Home » Language IDEs » ServerTools (WTP) » Cursor Movement in WebEditor
Cursor Movement in WebEditor [message #212407] |
Tue, 15 April 2008 18:15 |
Eric Bresie Messages: 46 Registered: July 2009 |
Member |
Hey guys, not sure if this is a bug, my preferences, or some plugin, but..
I was using the Web Page Editor to work on an HTML file. The editor shows
the Design view with the raw HTML at the bottom pane and the rendered
version on the top pane.
In HTML editor pane, I can move around with the left and right arrow keys
one character at a time which works fine. I can do Ctrl+left/right keys
to move one word at a time. Home and End key move me to the start or end
of the line.
Now the problem...when I attempt to move left and right in the rendered
pane, I can move single character left and right but when Ctrl+left/right
key is pressed, it still only moves a single character. The Home and End
key do nothing.
My configuration follows.
Eric Bresie
ebresie@gmail.com
*** Date: Tuesday, April 15, 2008 1:02:59 PM CT
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
birt.viewer.working.path=E:\workspace\.metadata\.plugins\org .eclipse.birt.report.viewer
eclipse.buildId=M20071023-1652
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
E:\eclipse\\plugins\org.eclipse.platform_3.3.3.r33x_r2008012 9\splash.bmp
-launcher
E:\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
E:\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32. x86_1.0.3.R33x_v20080118\eclipse_1023.dll
-startup
E:\eclipse\plugins\org.eclipse.equinox.launcher_1.0.1.R33x_v 20080118.jar
-vm
C:\Program Files\Java\jdk1.6.0_04\bin\..\jre\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1208266086213
eclipse.vm=C:\Program Files\Java\jdk1.6.0_04\bin\..\jre\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
-XX:MaxPermSize=256M
-Djava.class.path=E:\eclipse\plugins\org.eclipse.equinox.lau ncher_1.0.1.R33x_v20080118.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=E:\eclipse\plugins\org.eclipse.equinox.launc her_1.0.1.R33x_v20080118.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jdk1.6.0_04\jre\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jdk1.6.0_04\jre\lib\ext;C:\WINDOWS\Sun\Java\lib\e xt
java.home=C:\Program Files\Java\jdk1.6.0_04\jre
java.io.tmpdir=C:\DOCUME~1\ebresie\LOCALS~1\Temp\
java.library.path=E:\eclipse;.;C:\WINDOWS\Sun\Java\bin;C:\WI NDOWS\system32;C:\WINDOWS;C:\Program
Files\Java\jdk1.6.0_04\bin\..\jre\bin\client;C:\Program
Files\Java\jdk1.6.0_04\bin\..\jre\bin;C:\Program
Files\Java\jdk1.6.0_04\bin;c:\ruby\bin;C:\Perl\bin\;C:\Progr am
Files\CA\DCS\CAWIN\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOW S\System32\Wbem;C:\Program
Files\CA\SharedComponents\CAM\bin;C:\CA_APPSW;C:\PROGRA~1\CO EMES~1\bin;C:\WINDOWS\system32\;C:\Program
Files\JavEMES~1\bin;C:\WINDOWS\system32\;C:\h\IFL\bin;C:\h\T MS\bin;C:\Program
Files\CA\Unicenter DSM\bin;c:\Program Files\Microsoft SQL
Server\90\Tools\binn\;C:\Program
Files\QuickTime\QTSystem\;C:\Mapcore50\Bin;C:\JavaLibs\bin;C :\Program
Files\TENET\MapLink Pro\5.2\bin;C:\doxygen\doxygen\bin;C:\Program
Files\Java\jdk1.6.0_04\bin;C:\PROGRA~1\Java\J2RE14~1.1_0\bin ;C:\PROGRA~1\Java\J2RE14~1.1_0\bin\client;C:\Program
Files\Java\j2re1.4.1_02\bin;C:\Program
Files\Java\j2re1.4.1_02\bin\client;C:\Program
Files\cvsnt;C:\PROGRA~1\CA\ETRUST~1;C:\Program
Files\Rational\common;C:\Program Files\Rational\ClearCase\bin;C:\Program
Files\Graphviz2.16\Bin;C:\Program
Files\jEdit;e:\nios\altera\71\quartus\bin;C:\Program
Files\CA\SharedComponents\ScanEngine;C:\Program
Files\CA\SharedComponents\CAUpdate\;C:\Program
Files\CA\SharedComponents\ThirdParty\;C:\Program
Files\CA\SharedComponents\SubscriptionLicense\;;C:\Program
Files\STI\bin\pc-win95
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_04-b12
java.security.policy=/E:/eclipse/configuration/org.eclipse.o sgi/bundles/900/1/.cp/server.policy
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_04
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=10.0-b19
jazzy.config=com.bdaum.SpellChecker3.SpellCheckConfiguration
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.defaultlog=off
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.location=E:\eclipse\\plu gins\org.eclipse.platform_3.3.3.r33x_r20080129\splash.bmp
org.eclipse.mylyn.context.core.context.active=true
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.CurrentPackage,org.omg.PortableServer .POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg .PortableServer.portable,org.omg.PortableServer.ServantLocat orPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w 3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.eve nts,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w 3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=E:\eclipse\configuration\org.eclipse.osgi\b undles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/E:/eclipse/configuration/
osgi.framework=file:/e:/eclipse/plugins/org.eclipse.osgi_3.3 .2.R33x_v20080105.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.2.R33x_v20080105
osgi.install.area=file:/E:/eclipse/
