the configuration of RAP Client, correct?
FUDForum. Page generated in 0.03724 seconds
