Adding an EJB 3.0 to DD [message #214865] |
Thu, 05 June 2008 14:06 |
Originally posted by: jmordax.terra.es
I know now in Java EE 5.0 Deployment Descriptors are optional. But I
would like to have my EJB 3.0 declared in the DD. Is there any way to
force an EJB 3.0 to be added automatically? I haven't found how to do it.
Thanks in advance,
Chemi.
Re: Adding an EJB 3.0 to DD [message #215062 is a reply to message #215043] |
Tue, 10 June 2008 18:17 |
Kaloyan Raev wrote:
> What do you mean by "to be added automatically"?
> There are two ways for users to create EJB 3.0 projects with DD.
> 1. Select the "Generate deployment descriptor" checkbox on the second page
> of the "New EJB Project" wizard.
> 2. If you have already created an EJB 3.0 project with no DD, then
> right-click on the project and execute Java EE Tools > Generate Deployment
> Descriptor Stub.
> HTH,
> Kaloyan
What I mean is that EJBs are not added to the DD.
As you said I have created the EJB Project with the check box checked.
Then I develop an EJB following POJO style: an Interface with @Local and
a Class with @Stateless that implements the Interface.
When I expand the EJB Project, I can see the EJB but when I open the DD
I can't see it detailed. So I was looking for an automatic way to add
the EJB to the existing DD (I say automatic because I don't want to
write all the stuff manually).
Chemi..
Re: Adding an EJB 3.0 to DD [message #215085 is a reply to message #215062] |
Wed, 11 June 2008 08:53 |
Kaloyan Raev Messages: 201 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Chemi,
In EJB 3.0 deployment descriptor information is spread in both the
ejb-jar.xml deployment descriptor and Java annotations like @Stateless and
@Local. You can implement an annotated POJO like you do and you don't need
to describe it additionally in the ejb-jar.xml. The EJB 3.0 container where
you deploy the EJB module will parse the annotations and will recognize your
beans. This is one of the great new features in the EJB 3.0 specification.
The deployment descriptor node in the Project Explorer that you see displays
a merged view from the ejb-jar.xml and the annotations in your code.
If you still need the annotations metadata to be duplicated in the
ejb-jar.xml, probably because you may need to change the deployment
configuration later, then you may take a look at bug
https://bugs.eclipse.org/196271.
Another approach is to extend the Session Bean wizard to generate the
deployment descritpor metadata not in Java annotation, but in the
ejb-jar.xml, or in both places. If that make sense to you, then please open
an enhancement request in the bugzilla and we will consider this for the
next release.
Greetings,
Kaloyan
"Chemi" <jmordax@terra.es> wrote in message
news:g2mgf7$45j$1@build.eclipse.org...
>> page of the "New EJB Project" wizard.
>> Deployment Descriptor Stub.
>> HTH,
>> Kaloyan
> Then I develop an EJB following POJO style: an Interface with @Local and a
> When I expand the EJB Project, I can see the EJB but when I open the DD I
> can't see it detailed. So I was looking for an automatic way to add the
> EJB to the existing DD (I say automatic because I don't want to write all
> Chemi..
Re: Adding an EJB 3.0 to DD [message #215101 is a reply to message #215085] |
Wed, 11 June 2008 13:35 |
Kaloyan Raev wrote:
> Hi Chemi,
> next release.
> Greetings,
> Kaloyan
Thanks for the answer. That is exactly what I was looking for... I
understand the DD are optional but from an administration point of view
and maintenance I have found always easier to open a DD and check how
many EJBs are there, which kinds, etc.... instead to have to analyze the
Source Code.
I opened following request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=236621
Chemi.
Re: Adding an EJB 3.0 to DD [message #215109 is a reply to message #215101] |
Wed, 11 June 2008 14:02 |
Thanks, Chemi. I appreciate your end user point of view.
We will continue discussing this topic and solution in the bug entries you
have created.
Greetings,
Kaloyan
news:g2oka3$dv1$1@build.eclipse.org...
> Kaloyan Raev wrote:
>> Hi Chemi,
>> and @Local. You can implement an annotated POJO like you do and you don't
>> need to describe it additionally in the ejb-jar.xml. The EJB 3.0
>> container where you deploy the EJB module will parse the annotations and
>> will recognize your beans. This is one of the great new features in the
>> displays a merged view from the ejb-jar.xml and the annotations in your
>> code.
>> open an enhancement request in the bugzilla and we will consider this for
>> the next release.
>> Greetings,
>> Kaloyan
> and maintenance I have found always easier to open a DD and check how many
> EJBs are there, which kinds, etc.... instead to have to analyze the Source
> Code.
> Regards,
> Chemi.
FUDForum. Page generated in 0.02907 seconds