osgi.instance.area=file:/E:/workspace/
osgi.instance.area.default=file:/C:/Documents and
Settings/ebresie/workspace/
osgi.logfile=E:\workspace\.metadata\.log
osgi.manifest.cache=E:\eclipse\configuration\org.eclipse.osg i\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=E:\eclipse\\plugins\org.eclipse.platform _3.3.3.r33x_r20080129\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=e:\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jdk1.6.0_04\jre\lib\resources.jar;C:\Program
Files\Java\jdk1.6.0_04\jre\lib\rt.jar;C:\Program
Files\Java\jdk1.6.0_04\jre\lib\sunrsasign.jar;C:\Program
Files\Java\jdk1.6.0_04\jre\lib\jsse.jar;C:\Program
Files\Java\jdk1.6.0_04\jre\lib\jce.jar;C:\Program
Files\Java\jdk1.6.0_04\jre\lib\charsets.jar;C:\Program
Files\Java\jdk1.6.0_04\jre\classes
sun.boot.library.path=C:\Program Files\Java\jdk1.6.0_04\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=E:\workspace\Journal
user.home=C:\Documents and Settings\ebresie
user.language=en
user.name=ebresie
user.timezone=America/Chicago
user.variant=
workspace.projectclasspath=E:\workspace\BPMProject\bin;E:\wo rkspace\Bug
6372808\bin;E:\workspace\ButtonDemo\bin;E:\workspace\Example Project\bin;E:\workspace\JEDI
Programs\bin;E:\Glassfish\samples\JEE
Quickstart\build\classes;E:\workspace\JUnitExamples\bin;/E:/ Java
Tutorial/deployment/webstart/examples/Notepad.jar;E:\My
EBooks\Programming\Java\Tutorial\Java
Tutorial\classes;/E:/java/jdk1.6.0_04/lib/ext/j3dcore.jar;/E :/java/jdk1.6.0_04/lib/ext/j3dutils.jar;/E:/java/jdk1.6.0_04 /lib/ext/joalmixer.jar;/E:/java/jdk1.6.0_04/lib/ext/vecmath. jar;E:\src\java\Java3D
Examples\src\classes;E:\workspace\MidletSuite\bin;E:\workspa ce\MyMidlet\bin;E:\workspace\WebServiceProject\build\classes ;E:\workspace\WorkbenchTutorial\bin;E:\workspace\action\bin; E:\workspace\door\bin;E:\workspace\headstartdesignpatterns\b uild\classes
*** Features:
AnyEditTools (1.9.3) "AnyEdit Tools"
com.bdaum.SpellChecker3 (3.2.4) "SpellChecker3 Plug-in"
com.bdaum.SpellChecker3src (3.2.4.0) "SpellChecker3src"
com.lowagie.itext (1.5.4.v20080225-043-w31191339) "Lowagie Itext"
com.vectrace.MercurialEclipse (0.2.239) "MercurialEclipse"
csdl.jupiter (2.2.706.3x) "Jupiter Review Plug-in"
eclipseme.feature (1.7.9) "EclipseME"
EclipseSkins (1.4.3) "Extended VS Presentation Plug-in"
FileSync (1.3.2.1) "FileSync Plug-in"
JDepend4Eclipse (1.2.1) "JDepend4Eclipse"
org.apache.batik (1.6.0.v20061222-1222-0842283444-3444) "Apache Batik"
org.apache.batik.pdf (1.6.0.v20060613-1220-0842282835-3442) "Bundle-Name"
org.apache.commons.codec (1.3.0.v20070907-02--w311817222849) "Apache
Commons Codec Plug-in"
org.apache.derby.core (10.1.2.1) "Apache Derby Core Plug-in for Eclipse"
org.eclipse.ajdt (1.5.2.200804102023) "AspectJ Development Tools"
org.eclipse.ajdt.source (1.5.2.200804102023) "Eclipse AspectJ Development
Tools Source Code"
org.eclipse.birt (2.2.2.r22x_v20071015-7M7M7L3OP4P3fZkIcJ9QOFI1cpYT)
"Business Intelligence and Reporting Tools"
org.eclipse.birt.chart (2.2.2.r22x_v20071015-7979782epMz0t2ifpV9GJ8D8unV9)
"BIRT Chart Framework"
org.eclipse.birt.chart.cshelp (2.2.2.r22x_v20071015-11--w31181736) "BIRT
Chart Context-sensitive Help"
org.eclipse.birt.chart.doc.isv (2.2.2.r22x_v20071015-11--w31181736) "BIRT
Chart ISV Documentation"
org.eclipse.birt.chart.runtime
(2.2.2.r22x_v20071015-7Y8l7DMVg4-_6uC7tmU8Y) "BIRT Chart Runtime"
org.eclipse.birt.chart.runtime.source
(2.2.2.r22x_v20071015-7Y8l7DMVg4-_6uC7tmU8Y) "BIRT Chart Runtime Source"
org.eclipse.birt.chart.source
(2.2.2.r22x_v20071015-7979782epMz0t2ifpV9GJ8D8unV9) "BIRT Chart Source
Plugin"
org.eclipse.birt.crosstab.source (2.2.2.r22x_v20071015-3330j777Nr733G577E)
"BIRT Source"
org.eclipse.birt.cshelp (2.2.2.r22x_v20071015-11--w31181733) "BIRT
org.eclipse.birt.doc (2.2.2.r22x_v20071015-110-s332Aw31181_2_) "BIRT
Documentation"
org.eclipse.birt.doc.isv (2.2.2.r22x_v20071015-110-s332Aw31181_24) "BIRT
ISV Documentation"
org.eclipse.birt.example (2.2.2.r22x_v20071015-7C7C7A55QQBJZTFDqGIOV)
"BIRT Example"
org.eclipse.birt.report.designer
(2.2.2.r22x_v20071015-7U7U7TB8R573QDLV82yqWWX8fppV) "BIRT Report Designer"
org.eclipse.birt.report.designer.source
Source"
org.eclipse.birt.report.runtime
(2.2.2.r22x_v20071015-7U7U7RBs-_N6u3VW7eooU) "BIRT Report Runtime"
org.eclipse.birt.report.runtime.source
(2.2.2.r22x_v20071015-7U7U7RBs-_N6u3VW7eooU) "BIRT Report Runtime Source
Plugin"
org.eclipse.birt.sdk (2.2.2.r22x_v20071015-7K7K7J5MyiE__nqDs-RAXyUz0QYv)
"BIRT SDK"
org.eclipse.birt.source
(2.2.2.r22x_v20071015-7M7M7L3OP4P3fZkIcJ9QOFI1cpYT) "BIRT Source Plugin"
org.eclipse.buckminster.core.feature (1.0.0.r09041) "Buckminster UI
Plug-in"
org.eclipse.buckminster.cvs.feature (1.0.0.r09008) "Buckminster CVS
Plug-in"
org.eclipse.buckminster.maven.feature (1.0.0.r08939) "Buckminster Maven
Plug-in"
org.eclipse.buckminster.p4.feature (1.0.0.r09016) "Buckminster Perforce UI
Plug-in"
org.eclipse.buckminster.pde.feature (1.0.0.r09041) "Buckminster PDE
Plug-in"
org.eclipse.buckminster.svn.feature (0.2.0.r3554) "Buckminster Subversion
Plug-in (Incubation)"
org.eclipse.cdt (4.0.3.200802251018) "Eclipse C/C++ Development Tools"
