Home » Archived » Hudson » Hudson upgrade(Hudson upgrade from 2.2.1 to 3.1.2 )
Hudson upgrade [message #1284356] Fri, 04 April 2014 07:25 Go to next message
I am upgrading the Hudson from 2.2.1 to 3.1.2 . Please let me know the steps to take care. This is the first time I am being part of upgrading .
Re: Hudson upgrade [message #1284982 is a reply to message #1284356] Fri, 04 April 2014 23:24 Go to previous messageGo to next message
Nothing special
- Make sure to backup Hudson home
- If you are using authentication and authorization from plugin, then disable security
- Start with Hudson 3.1.2
- When the initial setup page appears, make sure to install all the plugins updates
Once Hudson is up and running, if you disabled security, then re-enable it
Tip: In Hudson 3.x, the security information is saved in hudson-security.xml. You can copy the original security information from the config.xml to this file.
Re: Hudson upgrade [message #1286735 is a reply to message #1284982] Sun, 06 April 2014 22:42 Go to previous messageGo to next message
Thanks Prakash...
Re: Hudson upgrade [message #1288080 is a reply to message #1286735] Tue, 08 April 2014 05:01 Go to previous messageGo to next message
Hi Praskash,
I am planning to do upgrade with automatic option in Hudson. Please let me know why we need to disable the security and update the plugins? cant we automatically update its own?
Do we need to install all the installed plugin again for the new upgrade version manually?
also this hudson-security.xml is only for latest version? Can I know the location of this file ?
Re: Hudson upgrade [message #1289786 is a reply to message #1288080] Wed, 09 April 2014 12:43 Go to previous messageGo to next message
You don't have to disable security, if you use buit-in Authentication (such as bundled daabase or LDAP) and authentication (ex. matrix-based, project-based etc).
You don't have to manually install plugins, the initial setup screen will display the list of plugins to be upgraded and helps you to quickly update the plugins.
hudson-security.xml is for 3.x. It will be automatically created from old settings.
Re: Hudson upgrade [message #1290703 is a reply to message #1289786] Thu, 10 April 2014 07:00 Go to previous messageGo to next message
Thanks Prakash.
I have one more question. How do we take ThreadDumps in Hudson . I have tried this way which I got from one doc http://yourserver/hudson/threadDump
But it didnt work.
Actually what happened was ,
The job was stuck while checking out from Subversion and I tried to abort and it was not happening. So read in one doc says we need to see the Thread Dumps to check further where exactly the stuck is . Please let me know what is the action should be taken care in these scenarios .
Re: Hudson upgrade [message #1292604 is a reply to message #1290703] Fri, 11 April 2014 19:49 Go to previous messageGo to next message
That is the right way. For example to take thread Dump from
http://ci.hudson-ci.org
I issue the command
http://ci.hudson-ci.org/threadDump
What is the exact error you get?
Re: Hudson upgrade [message #1298142 is a reply to message #1292604] Wed, 16 April 2014 00:32 Go to previous messageGo to next message
Hi Prakash,
I am not getting an error. I am not understanding which date's threadDump it is showing up .
I am getting one thread as below. But how do we take action on this ? Is there any way we can kill the build process in the backend from unix server? If in case abort option is not working because of stuck somewhere . is there any option to kill only that build in the back end?
pool-1-svnkit-thread-2
"pool-1-svnkit-thread-2" Id=52 Group=main WAITING on java.util.concurrent.SynchronousQueue$TransferStack@5752f
at sun.misc.Unsafe.park(Native Method)
- waiting on java.util.concurrent.SynchronousQueue$TransferStack@5752f
at java.util.concurrent.locks.LockSupport.park(LockSupport.java:158)
at java.util.concurrent.SynchronousQueue$TransferStack.awaitFulfill(SynchronousQueue.java:422)
at java.util.concurrent.SynchronousQueue$TransferStack.transfer(SynchronousQueue.java:323)
at java.util.concurrent.SynchronousQueue.take(SynchronousQueue.java:857)
at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:947)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:907)
at java.lang.Thread.run(Thread.java:662)
Re: Hudson upgrade [message #1298173 is a reply to message #1298142] Wed, 16 April 2014 01:00 Go to previous messageGo to next message
This is not the right stack. If you are on linux, you may be able to see the process tree using the command "ps axf" or "pstree" and determine which process is stuck.
