Missing Sun facelet DTD URL [message #215265] |
Fri, 13 June 2008 13:08 |
<!DOCTYPE facelet-taglib PUBLIC
"-//Sun Microsystems, Inc.//DTD Facelet Taglib 1.0//EN"
"http://java.sun.com/dtd/facelet-taglib_1_0.dtd">
If I have the above header in foo.taglib.xml and on the third line, I
get a warning to the effect that
The file cannot be validated as the XML Schema
"http://java.sun.com/dtd/facelet-taglib_1_0.dtd" that is specified as
describing the syntax of the file cannot be located
where do I get the DTD and how do I stick Eclipse's nose into it so that
it recognizes it? Have I misspelled this DTD's name subtly and can't see
what's wrong? I know this URL doesn't exist, but neither can Sun find
anything that might help me based on the key words it fabricates from my
bad URL.
I got this URL out of a tutorial and suspect that its incorrectness is
at the root of other problems I have in this facelet exercise.
Russ Bateman
Re: Missing Sun facelet DTD URL [message #215272 is a reply to message #215265] |
Fri, 13 June 2008 13:20 |
Russ,
A quick google search turned up
http://www.mojavelinux.com/blog/archives/2006/01/eclipse_dtd _trick/
> that it recognizes it? Have I misspelled this DTD's name subtly and
> can't see what's wrong? I know this URL doesn't exist, but neither can
> Sun find anything that might help me based on the key words it
> fabricates from my bad URL.
> Russ Bateman
Re: Missing Sun facelet DTD URL [message #215280 is a reply to message #215272] |
Fri, 13 June 2008 13:23 |
Ed Merks wrote:
> Russ,
>> Thanks,
>> Russ Bateman
Hmmmm, yes, pretty helpful. I'll have to then see if I can find this
particular DTD given this useful information. I wonder if also, assuming
I can ever find this DTD, if there's not a place I could just simply
stick it in my project so it would always be there?
Best,
Russ
Re: Missing Sun facelet DTD URL [message #215296 is a reply to message #215280] |
Fri, 13 June 2008 13:36 |
Windofkeltia,
I suspect the XML catalog will be useful for that...
Windofkeltia wrote:
> Ed Merks wrote:
>> Russ,
>>> I get a warning to the effect that
>>> as describing the syntax of the file cannot be located
>>> can Sun find anything that might help me based on the key words it
>>> is at the root of other problems I have in this facelet exercise.
>>> Thanks,
>>> Russ Bateman
> assuming I can ever find this DTD, if there's not a place I could just
> simply stick it in my project so it would always be there?
> Best,
> Russ
FUDForum. Page generated in 0.03916 seconds