org.eclipse.cvs (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_) "Eclipse CVS
Client"
org.eclipse.cvs.source (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_)
"Eclipse CVS Client SDK"
org.eclipse.datatools.connectivity.feature (1.5.2.200802201) "Data Tools
Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.5.2.200802201)
"DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.5.2.200802201) "DTP Open
Data Access"
org.eclipse.datatools.doc.user (1.5.2.200802201) "Data Tools Platform User
Guide"
org.eclipse.datatools.enablement.apache.derby.feature (1.5.2.200802201)
"High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.5.2.200802201) "Eclipse Data
Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.5.2.200802201) "Eclipse
Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.5.2.200802201) "Eclipse
org.eclipse.datatools.enablement.jdbc.feature (1.5.2.200802201)
org.eclipse.datatools.enablement.msft.feature (1.5.2.200802201) "Eclipse
org.eclipse.datatools.enablement.mysql.feature (1.5.2.200802201) "Eclipse
org.eclipse.datatools.enablement.oda.designer.feature (1.5.2.200802201)
"Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.5.2.200802201) "Eclipse
Data Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.5.2.200802201) "Eclipse
org.eclipse.datatools.enablement.postgresql.feature (1.5.2.200802201)
"Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.5.2.200802201)
org.eclipse.datatools.intro (1.5.2.200802201) "Eclipse Data Tools Platform
Intro Plug-in"
org.eclipse.datatools.modelbase.feature (1.5.2.200802201) "Eclipse Data
Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sdk.feature (1.5.2.200802201) "Data Tools Platform
Source Code"
org.eclipse.datatools.sqldevtools.feature (1.5.2.200802201) "Eclipse Data
Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.dd.dsf.gdb (0.9.0.v20070615) "Debug Services Framework GDB
Core Plug-in"
org.eclipse.dd.ipxact (0.2.2.v20080405) "Bundle-Name.0"
org.eclipse.dltk.core (0.9.2.v20080226-1047-08O78E8IaRUDKuX65LAUY)
"Eclipse Dynamic Languages Toolkit (Incubation)"
org.eclipse.dltk.core.source (0.9.2.v20080226-1047-08O78E8IaRUDKuX65LAUY)
"Dynamic Languages Toolkit Core Source (Incubation)"
org.eclipse.dltk.ruby (0.9.2.v20080226-1047-07q4BUISWQEQGb5QALG) "Ruby
Development Tools (Incubation)"
org.eclipse.dltk.ruby.source (0.9.2.v20080226-1047-07q4BUISWQEQGb5QALG)
"Dynamic Languages Toolkit (DLTK) Ryby IDE Source"
org.eclipse.dltk.tcl (0.9.2.v20080226-1047-07z3CQMUYYGcJx4N998) "Tcl
org.eclipse.dltk.tcl.source (0.9.2.v20080226-1047-07z3CQMUYYGcJx4N998)
"Dynamic Languages Toolkit (DLTK) TCL IDE Source"
org.eclipse.eclipsemonkey (1.0.0.200706060947) "Eclipse Monkey
(Incubation)"
org.eclipse.emf (2.3.2.v200802051830) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.cdo (0.7.1.v200610021452) "CDO"
org.eclipse.emf.cdo.client (0.7.1.v200610021452) "CDO Client Framework"
org.eclipse.emf.cdo.dbgen (0.7.1.v200610021452) "CDO DBGen Framework"
org.eclipse.emf.cdo.doc (0.7.1.v200610021452) "CDO Documentation"
org.eclipse.emf.cdo.jdbc (0.7.1.v200610021452) "CDO JDBC Framework"
org.eclipse.emf.cdo.server (0.7.1.v200610021452) "CDO Server Framework"
org.eclipse.emf.cdo.source (0.7.1.v200610021452) "CDO Source"
org.eclipse.emf.codegen (2.3.1.v200802051830) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.3.2.v200802051830) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.3.1.v200802051830) "EMF Ecore Code
Generation UI"
org.eclipse.emf.codegen.ui (2.3.1.v200802051830) "EMF Template Code
Generator UI"
org.eclipse.emf.common (2.3.1.v200802051830) "EMF Common"
org.eclipse.emf.common.ui (2.3.1.v200802051830) "EMF Common UI"
org.eclipse.emf.converter (2.3.1.v200802051830) "EMF Model Convert Support"
org.eclipse.emf.doc (2.3.2.v200802051830) "Eclipse Modeling Framework
(EMF) Programmers Guide"
org.eclipse.emf.ecore (2.3.2.v200802051830) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.1.v200802051830) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.3.1.v200802051830) "Sample Ecore Editor"
org.eclipse.emf.ecore.sdo (2.3.1.v200802051830) "EMF Service Data Objects
(SDO)"
org.eclipse.emf.ecore.sdo.doc (2.3.2.v200802051830) "EMF Service Data
Objects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.edit (2.3.1.v200802051830) "EMF Service Data
Objects (SDO) Edit Support"
org.eclipse.emf.ecore.sdo.editor (2.3.1.v200802051830) "EMF Service Data
Objects (SDO) Editor"
org.eclipse.emf.ecore.sdo.source (2.3.2.v200802051830) "EMF Service Data
Objects (SDO) Source"
org.eclipse.emf.edit (2.3.2.v200802051830) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI"
org.eclipse.emf.examples (2.3.1.v200802051830) "Eclipse Modeling Framework
(EMF) Examples"
org.eclipse.emf.examples.source (2.3.1.v200802051830) "Eclipse Modeling
Framework (EMF) Examples"
org.eclipse.emf.mapping (2.3.1.v200802051830) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.1.v200802051830) "Eclipse Modeling
Framework (EMF) - org.eclipse.emf.mapping.ecore"
org.eclipse.emf.mapping.ecore.editor (2.3.1.v200802051830) "Eclipse
Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
org.eclipse.emf.mapping.ui (2.3.1.v200802051830) "EMF Mapping UI"
org.eclipse.emf.ocl (1.1.1.v200709121956-1007w31181_232_67) "Object
Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.ocl.doc (1.1.0.v200706071450-10-7w311817182561) "Object
Constraint Language (OCL) 2.0 Compatibility API Documentation"
org.eclipse.emf.ocl.examples (1.1.0.v200706071450-32-9oA55P5M5P8GJ5)
"Object Constraint Language (OCL) 2.0 Examples"
org.eclipse.emf.ocl.examples.source (1.1.0.v200706071450) "Object
Constraint Language (OCL) 2.0 Examples Source"
org.eclipse.emf.ocl.source (1.1.1.v200709121956-1007w31181_232_67) "Object
Constraint Language (OCL) 2.0 Compatibility Source"
org.eclipse.emf.query (1.1.1.v200711281714-1007w311822392825) "EMF Model
Query"
org.eclipse.emf.query.doc (1.1.0.v200706071712-21-8s733G3E4C5B76) "EMF
Model Query Documentation"
org.eclipse.emf.query.examples (1.1.0.v200706071712-428Y_kE77Y7U9QAOEC)
"EMF Model Query Examples"
org.eclipse.emf.query.examples.source (1.1.0.v200706071712) "EMF Model
Query Examples Source"
org.eclipse.emf.query.ocl (1.1.0.v200706071712-10-7w311817182823) "EMF
Model Query OCL Integration"
org.eclipse.emf.query.ocl.source (1.1.0.v200706071712-10-7w311817182823)
"EMF Model Query OCL Integration Source"
org.eclipse.emf.query.source (1.1.1.v200711281714-1007w311822392825) "EMF
Model Query Source"
org.eclipse.emf.source (2.3.2.v200802051830) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.emf.transaction (1.1.2.v200710151610-208a8s733G4A3F5H88) "EMF
Model Transaction Core"
org.eclipse.emf.transaction.doc (1.1.0.v200706071723-208Y8s733G3E3G5G79)
"EMF Model Transaction Documentation"
org.eclipse.emf.transaction.examples
(1.0.100.v200706071723-3-Ag8x8FlRtR_NWNVFQ9QBE) "EMF Model Transaction
Examples"
org.eclipse.emf.transaction.examples.source (1.0.100.v200706071723) "EMF
Model Transaction Examples Source"
org.eclipse.emf.transaction.source
(1.1.2.v200710151610-208a8s733G4A3F5H88) "EMF Model Transaction Source"
org.eclipse.emf.validation (1.1.1.v200708161445-318Z9oA55P5O6O8IC_) "EMF
Validation Framework Core"
org.eclipse.emf.validation.doc (1.1.0.v200706071520-21-8s733G3E4C5_88)
"EMF Validation Framework Documentation"
org.eclipse.emf.validation.examples
(1.1.0.v200706071520-52_7AgI99h9cAZDRKI) "EMF Validation Framework Example"
org.eclipse.emf.validation.examples.source (1.1.0.v200706071520) "EMF
Validation Framework Examples Source"
org.eclipse.emf.validation.ocl (1.1.0.v200706071520-10-7w311817182631)
"EMF Validation Framework OCL Integration"
org.eclipse.emf.validation.ocl.source
(1.1.0.v200706071520-10-7w311817182631) "EMF Validation Framework OCL
Integration Source"
org.eclipse.emf.validation.source (1.1.1.v200708161445-318Z9oA55P5O6O8IC_)
"EMF Validation Framework Source"
org.eclipse.emf.workspace (1.1.2.v200711281719-208a8s733G4A3F5H88) "EMF
Model Transaction Workbench Integration Core"
org.eclipse.emf.workspace.doc (1.1.0.v200706071723-10-7w311817182834) "EMF
Model Transaction Workbench Integration Documentation"
org.eclipse.emf.workspace.examples
(1.0.100.v200706071723-3-Ag9oA55P5M5P8PAD) "EMF Model Transaction
Workbench Integration Examples"
org.eclipse.emf.workspace.examples.source (1.0.100.v200706071723) "EMF
Model Transaction Workbench Integration Examples Source"
org.eclipse.emf.workspace.source (1.1.2.v200711281719-208a8s733G4A3F5H88)
"EMF Model Transaction Workbench Integration Source"
org.eclipse.eodm (0.9.1.v200710090302) "pluginName (Incubation)"
org.eclipse.eodm.doc (0.9.1.v200710090302) "Plugin.name (Incubation)"
org.eclipse.eodm.source (0.9.1.v200710090302) "EODM Source"
org.eclipse.equinox.source (3.3.1.R33x_r20070918-7n7LEClEIdwb-bbP_z--EYAO)
"Equinox bundle source plug-in"
org.eclipse.gef (3.3.2.v20080129) "Graphical Editing Framework"
org.eclipse.gef.examples (3.3.1.v20070814) "Graphical Editing Framework
Examples Source"
org.eclipse.gef.sdk (3.3.2.v20080129) "Graphical Editing Framework
Developer Resources"
org.eclipse.gef.source (3.3.2.v20080129) "Graphical Editing Framework
org.eclipse.gmf (1.0.101.v20080114-2222-7d-EVOEYjiMWaZ4YWeu3dCypkm71)
"Graphical Modeling Framework"
org.eclipse.jdt (3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7)
"Eclipse Java Development Tools"
org.eclipse.jdt.source (3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7)
"Eclipse Java Development Tools SDK"
org.eclipse.jem (1.2.4.v200704181020--6zXJK0L0SE3a95) "Java EMF Model"
org.eclipse.jem.sdk (1.2.4.v200704140333-GIHlkYKbOQv_rA7) "Java EMF Model
SDK"
org.eclipse.jem.source (1.2.4.v200704181020--6zXJK0L0SE3a95) "Java EMF
Model Source"
org.eclipse.jet (0.8.2.v20071206-17E29oA55Q5O9G) "Eclipse Modeling
Framework Technologies - JET (Incubation)"
org.eclipse.jet.doc (0.8.0.v20070913-07707w31181_31) "Eclipse Modeling
Framework Technologies - JET Documentation (Incubation)"
org.eclipse.jet.examples (0.8.0.v20070913-077-7w31181_24) "Eclipse
Modeling Framework Technologies - JET Examples (Incubation)"
org.eclipse.jet.source (0.8.2.v20071206) "Eclipse Model to Text - JET SDK"
org.eclipse.jpt.feature.source (1.0.2.v200802140100-77-7_CYQCD2CaLYCHCD)
