Home » Newcomers » Newcomers » Customize ouput of automatic try/catch
Customize ouput of automatic try/catch [message #214759] Sat, 09 June 2007 14:25 Go to next message
For the Java auto-correction feature of adding a try/catch, is there any way
to customize what is output, including the following:
- name of the exception parameter
- comments, or lack thereof (I'd like to get rid of the automatic TODO
added)
- any other standard code, such as adding in myCustomLogMethod(exception)
Where would I customize these?
Thanks?
Re: Customize ouput of automatic try/catch [message #214767 is a reply to message #214759] Sat, 09 June 2007 16:31 Go to previous messageGo to next message
Originally posted by: news.pellaton.li
- Go to Window > Preferences > Java > Code Style > Code Templates
- Then in list on the right pane select for the item "Catch Block Body"
- Click on [Edit...]
- change the block's template to your linking
--> look at the variables - they might help you write less code ;-)
Michael
Re: Customize ouput of automatic try/catch [message #732356 is a reply to message #214767] Tue, 04 October 2011 11:08 Go to previous message
Hello! I have a similiar question.
After surrounding with try/catch first line of code like...
String s = new String("value");
System.out.println(s);
...I get...
String s;
try {
} catch (Exception e) {
	// TODO Auto-generated catch block
	e.printStackTrace();
.. and the exception in the last line, pointing that the variable 's' may not have been initialized.
How can I edit the default template so that it automatically assignt value of null to the variable?
Thanks in advance.
Previous Topic:Installation problem
Next Topic:Calling fortran function from c
Current Time: Fri Sep 12 11:07:56 EDT 2025
Powered by FUDForum. Page generated in 0.07914 seconds
