Re: Execute Aliases From EGit UI [message #1278595 is a reply to message #1278020] |
Thu, 27 March 2014 15:09 |
Blake Longmore Messages: 2 Registered: March 2014 |
Thank you for that suggestion. It works great. The only problem is when I try to run a git svn rebase --all, it prompts for my password with the username already populated. My username on my PC is different than my svn username and it appears to be populating the username with my PC username. This works fine if I run it from gitbash, since it prompted me for my username too. It seems a bit strange, since I was able to perform a svn dcommit and it remembered my username/password from my gitbash settings. Is there a way to get this working in the external tools? Thanks.
--EDIT--
I figured out the solution to this latest problem on my own. The answer is to create your external tool with the '--username=' flag set to the username you want to use. This works very nicely now. Thanks again for your help.
[Updated on: Thu, 27 March 2014 19:59] Report message to a moderator
FUDForum. Page generated in 0.02909 seconds