"Dali Java Persistence API (JPA) Tools"
org.eclipse.jst (2.0.2.v200802150100-7B-7_8dDTOvmuz0di_U5vgUfz0em) "J2EE
Standard Tools (JST)"
org.eclipse.jst.common_core.feature.source
(2.0.0.v200706041905-1007w311817231426) "J2EE Standard Tools - Common Core
Source"
org.eclipse.jst.enterprise_core.feature.source
(2.0.2.v200802150100-42Au_kE77c7EAgE7I7) "J2EE Standard Tools - Enterprise
Core Source"
org.eclipse.jst.enterprise_ui.feature.source
(2.0.2.v200802150100-7b7_Es8EU6AXOV9QLJSees1SQoYQ) "J2EE Standard Tools -
Enterprise UI Source"
org.eclipse.jst.sdk (2.0.2.v200802150100-7F-7D8fNerpqc2VheGP-mWEPz-u9)
"J2EE Standard Tools (JST)"
org.eclipse.jst.server_adapters.feature.source
(2.0.2.v200802150100-787KE8iDUUEF6GwKwpHEQ) "J2EE Standard Tools - Server
Adapters Source"
org.eclipse.jst.server_core.feature.source
(2.0.2.v200802150100-56CQ9rC7EK_UAblGAD2537) "J2EE Standard Tools - Server
Core Source"
org.eclipse.jst.server_ui.feature.source
(2.0.2.v200802150100-77-CT9yJXEkuiKVeQrclqTHQ3648) "J2EE Standard Tools -
Server UI Source"
org.eclipse.jst.web_core.feature.source
(2.0.300.v200802200333-7Q7AE7JEHhHeh0hI5y-QGB) "J2EE Standard Tools - Web
Core Source"
org.eclipse.jst.web_ui.feature.source
(2.0.2.v200802150100-7B1DzCkuNa_RPevwkwB1iJ6z-0RH) "J2EE Standard Tools -
Web UI Source"
org.eclipse.jst.webpageeditor.feature.source
(1.0.1.v200709110605-3-29oA55P5V8A) "Web Page Editor Source"
org.eclipse.mylyn_feature (2.3.2.v20080402-2100) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (2.3.2.v20080402-2100) "Mylyn"
org.eclipse.mylyn.context_feature (2.3.2.v20080402-2100) "Mylyn"
org.eclipse.mylyn.ide_feature (2.3.2.v20080402-2100) "Mylyn"
org.eclipse.mylyn.java_feature (2.3.2.v20080402-2100) "Mylyn"
org.eclipse.mylyn.jira_feature (2.3.2.v20080402-2100) "Mylyn"
org.eclipse.mylyn.monitor_feature (2.3.2.v20080402-2100) "Mylyn"
org.eclipse.mylyn.pde_feature (2.3.2.v20080402-2100) "Mylyn"
org.eclipse.mylyn.trac_feature (2.3.2.v20080402-2100) "Mylyn"
org.eclipse.mylyn.web.tasks_feature (2.3.2.v20080402-2100) "Mylyn"
org.eclipse.mylyn.xplanner_feature (2.3.2.v20080402-2100) "Mylyn XPlanner
Connector UI"
org.eclipse.net4j (0.7.1.v200610021152) "Net4j"
org.eclipse.net4j.doc (0.7.1.v200610021152) "Net4j Documentation"
org.eclipse.net4j.source (0.7.1.v200610021152) "Net4j Source"
org.eclipse.ocl (1.1.2.v200711262212-3219oA55P6H8I9HDE) "Object Constraint
Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.ocl.doc (1.1.0.v200706071450-21-8s733G3E3G5AC3) "Object
Constraint Language (OCL) 2.0 Documentation"
org.eclipse.ocl.source (1.1.2.v200711262212-3219oA55P6H8I9HDE) "Object
Constraint Language (OCL) 2.0 Source"
org.eclipse.ocl.uml (1.1.1.v200707131415-1007w311818242526) "OCL 2.0
Binding for UML"
org.eclipse.ocl.uml.source (1.1.1.v200707131415-1007w311818242526) "OCL
2.0 Binding for UML Source"
org.eclipse.pde (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL) "Eclipse
Plug-in Development Environment"
org.eclipse.pde.source (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL)
"Eclipse Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft) "Eclipse
Platform"
org.eclipse.platform.source (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc) "Eclipse
RCP"
org.eclipse.rcp.source (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc)
"Eclipse RCP Plug-in Developer Resources"
org.eclipse.releng.tools (3.2.100.v20070122-32-7w31181523) "RelEng Plug-in"
org.eclipse.rse (2.0.3.v20080225-7D-7A8mJIoa9WAvksISSE8yz-C) "Remote
System Explorer End-User Runtime"
org.eclipse.rse.core (2.0.3.v20080225-7P-7IEB7sQRz0SoiTb) "Remote System
Explorer Core"
org.eclipse.rse.core.source (2.0.3.v20080225-7P-7IEB7sQRz0SoiTb) "Remote
System Explorer Core Source"
org.eclipse.rse.dstore (2.0.1.v20070926-7F-4DUUEF6FALu) "RSE DStore
Services"
org.eclipse.rse.dstore.source (2.0.1.v20070926-7F-4DUUEF6FALu) "RSE DStore
Services Source"
org.eclipse.rse.examples (2.0.0.v20070609-6--9oA55P5M7Q) "Remote System
Explorer Examples"
org.eclipse.rse.ftp (2.0.3.v20080225-7737D_kE77a7PDI4I7B) "RSE FTP Service"
org.eclipse.rse.ftp.source (2.0.3.v20080225-7737D_kE77a7PDI4I7B) "RSE FTP
Service Source"
org.eclipse.rse.local (2.0.1.v20070705-7_-2AgI99h9l9l) "RSE Local Services"
org.eclipse.rse.local.source (2.0.1.v20070705-7_-2AgI99h9l9l) "RSE Local
Services Source"
org.eclipse.rse.remotecdt (2.0.1.v20070926-4-18s733G3K5H) "Remote System
Explorer C/C++ Remote Debug Launcher"
org.eclipse.rse.sdk (2.0.3.v20080225-7J-7EE7ZoHQURqoFwQQpz0MuGUHD) "Remote
System Explorer Extender SDK"
org.eclipse.rse.ssh (2.0.3.v20080225-78-6_kE77a7OAU) "RSE SSH Services"
org.eclipse.rse.ssh.source (2.0.3.v20080225-78-6_kE77a7OAU) "RSE SSH
Services Source"
org.eclipse.rse.telnet (2.0.1.v20070704-637AAgI99h9mBW4I7B) "RSE Telnet
Service"
org.eclipse.rse.telnet.source (2.0.1.v20070704-637AAgI99h9mBW4I7B) "RSE
Telnet Service Source"
org.eclipse.rse.tests (2.0.1.v20070926-6-19oA55P5SAG) "RSE Unit Tests"
org.eclipse.sdk (3.3.3.r33x_r20080129-7M7J7LB-u3aphGW6o3_VmiVfGXWO)
"Eclipse Project SDK"
org.eclipse.sdk.examples (3.1.200.v20070607-847XERgEE5Y56gOmWq8HKOG)
