Home » Eclipse Projects » Eclipse Scout » Column Filter in TablePages when table is scrolled(Column Filter in TablePages when table is scrolled)
Column Filter in TablePages when table is scrolled [message #1276356] Mon, 24 March 2014 08:57 Go to next message
Hi Scout Users,
Firstly and before starting with my questions and my problems I have to congratulate all Scout Team for this great job !
I use Scout 3.9 (with RAP only, neither SWT nor Swing) on Linux system.
It seems that when I want to filter values in a TablePage (right clic on header column and "Column filter..."), the form that appears does not give the good values if the table (with a lot of columns) is scrolled on the right.
Re: Column Filter in TablePages when table is scrolled [message #1276402 is a reply to message #1276356] Mon, 24 March 2014 10:15 Go to previous messageGo to next message
Can you post a screenshot or a code example in order to reproduce it?
It would also help if you can tell if the problem exists with the lastest Luna Milestone release.
http://www.eclipse.org/downloads/index-developer.php
Re: Column Filter in TablePages when table is scrolled [message #1276648 is a reply to message #1276402] Mon, 24 March 2014 17:40 Go to previous messageGo to next message
Hi Jeremie,
I'm sorry if it wasn't clear enough. I will try with Luna as soon as possible. For the moment, here are two screenshots :
Firstly, I scroll my table to get the column that I want to filter, and then I open the column filter dialog box:
index.php/fa/17830/0/
And the result : values of the wrong column (because of the scroll)
index.php/fa/17831/0/
Thanks for you help.
With regards,
Didier.
  • Attachment: step1.jpg
    (Size: 120.36KB, Downloaded 709 times)
  • Attachment: step2.jpg
    (Size: 154.78KB, Downloaded 700 times)
Re: Column Filter in TablePages when table is scrolled [message #1277824 is a reply to message #1276648] Wed, 26 March 2014 10:11 Go to previous messageGo to next message
Thanks a lot for your explanations. It is much clearer now.
I could reproduce your case with scout 3.9.1.
It seems that the bug has been fixed for Luna. If you do not want to migrate now to 4.0, I recommend you to switch to one of the 3.10 milestones. I tried it with 3.10-M5 and it works. (we explained our new versioning policy in this thread. If something is not clear do not hesitate to ask)
PS: By the way, it seems that you have a nice scout application.
Re: Column Filter in TablePages when table is scrolled [message #1277894 is a reply to message #1277824] Wed, 26 March 2014 11:56 Go to previous messageGo to next message
here lies the problem on 3.9 brand:
	public static TableColumn getRwtColumnAt(Table table, Point p) {
		int x = p.x;
		if (table.getHorizontalBar() != null) {
			x += table.getHorizontalBar().getSelection();
		// loop over all columns with respect to the current display order
		for (int index : table.getColumnOrder()) {
			TableColumn col = table.getColumn(index);
			if (col != null) {
				if (x >= 0 && x <= col.getWidth()) { return col; }
				x -= col.getWidth();
		return null;
in RWTUtility
and I really don't know the reason why table.getHorizontalBar().getSelection() always return 0 while an offset is expected!
PS: yeah the app looks very nice and that's not all! Smile
Re: Column Filter in TablePages when table is scrolled [message #1278820 is a reply to message #1277824] Thu, 27 March 2014 18:29 Go to previous messageGo to next message
Hi Jeremie,
Sorry for my late reply and thanks a lot for your help! I'm going to try 3.10-M5...(and surely Luna, but later).
PS : Concerning our application, we are very satisfied of what we have succeeded to do with Scout/RAP. Thanks to my friend Boy D'Poy who convinced us to use Scout framework. Unfortunatly for us, he abandoned us (joke) to go to other adventure... Razz
Re: Column Filter in TablePages when table is scrolled [message #1332545 is a reply to message #1278820] Sun, 04 May 2014 13:59 Go to previous messageGo to next message
Hi Jeremie,
I tried with the latest luna branch 4.0.0.2140503 (but not with 3.10-M5) and the problem always exists. I even met other problems : when I right click on column header to open a filter:
- the first time, the "Column filter" menu item is not visible
- the second time and after, the values match the column one rank on the left
- and whatever the column you choose, the values are always the same
Did I make a mistake or do you meet the same problem ?
