| Error when creating a Java project: 'Must specify a URI scheme' [message #214447] |
Thu, 07 June 2007 13:19  |
Originally posted by: stefan_._sss-smart_._com
Hello.
I'm working with Eclipse SDK version 3.2.2 doing my first steps in Java
development.
I want my projects to be independent from the actual drive and folder
location of my workspace. The projects are not stored in the workspace
folder but in parallel folders at the same level, eg. like this
P:\Development\Java\
P:\Development\Java\Eclipse # workspace
P:\Development\Java\Project1 # 1st project
P:\Development\Java\Project2 # 2nd project
My goal is that if I give my whole Java folder to anyone who stores it
for example in c:\ it should compile with as less changes as possible.
What I've done so far:
I created a linked resource in
'Window->Preferences-General-Workspace-Linked Resources' and of course
enabled linked resources in the same dialog:
Defined path variables: PROGRAMAS_JAVA - P:\Development\Java
My idea is that this variable should be the only thing to adapt for
other developers in order to get my projects compiled.
Then I created the folder Project1 and tried to create a new Java
project. In the upcoming dialog I gave the project name 'Project1' and
used 'Create project from existing source'. As the directory name I used
'PROGRAMAS_JAVA\Project1' and what I got was the following error:
'Must specify a URI scheme:PROGRAMAS_JAVA/Project1'
I also tried using $PROGRAMAS_JAVA and some other notations all with the
same result.
I suppose it's just a matter of syntax but I haven't found the right one
for this dialog.
Thanks for any help.
Stefan
Email: _._ = .
_@_ = @
| Re: Error when creating a Java project: 'Must specify a URI scheme' [message #214598 is a reply to message #214523] |
Fri, 08 June 2007 08:40   |
Stefan wrote:
> Mark Dexter escribió:
>> Stefan wrote:
>>> Hello.
>>> Java development.
>>> workspace folder but in parallel folders at the same level, eg. like
>>> this
>>> it for example in c:\ it should compile with as less changes as
>>> possible.
>>> course enabled linked resources in the same dialog:
>>> and used 'Create project from existing source'. As the directory name
>>> I used 'PROGRAMAS_JAVA\Project1' and what I got was the following
>>> error:
>>> the same result.
>>> one for this dialog.
>>> Stefan
>> Hi Stefan. I just tried this and it worked for me
>> (WinXP/Eclipse3.2.2). I did one thing differently, perhaps. I started
>> with a valid Eclipse project. Then I created a new project and added a
>> folder that linked back to the first project's top-level folder. I
>> created a variable called MyPath = "C:\eclipse\workspaces" and then
>> created the linked folder as "MyPath\testproject", where testproject
>> was the subfolder for the linked project.
>> Anyway, hope this helps. Mark Dexter
> Thanks Mark for your answer.
> Let me see if I can follow your steps in my environment:
> (Workspace is p:\Development\Java\Eclipse)
> (My desired project folder is p:\Development\Java\Project1)
> (All references to p:\Development\Java should be substituted by the
> variable PROGRAMAS_JAVA)
> First I create a new Project in my workspace:
> p:\Development\Java\Eclipse\Project1
> Then, in the second step of the new project wizard I use a linked source
> to PROGRAMAS_JAVA\Project1\src where my sources will be located.
> This works but then all the output-files go to the Eclipse folder
> (p:\Development\Java\Eclipse\Project1\bin) and I would like to have all
> project files in one folder (they should go to
> p:\Development\Java\Project1\bin).
> What I finally want to achieve is some structure of the projects in my
> workspace, for example all ide-projects in one subfolder
> (p:\Development\Java\Ide\Project_1..n) and the console projects into
> another one (p:\Development\Java\Console\Project_1..n).
> There seems no way to get this structure into one workspace, the only
> idea I have is to create two workspaces, one for the ide-project in
> p:\Development\Java\Ide and another one for the console projects in
> p:\Development\Java\Console.
> Since I am new to Eclipse probably I'm missing something.
> Thanks again for your help.
> Stefan
Hi Stefan. I'm somewhat new to Eclipse as well, but I think the idea of
keeping those in separate projects makes sense. There is no disadvantage
that I can see to having a lot of projects. There are some good articles
in Eclipse Magazine about organizing your workspaces and projects. I
don't have time now to get the links, but you can google on Eclipse
magazine. Hope this helps. Mark
| Re: Error when creating a Java project: 'Must specify a URI scheme' [message #215584 is a reply to message #215040] |
Wed, 13 June 2007 15:29   |
Thanks a lot for your explanations Dave. In fact I am impressed
by the 'responsiveness' of this newsgroup.
You are right: my idea was to share the workspace itself in order
to have all developers use a unique structure over all projects.
So far we used CVS for our (Delphi and C++) projects and I
barely new about the integrated CVS features of Eclipse.
In the Eclipse projects that I created so far I am referring to
some linked sources/folders where I put my common classes.
In the definition of this linked sources I used a variable that
I defined in the preferences of my Eclipse workspace.
So I suppose that if the other developers define the same variable
in their workspace everything should compile without problems when
they checkout my projects. (Of course they have to checkout as well
the sources with my common classes)
I will make some tests to see how this works.
Thanks again for all your help.
Stefan
Dave Wegener escribió:
> One point you need to understand. The workspace is not designed to be
> shared with other developers. Only projects are expected to be shared.
> Projects don't need to reside in your workspace, so the folder layout you
> discuss is supported. The project files (.classpath and .project) maintain
> references relative to the project itself, so it shouldn't be a problem to
> give you projects to someone else. They would need to perform an import
> into their workspace, but they could place them any where in the file
> system.
> The ide and console structures that you reference are possible. You can
> have as many projects as you want in the ide or console folder. This may be
> the way you want to go. All projects can exist in your workspace at the
> same time. When creating the projects, you don't need to worry about linked
> resources. On the New Project wizard, select Create new project from
> existing source. Don't worry if you don't have any existing source. You
> can create the project in an empty directory. Browse to your ide or console
> folder. Create a new sub folder for the project. Finish the wizard.
> Repeat for each additional project you want to create in your workspace.
> You can share these projects by either copying the ide/console folders or
> using the File-Export option on the Eclipse menu. The person you share the
> project will will need to use the File->Import menu to import them into
> their workspace.
> "Mark Dexter" <dextercowley@gmail.com> wrote in message
> news:f4bipa$l14$1@build.eclipse.org...
>>>> Stefan wrote:
>>>>> Hello.
>>>>> Java development.
>>>>> this
>>>>> possible.
>>>>> error:
>>>>> the same result.
>>>>> Stefan
>>> Stefan
Email: _DT_ = .
_@_ = @
| Re: Error when creating a Java project: 'Must specify a URI scheme' [message #216645 is a reply to message #216251] |
Tue, 19 June 2007 03:47  |
Eric, thank you for your suggestions.
I will search for some documentation about Team Project Sets
and then make some tests with our CVS.
After this I will document my experiences in this NG thread.
Stefan
> Why not make an Eclipse project (or projects) out of that "common" code,
> too? If everything is an Eclipse project, you can export a Team Project
> Set and send it to others to import into their workspaces; that way they
> don't even have to do the check-out manually, the Team Project Set
> inherently knows to get the projects from CVS.
> Hope this helps,
> Eric
Email: _DT_ = .
_@_ = @
FUDForum. Page generated in 0.29921 seconds