"Eclipse SDK Examples"
org.eclipse.stp.soas.feature (0.7.0.200711162004) "STP SOAS Deploy Core
(Incubation)"
org.eclipse.tm.discovery (2.0.0.v20070611-7J--E8McIJNJCPr) "Target
Management Service Discovery Engine"
org.eclipse.tm.terminal (1.0.3.v20080225-1-27w31191336) "Target Management
Terminal Widget"
org.eclipse.tm.terminal.serial (1.0.2.v20071030-1-17w31182141) "Target
Management Terminal Serial Connector"
org.eclipse.tm.terminal.ssh (1.0.3.v20080225-1-27w31191336) "Target
Management Terminal SSH Connector"
org.eclipse.tm.terminal.telnet (1.0.3.v20080225-1-27w31191336) "Target
Management Terminal Telnet Connector"
org.eclipse.tm.terminal.view (1.0.3.v20080225-1-27w31191336) "Target
Management Terminal View"
org.eclipse.tptp.monitoring (4.4.2.v200802070100-7c7KEK28DcIJUKhJAIiNP)
"TPTP Monitoring"
org.eclipse.tptp.monitoring.doc.user
(4.3.102.v200802070100-774Aj0r733I373F3533) "TPTP Monitoring Project
Documentation"
org.eclipse.tptp.monitoring.examples
(4.3.102.v200802070100-328a-w311913191211) "User examples for the TPTP
Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.instrumentation
(4.3.2.v200802070100-7A7951mA55S5A5S5855) "TPTP Instrumentation Monitoring
org.eclipse.tptp.monitoring.la.core
(4.4.2.v200802070100-7A78_A1mA55R5E5K5855) "Monitoring Log Analyzer Core"
org.eclipse.tptp.monitoring.managedagent
(4.4.2.v200802070100-7E7D8f2hE77c7E7Z7A77) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents
(4.4.100.v200802050100-338Y-w311912371211) "JMX Managed Agent"
org.eclipse.tptp.monitoring.mx4j.jmx
(4.4.1.v200802221314-2-2-w311913161211) "MX4J"
org.eclipse.tptp.monitoring.profile.server
(4.2.102.v200802070100-318a-w311913191211) "TPTP Profile On Server Logging
Utility"
org.eclipse.tptp.monitoring.profile.server.source (4.1.0.1) "TPTP Server
Log Import Source"
org.eclipse.tptp.monitoring.report.birt
(4.4.2.v200802070100-7A798d1mA55S5A5P6F_D) "BIRT Monitor Reports for TPTP
Branding Plugin"
org.eclipse.tptp.monitoring.report.birt.source (4.1.0.1) "BIRT Reporting
for TPTP Feature Source"
org.eclipse.tptp.monitoring.source (4.1.0.1) "TPTP Monitoring Source"
org.eclipse.tptp.platform.analysis
(4.4.2.v200802070100-7E7_Du2hE77b7L7X7A77) "TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java
(4.4.101.v200802070100-777730r733I373I3533) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine
(4.3.200.v200709030100-773Dp0r733H3D3A3533) "TPTP Analysis Engine"
org.eclipse.tptp.platform.analysis.engine.source (4.1.0) "TPTP Analysis
Engine Source"
org.eclipse.tptp.platform.analysis.source (4.1.0) "TPTP Analysis Feature
Source"
org.eclipse.tptp.platform.core
(4.4.100.v200709030100-8Q82EeRJEPilTjotXnOr2) "TPTP Platform"
org.eclipse.tptp.platform.core.doc.user
(4.3.200.v200709030100-7A6E9w1mA55Q5N6J5855) "TPTP Platform Project
Documentation"
org.eclipse.tptp.platform.core.source (4.1.0.1) "TPTP Core Source"
org.eclipse.tptp.platform.deprecated (4.1.0) "Deprecated plugins of
Platform project"
org.eclipse.tptp.platform.doc.user
(4.3.200.v200709030100-7A77E8O08IKQLvAsOHBfAU_O9B66) "TPTP Platform
Project Documentation"
org.eclipse.tptp.platform.examples
(4.3.200.v200709030100-32_7-w31181_141211) "TPTP Platform Examples"
org.eclipse.tptp.platform.instrumentation.ui
(4.2.100.v200709050100-321-w311913191211) "Instrument Core UI"
org.eclipse.tptp.platform.integration.pde
(4.4.1.v200802050100-330-w311913161211) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.jvmti
(4.3.100.v200709030100-7777_70r733I3777595A) "TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.la.core
(4.3.200.v200709030100-328a-w311913191211) "Log Analysis Core"
org.eclipse.tptp.platform.lta (4.3.200.v200709030100-773CG0r733H3D584747)
"TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.lta.source (4.1.0) "TPTP Log and Trace Analyzer
Source"
org.eclipse.tptp.platform.probekit
(4.3.200.v200709030100-7E5EFB2hE77Z7Z7K7A77) "TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user
(4.3.200.v200709030100-31_7-w31181_141211) "Probekit User Documentation"
org.eclipse.tptp.platform.probekit.source (4.1.0) "TPTP ProbeKit Source"
org.eclipse.tptp.platform.profile.server
(4.3.100.v200709030100-7E79_C2hE77b7L9R8C8A) "TPTP Profile on Server"
org.eclipse.tptp.platform.profile.server.source (4.1.0.1) "TPTP Profile on
Server Source"
org.eclipse.tptp.platform.report
(4.2.200.v200709030100-7A5Dq1mA55R5H5H5855) "TPTP Charting Service"
org.eclipse.tptp.platform.report.birt
(4.3.200.v200709030100-77778a0r733I364J3533) "BIRT Reporting for TPTP
Branding plugin"
org.eclipse.tptp.platform.report.birt.source (4.1.0.1) "BIRT Reporting for
org.eclipse.tptp.platform.report.source (4.1.0.1) "TPTP Charting Service
Source"
org.eclipse.tptp.platform.samples
(4.3.200.v200709030100-7A4E9x1mA55Q5O5F5855) "TPTP Platform Samples"
org.eclipse.tptp.platform.samples.source (4.1.0) "TPTP Platform Samples
Source"
org.eclipse.tptp.platform.statistical.report.birt
(4.4.100.v200709030100-77778a0r733H3D3D3533) "BIRT Statistical Reports for
TPTP Branding Plugin"
org.eclipse.tptp.platform.statistical.ui
(4.1.400.v200709030100-772Dq0r733H3D584A43) "TPTP Statistical UI"