(Linux Fedora 20 + Eclipse Luna)
Didier
Re: Column Filter in TablePages when table is scrolled [message #1384329 is a reply to message #1332545] Wed, 28 May 2014 14:32 Go to previous messageGo to next message
Hi Didier,
Sorry for the late answer (*) and thank you for your message.
Tested with Scout Luna RC1:
- org.eclipse.rap.rwt.osgi 2.3.0.20140124-1321
- org.eclipse.rap.ui.workbench 2.3.0.20140212-1749
- org.eclipse.scout.rt.ui.rap.theme.rayo.mobile 4.0.0.20140520-1318
- org.eclipse.scout.rt.ui.rap.mobile 4.0.0.20140520-1318
- org.eclipse.scout.rt.ui.rap.theme.rayo 4.0.0.20140520-1318
- org.eclipse.rap.ui 2.3.0.20131210-1030
- org.eclipse.scout.svg.ui.rap 4.0.0.20140520-1318
- org.eclipse.rap.ui.forms 2.3.0.20140512-0919
- org.eclipse.scout.rt.ui.rap 4.0.0.20140521-1250
- org.eclipse.rap.jface.databinding 2.3.0.20131210-1030
- org.eclipse.rap.rwt 2.3.0.20140520-1615
- org.eclipse.rap.jface 2.3.0.20140306-1341
Firefox 29.0.1
Windows 7
I could observe similar behavior:
If I click only with right-click, I never get the "Column filter" menu Item.
index.php/fa/18161/0/
index.php/fa/18162/0/
If I once click with the left button of the mouse, it changes the sort order (the table is ordered by this column). After that, in the context menu (right click), I get the Menu Item "Column filter" but the filter windows is opened for the column that was clicked previously with the left click, independently from where the right click occurs.
index.php/fa/18163/0/
index.php/fa/18164/0/
Both menus open this filter window:
index.php/fa/18165/0/<Image>
I will try to ask the Scout RT development team. I hope there is a solution.
(*) am I currently really busy in the scout project I am involved in. I do not have enough time for the Eclipse Scout community.
[Updated on: Wed, 28 May 2014 15:10] by Moderator
Re: Column Filter in TablePages when table is scrolled [message #1384547 is a reply to message #1384329] Thu, 29 May 2014 05:23 Go to previous messageGo to next message
Hi Jeremie,
No problem, I've guessed you were (are) busy (I also know that kind of problem Wink). So, thank you to have taken time to answer my question.
Bon courage Wink !
Didier.
Re: Column Filter in TablePages when table is scrolled [message #1384838 is a reply to message #1384547] Mon, 02 June 2014 09:15 Go to previous messageGo to next message
Hi Didier, Jérémie,
I just verified the problem with the 4.0.x and 4.1 (develop) branch. The problem occurs on both branches: I created bug 436361
Thanks for reporting.
Matthias
Re: Column Filter in TablePages when table is scrolled [message #1385072 is a reply to message #1384838] Wed, 04 June 2014 04:22 Go to previous messageGo to next message
Hi Didier,
we fixed the problem on the latest Scout branch. Can you test it with a version >= 04.06.2014 and report if your problems are solved now?
Matthias
Re: Column Filter in TablePages when table is scrolled [message #1385741 is a reply to message #1385072] Tue, 10 June 2014 17:15 Go to previous messageGo to next message
Hi Matthias,
I'm sorry for the delay : I've had few problems with update on my eclipse luna RC2. So, I installed RC3 and...all problems are now solved !
- "column filter" menu appears on every right clic and gives the good filter values,
- on large tables with right scroll, the "column filter" is now ok (good values ; no more shift problem)
Thanks Matthias, Jeremie (and all Scout Team!)
Re: Column Filter in TablePages when table is scrolled [message #1385766 is a reply to message #1385741] Wed, 11 June 2014 02:21 Go to previous message
Hi Didier,
glad it works now, and thank you very much for testing Smile
Matthias
Previous Topic:Scout usage from command line
Next Topic:Jetty server hook for configuration
Current Time: Wed Oct 15 17:49:44 EDT 2025
Powered by FUDForum. Page generated in 0.26630 seconds