Re: Hudson upgrade [message #1303480 is a reply to message #1298173] Sat, 19 April 2014 05:09 Go to previous messageGo to next message
Hi , For 3.1.2 version, is the web server mandatory? In our system, Hudson is running stand alone. its not in any of the container. Please let us is it mandatory to be in Apache tomcat from 3.1.2 version.Current version we are using is 2.2.1. Up-gradation failed with 500 error while login after up-gradation.
[Updated on: Mon, 21 April 2014 06:22] by Moderator
Re: Hudson upgrade [message #1308141 is a reply to message #1303480] Mon, 21 April 2014 20:32 Go to previous messageGo to next message
No, it is same as 2.2.1, you can use java -jar hudson.war to run 3.1.2.
If you get 500 error look at the log file (if you used apache, then catalina.log) and see if you find any error related to login. What kind of Authentication and Authorization scheme are you using?
Re: Hudson upgrade [message #1310389 is a reply to message #1308141] Wed, 23 April 2014 02:46 Go to previous messageGo to next message
we are using project matrix authentication strategy.
error log as below,
HTTP ERROR 500
Problem accessing /. Reason:
jar:file:/data03/hudson/Hudson/war/webapp/WEB-INF/lib/hudson-core-3.1.2.jar!/lib/hudson/projectView.jelly:60:81: <st:include> hudson.model.Hudson.getAuthentication()Lorg/acegisecurity/Authentication;
Caused by:
org.apache.commons.jelly.JellyTagException: jar:file:/data03/hudson/Hudson/war/webapp/WEB-INF/lib/hudson-core-3.1.2.jar!/lib/hudson/projectView.jelly:60:81: <st:include> hudson.model.Hudson.getAuthentication()Lorg/acegisecurity/Authentication;
at org.apache.commons.jelly.impl.TagScript.handleException
(TagScript.java:728)
at org.apache.commons.jelly.impl.TagScript.run(TagScript.java:290)
at org.apache.commons.jelly.TagSupport.invokeBody(TagSupport.java:186)
at org.apache.commons.jelly.tags.core.ForEachTag.doTag(ForEachTag.java:150)
at org.apache.commons.jelly.impl.TagScript.run(TagScript.java:270)
at org.apache.commons.jelly.impl.ScriptBlock.run(ScriptBlock.java:95)
at org.kohsuke.stapler.jelly.ReallyStaticTagLibrary$1.run(ReallyStaticTagLibrary.java:91)
at org.apache.commons.jelly.tags.core.CoreTagLibrary$1.run(CoreTagLibrary.java:98)
at org.apache.commons.jelly.tags.core.CoreTagLibrary$2.run(CoreTagLibrary.java:105)
at org.kohsuke.stapler.jelly.CallTagLibScript.run(CallTagLibScript.java:111)
at org.apache.commons.jelly.tags.core.OtherwiseTag.doTag(OtherwiseTag.java:41)
at org.apache.commons.jelly.tags.core.ChooseTag.doTag(ChooseTag.java:38)
at org.kohsuke.stapler.jelly.JellyViewScript.run(JellyViewScript.java:55)
at org.kohsuke.stapler.jelly.IncludeTag.doTag(IncludeTag.java:138)
at org.kohsuke.stapler.jelly.CallTagLibScript$1.run(CallTagLibScript.java:90)
at org.apache.commons.jelly.tags.define.InvokeBodyTag.doTag(InvokeBodyTag.java:91)
at org.kohsuke.stapler.jelly.CompressTag.doTag(CompressTag.java:36)
at org.kohsuke.stapler.jelly.DefaultScriptInvoker.invokeScript(DefaultScriptInvoker.java:55)
at org.kohsuke.stapler.jelly.DefaultScriptInvoker.invokeScript(DefaultScriptInvoker.java:45)
at org.kohsuke.stapler.jelly.JellyClassTearOff.serveIndexJelly(JellyClassTearOff.java:64)
at org.kohsuke.stapler.jelly.JellyFacet.handleIndexRequest(JellyFacet.java:106)
at org.kohsuke.stapler.Stapler.tryInvoke(Stapler.java:554)
at org.kohsuke.stapler.Stapler.invoke(Stapler.java:650)
at org.kohsuke.stapler.Stapler.tryInvoke(Stapler.java:616)
at org.kohsuke.stapler.Stapler.invoke(Stapler.java:481)
at org.kohsuke.stapler.Stapler.service(Stapler.java:152)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:648)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1336)
at hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:86)
at org.hudsonci.servlets.internal.ServletRegistrationFilterAdapter.doFilter(ServletRegistrationFilterAdapter.java:162)
at org.hudsonci.servlets.internal.ServletRegistrationFilterAdapter.doFilter(ServletRegistrationFilterAdapter.java:134)
at hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:89)
at hudson.plugins.audit_trail.AuditTrailFilter.doFilter(AuditTrailFilter.java:64)
at hudson.util.PluginServletFilter.doFilter(PluginServletFilter.java:78)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1307)
at hudson.security.ChainedServletFilter$1.doFilter(ChainedServletFilter.java:81)
