Home » Language IDEs » ServerTools (WTP) » Re: Can't get XSD graphical editor working...
Re: Can't get XSD graphical editor working... [message #212973] |
Fri, 25 April 2008 20:11 |
Mike,
The XSD project doesn't directly provide this editor. We only provide a
crude sample editor. You'll want to install
http://www.eclipse.org/webtools/ and ask any questions about the editor
on the WTP newsgroup, which I've added to the "to" list of the reply.
Mike wrote:
> Hi all,
> I recently downloaded and installed the EMF along with anything and
> everything I thought I would need to enable graphical (GUI-driven)
> editing of XML schema (XSD) and XML files.
> Unfortunately, I cannot seem to get the graphical design editor tab
> ("Design") to show up in the list of tabs along the bottom of the file
> window currently being edited. I'm expecting this tab to be there
> based on the following tutorial:
> http://wiki.eclipse.org/index.php/Introduction_to_the_XSD_Ed itor.
> I only have the following tabs visible when editing an XSD file:
> "Source", "Semantics", "Syntax".
> Can some one show me how or tell me what to do to get the graphical
> editor to work for XSD files?
> Mike
> FYI - Here's my config and what I installed wrt EMF:
> Eclipse Version: 3.3.0
> Build id: I20070621-1340
> (Sorry for the cut-n-paste below. Don't know any other easier way to
> provide the information)
> Apr 22, 2008 11:28:23 AM
> Date / Time Target Action Status
> Apr 22, 2008 11:28:01 AM
> org.eclipse.emf.codegen.ecore.ui_2.3.1.v200802051830
> feature-install success
> Apr 22, 2008 11:28:14 AM
> feature-enable success
> org.eclipse.emf.codegen.ecore_2.3.2.v200802051830
> Apr 22, 2008 11:28:16 AM
> org.eclipse.emf.codegen.ui_2.3.1.v200802051830 feature-install
> success
> Apr 22, 2008 11:28:17 AM
> org.eclipse.emf.codegen.ui_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.codegen_2.3.1.v200802051830 feature-install
> success
> Apr 22, 2008 11:28:18 AM
> org.eclipse.emf.codegen_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.common.ui_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.common.ui_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.common_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.common_2.3.1.v200802051830 feature-enable success
> org.eclipse.emf.converter_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.converter_2.3.1.v200802051830 feature-enable
> success
> Apr 22, 2008 11:28:18 AM org.eclipse.emf.doc_2.3.2.v200802051830
> org.eclipse.emf.ecore.edit_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.ecore.edit_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.ecore.editor_2.3.1.v200802051830
> Apr 22, 2008 11:28:18 AM org.eclipse.emf.ecore_2.3.2.v200802051830
> org.eclipse.emf.edit.ui_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.edit.ui_2.3.1.v200802051830 feature-enable
> success
> Apr 22, 2008 11:28:18 AM org.eclipse.emf.edit_2.3.2.v200802051830
> org.eclipse.emf.mapping.ecore.editor_2.3.1.v200802051830
> org.eclipse.emf.mapping.ecore_2.3.1.v200802051830
> org.eclipse.emf.mapping.ui_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.mapping.ui_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.mapping_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.mapping_2.3.1.v200802051830 feature-enable
> success
> Apr 22, 2008 11:28:18 AM org.eclipse.emf.sdk_2.3.2.v200802051830
> Apr 22, 2008 11:28:20 AM org.eclipse.emf_2.3.2.v200802051830
> org.eclipse.emf.source_2.3.2.v200802051830 feature-enable success
> Apr 22, 2008 11:28:20 AM org.eclipse.emf.sdk_2.3.2.v200802051830
> org.eclipse.emf.source_2.3.2.v200802051830 feature-install
> success
> org.eclipse.emf.ecore.sdo.doc_2.3.2.v200802051830
> org.eclipse.emf.ecore.sdo.edit_2.3.1.v200802051830
> org.eclipse.emf.ecore.sdo.editor_2.3.1.v200802051830
> org.eclipse.emf.ecore.sdo.sdk_2.3.2.v200802051830
> Apr 22, 2008 11:28:21 AM
> org.eclipse.emf.ecore.sdo_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.ecore.sdo.source_2.3.2.v200802051830
> org.eclipse.emf.ecore.sdo_2.3.1.v200802051830 feature-install
> success
> Apr 22, 2008 11:28:21 AM org.eclipse.xsd.doc_2.3.2.v200802051830
> Apr 22, 2008 11:28:22 AM org.eclipse.xsd.doc_2.3.2.v200802051830
> org.eclipse.xsd.ecore.converter_2.3.2.v200802051830
> Apr 22, 2008 11:28:22 AM org.eclipse.xsd.edit_2.3.0.v200802051830
> org.eclipse.xsd.editor_2.3.0.v200802051830 feature-install
> success
> org.eclipse.xsd.editor_2.3.0.v200802051830 feature-enable success
> org.eclipse.xsd.mapping.editor_2.3.0.v200802051830
> org.eclipse.xsd.mapping_2.3.0.v200802051830 feature-install
> success
> org.eclipse.xsd.mapping_2.3.0.v200802051830 feature-enable
> success
> Apr 22, 2008 11:28:22 AM org.eclipse.xsd.sdk_2.3.2.v200802051830
> Apr 22, 2008 11:28:23 AM org.eclipse.xsd_2.3.2.v200802051830
> org.eclipse.xsd.source_2.3.2.v200802051830 feature-enable success
> Apr 22, 2008 11:28:23 AM org.eclipse.xsd.sdk_2.3.2.v200802051830
> org.eclipse.xsd.source_2.3.2.v200802051830 feature-install
> success
> org.eclipse.emf.examples.source_2.3.1.v200802051830
> org.eclipse.emf.examples_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.examples_2.3.1.v200802051830 feature-enable
> success
Re: Can't get XSD graphical editor working... [message #213209 is a reply to message #212973] |
Thu, 01 May 2008 17:09 |
Keith Chong Messages: 64 Registered: July 2009 |
Member |
You can find the declared builds here:
http://download.eclipse.org/webtools/downloads/
(Grab the required requisites zip, and the wtp zip)
Note that for the latest R3.0 Integration build, because of P2, you can
extract the zips into the dropins folder. See the section "Running WTP"
from the following link for more details:
http://wiki.eclipse.org/WTP/What_we_have_learned_%28to_love% 29_about_P2
> Ed Merks wrote:
> Mike,
> Mike wrote:
>> Hi all,
>> Thanks,
>> Mike
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
Current Time: Fri Apr 26 17:58:15 GMT 2024
Powered by FUDForum. Page generated in 0.03870 seconds