org.eclipse.tptp.platform.statistical.ui.source (4.1.0) "TPTP Statistical
UI Source"
org.eclipse.tptp.platform.trace
(4.3.200.v200709030100-7E7ADs2hE77a7S9M8G87) "TPTP Platform Trace"
org.eclipse.tptp.platform.trace.source (4.1.0.1) "TPTP Platform Trace
Source"
org.eclipse.tptp.test (4.3.200.v200709070956-7I7AEGm3cI99l9OBa_NEI) "TPTP
Test"
org.eclipse.tptp.test.doc.user (4.3.200.v200709070956-328Y-w3119122_1211)
"Test Tools User Documentation"
org.eclipse.tptp.test.report.birt
(4.3.200.v200801190100-7A7A_91mA55R5G6S5F_A) "BIRT Test Reports for TPTP
Branding Plugin"
org.eclipse.tptp.test.report.birt.source (4.1.0.1) "BIRT Reporting for
org.eclipse.tptp.test.samples (4.2.100.v200709070956-318Y-w3119122_1211)
"TPTP Test Samples"
org.eclipse.tptp.test.samples.source (4.1.0) "TPTP Test Samples Source"
org.eclipse.tptp.test.source (4.1.0.1) "TPTP Test Source"
org.eclipse.tptp.test.tools
(4.3.200.v200709070956-7E7CE8M1vNDHhvJwZCOeLH9N7IBF) "TPTP Test Tools"
org.eclipse.tptp.test.tools.junit
(4.4.100.v200709070956-7A7ADo1mA55R5G8M6HAE) "TPTP JUnit Plugin Test Tools"
org.eclipse.tptp.test.tools.source (4.1.0) "TPTP Test Tools Source"
org.eclipse.tptp.trace (4.2.100.v200709070956-771EC30r733H3C4I3C89) "TPTP
Trace"
org.eclipse.tptp.trace.arm (4.2.100.v200709260100-772_70r733H3C4I3C89)
"TPTP ARM Monitoring "
org.eclipse.tptp.trace.arm.ui (4.3.100.v200709260100-7758Z0r733I364G3533)
"Instrument ARM UI"
org.eclipse.tptp.trace.jvmti (4.2.100.v200709260100-338Y-w31181_141211)
"TPTP Trace JVMTI Client"
org.eclipse.tptp.trace.report.birt
(4.4.100.v200801190100-7A7AAg1mA55R5F7T5F_A) "BIRT Trace Reports for TPTP
Branding Plugin"
org.eclipse.tptp.trace.report.birt.source (4.1.0.1) "BIRT Reporting for
org.eclipse.tptp.trace.source (4.1.0) "TPTP Trace Source"
org.eclipse.uml2 (2.1.1.v200708301222) "UML2"
org.eclipse.uml2.diagram (0.7.101.v200802260712) "UML2 Diagramming Plug-in
(Incubation)"
org.eclipse.uml2.diagram.source (0.7.101.v200802260712) "UML2 Diagramming
Source"
org.eclipse.uml2.doc (2.1.1.v200707181556) "UML2 Documentation"
org.eclipse.uml2.examples (2.1.0.v200706251652) "UML2 Examples"
org.eclipse.uml2.examples.source (2.1.0.v200706251652) "UML2 Examples
Source"
org.eclipse.uml2.source (2.1.1.v200708301222) "UML2 Source"
org.eclipse.uml2tools (0.7.101.v200802260712) "UML2 Tools Plug-in
(Incubation)"
org.eclipse.uml2tools.doc (0.7.0.v200802260712) "UML2 Tools Documentation
Plug-in"
org.eclipse.ve (1.3.0.200802040250) "Visual Editor"
org.eclipse.ve.sdk (1.2.1.v20060825_M-u0g6E989Ug_OQPH) "Visual Editor SDK"
org.eclipse.ve.source (1.2.1.v20060817_M-zXJUB0fx_-eyDdh) "Visual Editor
Source"
org.eclipse.wst (2.0.2.v200802150100-7C-7C8k0JWR293WFMOOObjNnnqho) "Web
Standard Tools (WST)"
org.eclipse.wst.common_core.feature.source
(2.0.2.v200802150100-7C78EKOE_EkMNlO6f7cjpz0) "Web Standard Tools - Common
Core Source"
org.eclipse.wst.common_ui.feature.source
(2.0.2.v200802150100-7C5EH3E9RvTVnirrspVz0bmP7g8d) "Web Standard Tools -
Common UI Source"
org.eclipse.wst.sdk (2.0.2.v200802150100-7E-7E8aNek-SRfrjr6TqAZAYKdiU)
"Web Standard Tools (WST)"
org.eclipse.wst.server_core.feature.source
(2.0.2.v200802150100-2-CN8s733H3_3Ic) "Web Standard Tools - Server Core
Source"
org.eclipse.wst.server_ui.feature.source
(2.0.2.v200802150100-77-CX9vCXDkvWGPlAMGMi447) "Web Standard Tools -
Server UI Source"
org.eclipse.wst.web_core.feature.source
(2.0.2.v200802150100-42CN_kE77a8F9XCOEL) "Web Standard Tools - Web Core
Source"
org.eclipse.wst.web_ui.feature.source
(2.0.2.v200802150100-7A0EAlCiWfJKsCZoChvz0dMYOb) "Web Standard Tools - Web
UI Source"
org.eclipse.wst.ws_core.feature.source
(2.0.2.v200802150100-7E7KEB2EC3wSU5UghChM0v) "Web Standard Tools - Web
Service Core Source"
org.eclipse.wst.ws_ui.feature.source
(2.0.2.v200802150100-791ECIAufYO9BlarnPCFGewtZiN1) "Web Standard Tools -
Web Service UI Source"
org.eclipse.wst.xml_core.feature.source
(2.0.2.v200802150100-787BE_4CYQCD-DaQMIfPd) "Web Standard Tools - XML Core
Source"
org.eclipse.wst.xml_ui.feature.source
(2.0.2.v200802150100-7A1ECMCnbcl1bVs9uNm_Zkieb7Qe) "Web Standard Tools -
XML UI Source"
org.eclipse.xsd (2.3.2.v200802051830) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.3.2.v200802051830) "XML Schema Infoset Model (XSD)
Programmers Guide"
org.eclipse.xsd.ecore.converter (2.3.2.v200802051830) "XML Schema Infoset
Model (XSD) - org.eclipse.xsd.ecore.converter"
org.eclipse.xsd.edit (2.3.0.v200802051830) "XML Schema Edit Framework"
org.eclipse.xsd.editor (2.3.0.v200802051830) "XML Schema Editor"
org.eclipse.xsd.mapping (2.3.0.v200802051830) "XML Schema Infoset Model
(XSD) - org.eclipse.xsd.mapping"
org.eclipse.xsd.mapping.editor (2.3.0.v200802051830) "XML Schema Infoset
Model (XSD) - org.eclipse.xsd.mapping.editor"
org.eclipse.xsd.source (2.3.2.v200802051830) "XML Schema Infoset Model
(XSD) Source"
org.mozilla.rhino (1.6.7.r22x_v20071217-056-s33yAw31191325) "Mozilla Rhino"
org.mx4j.jmx (4.3.0.v200610110100--08422833362322) "MX4J"
org.testng.eclipse (5.7.0.1) "TestNG"
org.tigris.subversion.subclipse (1.2.4) "SVN Team Provider Core"
