Re: Text ellipsis (in CLabel and other) [message #1284555 is a reply to message #1284219] |
Fri, 04 April 2014 16:01 |
Tim Buschtoens Messages: 396 Registered: July 2009 |
Hi.
Yes and yes.
Ellipsis are already supported on Row Templates, and we had it planned
for 2.3, but it's currently unclear if it will happen. We also have a
bug for it: https://bugs.eclipse.org/bugs/show_bug.cgi?id=429894
You can certainly add browser-native CSS (bypassing the RAP theming) to
enable this for ALL divs. To do so you must add the CSS in a style tag
to the applications HEAD_HTML:
http://eclipse.org/rap/developers-guide/devguide.php?topic=application-configuration.html
(This only has an example for BODY_HTML, but HEAD_HTML is the same).
Greetings,
Tim
Am 04.04.2014 10:12, schrieb Sebastien Arod:
> SWT CLabel does ellipsis when text is too long to fit in the widget
> size. This behavior does not work in RWT.
> More generally it would be nice to have a way to enable text ellipsis on
> widgets even if it's not supported by SWT.
> Ellipsis would make sense on most read-only widgets: Label, Buttons,
> CTabItem, TabItem, Column Headers, Tree/Table cell...
> This can be partially worked around on server side by calling
> computeSize with different text values and see when the result fit in
> the final size we want to use.
> However this is very inefficient, generates a lot of
> TextSizeDetermination queries and we end up seeing the different
> iteration on client.
> So the questions are:
> * Is there a way to enable browser builtin ellipsis support for some div
> ( white-space : nowrap;text-overflow:ellipsis) styles using
> theming/RemoteScripting?
> * Is there a plan to support ellipsis out of the box?
> Regards,
> -Seb
Tim Buschtöns
Twitter: @EclipseRAP
FUDForum. Page generated in 0.02822 seconds