at hudson.security.UnwrapSecurityExceptionFilter.doFilter(UnwrapSecurityExceptionFilter.java:45)
at hudson.security.ChainedServletFilter$1.doFilter(ChainedServletFilter.java:84)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at hudson.security.ChainedServletFilter.doFilter(ChainedServletFilter.java:73)
at hudson.security.HudsonFilter.doFilter(HudsonFilter.java:157)
at hudson.util.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:70)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:453)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:534)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1072)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:382)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1006)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:365)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:485)
at org.eclipse.jetty.server.BlockingHttpConnection.handleRequest(BlockingHttpConnection.java:53)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:926)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:988)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:635)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
at org.eclipse.jetty.server.BlockingHttpConnection.handle(BlockingHttpConnection.java:72)
at org.eclipse.jetty.server.bio.SocketConnector$ConnectorEndPoint.run(SocketConnector.java:264)
at org.eclipse.jetty.server.ssl.SslSocketConnector$SslConnectorEndPoint.run(SslSocketConnector.java:670)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
Caused by: java.lang.NoSuchMethodError: hudson.model.Hudson.getAuthentication()Lorg/acegisecurity/Authentication;
at hudson.plugins.favorite.column.FavoriteColumn.isLoggedIn(FavoriteColumn.java:59)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.apache.commons.jexl.util.introspection.UberspectImpl$VelMethodImpl.invoke(UberspectImpl.java:258)
at org.apache.commons.jexl.parser.ASTMethod.execute(ASTMethod.java:104)
at org.apache.commons.jexl.parser.ASTReference.execute(ASTReference.java:83)
at org.apache.commons.jexl.parser.ASTReference.value(ASTReference.java:57)
at org.apache.commons.jexl.parser.ASTReferenceExpression.value(ASTReferenceExpression.java:51)
at org.apache.commons.jexl.ExpressionImpl.evaluate(ExpressionImpl.java:80)
at org.eclipse.hudson.ExpressionFactory2$JexlExpression.evaluate(ExpressionFactory2.java:89)
at org.apache.commons.jelly.expression.ExpressionSupport.evaluateRecurse(ExpressionSupport.java:61)
at org.apache.commons.jelly.expression.ExpressionSupport.evaluateAsBoolean(ExpressionSupport.java:71)
at org.apache.commons.jelly.tags.core.CoreTagLibrary$1.run(CoreTagLibrary.java:97)
... 138 more
Caused by:
________________________________________
Powered by Jetty://
Re: Hudson upgrade [message #1311246 is a reply to message #1310389] Wed, 23 April 2014 13:40 Go to previous messageGo to next message
Ah I see. The issue is because of Favorite Column plugin.
Disable that plugin for now. Go to Hudson_Home/plugins and remove favorite.hpi and the favorite folder and restart Hudson.
We are preparing to release newer version of favorite column plugin for Hudson 3.2.0
Re: Hudson upgrade [message #1325204 is a reply to message #1311246] Thu, 01 May 2014 00:53 Go to previous messageGo to next message
Hi Prakash,
When will be the new version is getting released.
Re: Hudson upgrade [message #1326290 is a reply to message #1325204] Thu, 01 May 2014 13:16 Go to previous messageGo to next message
Hudson 3.2.0 will be released in June.
BTW, if you are looking for favorite plugin fix we discussed above, then the latest version 1.10-h-1 in the Plugin Center already has the fix.
Re: Hudson upgrade [message #1333146 is a reply to message #1326290] Sun, 04 May 2014 20:59 Go to previous messageGo to next message
Thanks Praskah.
What are the other features coming up with version 3.2.0?
Re: Hudson upgrade [message #1368049 is a reply to message #1333146] Mon, 19 May 2014 22:01 Go to previous messageGo to next message
Hi Prakash.
Do we have any update on when the version 3.2.0 will be released and its features.
Re: Hudson upgrade [message #1368240 is a reply to message #1368049] Mon, 19 May 2014 23:57 Go to previous messageGo to next message
The release schedule is posted ine the Community Meeting Page.
