Home » Modeling » Epsilon » Create connection between two classes
Create connection between two classes [message #1285670] Sat, 05 April 2014 17:45 Go to next message
I'm trying to create a GMF editor to create classes, attributes and association between two classes using a subset of the class diagram metamodel developed by OMG.
The problem is that I can't create a connection between two properties (actually, an association).
Here is the metamodel:
@gmf(foo="bar")
@namespace(uri="model", prefix="model")
package model;
@gmf.diagram(foo="bar")
class Model {
  val Class[*] classes;
abstract class Classifier {
@gmf.node(label="name", figure="rectangle", label.icon="false")
class Class extends Classifier {
  @gmf.compartment(layout="list", collapsible="false")
  val Attribute[*] attributes;
  @gmf.affixed
  val Property[*] properties;
  attr String name;
class Attribute {
  attr String name;
abstract class MultiplicityElement {
  attr int lower;
  attr int upper;
class Association extends RelationShip, Classifier {
@gmf.node(figure="rectangle", size="10,10", label="lower,upper", label.placement="external", label.icon="false", label.pattern="{0}..{1}")
class Property extends MultiplicityElement {
  ref Association association;
  attr AggregationKind aggregation;
abstract class RelationShip {
enum AggregationKind {
  none = 0;
  share = 1;
  aggregation = 2;
How can I create a connection between two properties? I tried to create a source and target Property in Association class but it did not work.
Thank you!
Re: Create connection between two classes [message #1285767 is a reply to message #1285670] Sat, 05 April 2014 20:25 Go to previous messageGo to next message
Hi Brian,
To create connections between elements in the editor you will need to use a @gmf.link annotation either on a reference (e.g. like Shortcut.target) or on a class (e.g. like Sync) in [1].
Dimitris
[1] http://eclipse.org/epsilon/doc/articles/eugenia-gmf-tutorial/
Re: Create connection between two classes [message #1286569 is a reply to message #1285670] Sun, 06 April 2014 18:15 Go to previous messageGo to next message
Hi Dimitris!
First of all, thank you for your response. Yes I know that I must use @gmf.link annotation to create a connection between two nodes. The problem is if I use @gmf.link in this node:
  @gmf.link
A connection between two properties using the association class is not possible. So I tried to extend the original metamodel and create a target reference:
  ref Property target;
But it is not yet possible create a connection between two properties.. I do not want to make many changes in the original metamodel.. but how can I do this?
Thank you!
[Updated on: Sun, 06 April 2014 18:17] by Moderator
Re: Create connection between two classes [message #1286860 is a reply to message #1286569] Mon, 07 April 2014 02:09 Go to previous message
Hi Brian,
I suspect that you'll need to add another property to your association:
@gmf.link(source="source", target="target")
ref Property source;
Another potential problem in your metamodel is that associations can't be contained anywhere in the structure. To fix this, I'd suggest changing
to
val Classifier[*] classifiers;
If your metamodel is immutable, you could either go with pure GMF or with a hybrid approach where you specify what you can using Eugenia's annotations and then fill in the gaps using a polishing transformation [1].
Dimitris
[1] http://eclipse.org/epsilon/doc/articles/eugenia-polishing/
[Updated on: Mon, 07 April 2014 02:09] by Moderator
Previous Topic:Profile not recognized in ETL when started from standalone plug-in
Next Topic:Handling Epsilon keywords as metamodel element names
Current Time: Mon Aug 11 17:29:31 EDT 2025
Powered by FUDForum. Page generated in 0.05670 seconds