The bug fixes and enhancement planned are listed in bugzilla with key candidate-3.2.0
Re: Hudson upgrade [message #1387099 is a reply to message #1368240] Tue, 24 June 2014 02:33 Go to previous messageGo to next message
Recently we have upgraded Hudson from 2.1.0 to 3.1.2, After up-gradation we face serious performance issue with hudson, hence we revert back to old version again.
Machine detail.
Machine type : VM (Vmware)
CPU = 1 Vcpu (Intel(R) Xeon(R) CPU X5690 @ 3.47GHz)
MemTotal: 6228844 KB
SwapTotal: 8393920 kB
it is deployed on apache tomcat 7.1,
could anyone point what could be the real cause of performance issue.
Please do let me know if more information required
Re: Hudson upgrade [message #1387181 is a reply to message #1387099] Tue, 24 June 2014 13:01 Go to previous messageGo to next message
Until Hudson 3.1.0 one of the major issue was memory consumption. For large installations (hundreds of jobs and tens of thousands of builds), huge memory was required. Even then Hudson has to be rebooted often to dump the accumulated memory. In large enterprises, rebooting often is not an option. Long uptime of Hudson in order of months is desirable. In Hudson 3.1.0 we introduced caching mechanism to retain only currently accessed jobs and builds and periodically release the memory.
One trade off is, this could introduce latency (page load), if Hudson was idle for a long time. Since all the data is released and memory is reclaimed. There are API to iterate over all jobs and builds and some of the plugins uses them (such as diskspace). This is the cause of the latency, since all jobs and builds need to be loaded from disk (especially slow if master is on a windows machine). We have introduced other APIs the plugins could use to reduce latency. We fixed in few plugins and keep fixing in others.
So a list of plugins you are using may be helpful for us to identify possible cause of latency.
Also, it helps to retain limited amount of builds in each job, by configuring the jobs to delete old builds.
Re: Hudson upgrade [message #1387667 is a reply to message #1387181] Wed, 25 June 2014 08:13 Go to previous messageGo to next message
Hello Winston,
Thanks for detail information.
once last question is, if i increase the RAM will it solve the issue.
in 3.2 release is these issues will be resolved.
As slow loading of page give user impression that application is running slow.
Re: Hudson upgrade [message #1387862 is a reply to message #1387667] Wed, 25 June 2014 13:51 Go to previous messageGo to next message
The main Hudson-on-Hudson is running 3.1.2 (http://ci.hudson-ci.org). No noticeable delay is seen. The main reason is the jobs retains only last 50 or so jobs.
Increasing memory does not solve the problem. Main purpose of caching is not to keep all data in the memory. We put some fixes to improve latency in 3.2.0
You can contact me off-line at winston dot prakash at gmail dot com and give details about your settings, espcially the plugins you are using
Re: Hudson upgrade [message #1404738 is a reply to message #1387862] Tue, 05 August 2014 07:44 Go to previous messageGo to next message
Hi Prakash,
Could you please give some information about Hudson 3.2.0 .When the final product will get release?
Re: Hudson upgrade [message #1407180 is a reply to message #1404738] Mon, 11 August 2014 23:35 Go to previous messageGo to next message
We have filed approval request with Eclipse PMC to allow the release of Hudson 3.2.0. If approved we are planning to release it around Aug 15th.
Re: Hudson upgrade [message #1411242 is a reply to message #1284356] Fri, 22 August 2014 15:39 Go to previous messageGo to next message
Eclipse GuestFriend
Member
After the upgrade of Hudson from 3.1.2 to 3.2.0 I am getting the below security error
HTTP ERROR 500
Problem accessing /j_spring_security_check. Reason:
anonymous is missing the Read permission
Caused by:
hudson.security.AccessDeniedException2: anonymous is missing the Read permission
at hudson.security.ACL.checkPermission(ACL.java:48)
at hudson.model.Node.checkPermission(Node.java:347)
at hudson.model.Hudson.getTarget(Hudson.java:3873)
at org.kohsuke.stapler.Stapler.tryInvoke(Stapler.java:500)
at hudson.security.HudsonFilter.doFilter(HudsonFilter.java:156)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:937)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:998)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:856)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:240)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:627)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:51)
at java.lang.Thread.run(Thread.java:636)
Powered by Jetty://
Re: Hudson upgrade [message #1411263 is a reply to message #1411242] Fri, 22 August 2014 16:55 Go to previous message
This looks like a security permission issue. What security setting do you have? What did you try to access?
Previous Topic:Stopping Maven3 build step leaves running processes
Next Topic:violations plugin doesn't show up
Current Time: Fri Nov 07 06:55:07 EST 2025
Powered by FUDForum. Page generated in 0.08593 seconds