org.tigris.subversion.subclipse.mylyn (2.0.0) "Subclipse Integration for
Mylar"
org.w3c.sac (1.3.0.v20070406-02--w31181821) "W3C Sac"
*** Plug-in Registry:
antenna.preprocessor.v2 (1.7.7) "Antenna Preprocessor Plug-in" [Starting]
ch.epfl.lamp.sdt.compiler (2.7.0.14321-final_0) "Compiler Plug-in"
[Starting]
ch.epfl.lamp.sdt.core (2.4.6) "Scala Development Tools Core" [Starting]
ch.epfl.lamp.sdt.debug (1.5.0) "Scala Debug Plug-in" [Starting]
ch.epfl.lamp.sdt.help (2.1.9) "Help Plug-in" [Resolved]
ch.epfl.lamp.sdt.ui (2.5.0) "Scala Development Tools UI" [Starting]
com.bdaum.SpellChecker.Cpp.NLsupport (3.2.3.0) "NL Support for C++
Spellchecker3" [Resolved]
com.bdaum.SpellChecker.HTML.NLsupport (3.2.3.0) "NL Support for HTML
com.bdaum.SpellChecker.Java.NLsupport (3.2.4.0) "NL Support for Java
com.bdaum.SpellChecker.NLsupport (3.2.3.0) "NL Support for Spellchecker3"
[Resolved]
com.bdaum.SpellChecker.Sql.NLsupport (3.2.3.0) "NL Support for Sq
Spellchecker3 Fragment" [Resolved]
com.bdaum.SpellChecker.Xml.NLsupport (3.2.3.0) "NL Support for XML
com.bdaum.SpellChecker3 (3.2.3) "SpellChecker3 Plug-in" [Active]
com.bdaum.SpellChecker3.Cpp (3.2.3) "SpellChecker for C++, Haskell, and
Python" [Starting]
com.bdaum.SpellChecker3.Html (3.2.4) "SpellChecker for HTML, JSP, PHP, and
RHTML" [Active]
com.bdaum.SpellChecker3.Java (3.2.4) "SpellChecker for AspectJ, Java,
JavaScript, Groovy, Scala, and Ruby" [Starting]
com.bdaum.SpellChecker3.Sql (3.2.3) "Sql Tokenizer Plug-in" [Starting]
com.bdaum.SpellChecker3.Xml (3.2.3) "SpellChecker for XML" [Starting]
com.bdaum.SpellChecker3src (3.2.4.0) "SpellChecker3src" [Resolved]
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Starting]
com.ibm.icu (3.6.1.v20070906) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.source (3.6.1.v20070906) "International Components for Unicode
for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
com.jdocs.eclipse.plugin (1.0.1) "JDocs Plugin" [Starting]
com.kyrsoft.stmemmon (1.1) "Status Memory Monitor" [Active]
com.lowagie.itext (1.5.4.v20080228) "Lowagie Itext" [Resolved]
com.pramati.jst.server (1.0.1) "Pramati Server definition." [Resolved]
com.sun.enterprise.jst.server.sunappsrv (1.0.2) "Sun Application Servers
and GlassFish Servers support" [Starting]
com.vectrace.MercurialEclipse (0.2.239) "MercurialEclipse" [Starting]
csdl.jupiter (2.2.706.3x) "Jupiter Review Plug-in" [Active]
de.kyrsoft.memmonitor (1.6.0) "Memmonitor Plug-in" [Starting]
de.loskutov.anyedit.AnyEditTools (1.9.3) "AnyEdit Tools" [Active]
de.loskutov.BytecodeOutline (2.2.3) "Bytecode Outline Plug-in" [Starting]
de.loskutov.eclipse.jdepend (1.2.1) "JDepend4Eclipse" [Starting]
de.loskutov.eclipseskins.extvs (1.4.3) "Extended VS Presentation Plug-in"
[Active]
de.loskutov.FileSync (1.3.2.1) "FileSync Plug-in" [Starting]
de.schlichtherle (6.6.0) "Truezip" [Resolved]
eclipseme.core (1.7.9) "EclipseME Core Plug-in" [Active]
eclipseme.core.hooks (1.6.5) "EclipseME Core Hooks Plug-in" [Active]
eclipseme.core.preverifier (1.6.7) "EclipseME Preverifier Plug-in" [Active]
eclipseme.core.resources (1.7.8) "EclipseME Resources Plug-in" [Starting]
eclipseme.docs (1.7.7) "EclipseME Docs Plug-in" [Starting]
eclipseme.feature.branding (1.6.5) "EclipseME" [Starting]
eclipseme.toolkit.me4se (1.7.7) "EclipseME ME4SE Support" [Starting]
eclipseme.toolkit.microemu (1.7.8) "EclipseME Microemulator Support"
[Starting]
eclipseme.toolkit.motorola (1.7.7) "EclipseME Motorola Plug-in" [Starting]
eclipseme.toolkit.mpowerplayer (1.7.7) "mpowerplayer Device Plug-in"
[Starting]
eclipseme.toolkit.siemens (1.6.6) "EclipseME Siemens Plug-in" [Starting]
eclipseme.toolkit.uei (1.7.8) "EclipseME Base UEI Support Plug-in" [Active]
eclipseme.ui (1.7.8) "EclipseME UI Plug-in" [Active]
edu.umd.cs.findbugs.plugin.eclipse (1.3.2.20080222) "FindBugs Plug-in"
[Starting]
javafx.eclipse.f3editor (0.0.2) "JavaFXeditor Plug-in" [Starting]
javax.management (1.2.0.v200706111329) "Java Management Extensions API"
[Resolved]
javax.management.remote (1.0.0.v200706111329) "Java Management Remote
Extensions API" [Resolved]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle"
[Resolved]
javax.servlet.jsp.source (2.0.0.v200706191603) "Java Server Pages API
Source Bundle" [Resolved]
javax.servlet.source (2.4.0.v200706111738) "Servlet API Source Bundle"
[Resolved]
javax.wsdl (1.4.0.v200706111329) "WSDL4J" [Resolved]
javax.wsdl15 (1.5.1.v200705290614) "WSDL4J" [Resolved]
javax.xml.rpc (1.1.0.v200706111329) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200706111329) "SAAJ" [Resolved]
net.sourceforge.eclipsesrs (2.0.2) "Srs Model" [Starting]
net.sourceforge.eclipsesrs.edit (2.0.2) "Srs Edit Support" [Starting]
net.sourceforge.eclipsesrs.editor (2.0.2) "Srs Editor" [Starting]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200706111738) "SourceForge LPG"
[Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200711021030) "SourceForge LPG"
[Resolved]
net.sourceforge.lpg.lpgjavaruntime.source (1.1.0.v200706111738)
"SourceForge LPG Source Bundle" [Resolved]
org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
org.apache.ant.source (1.7.0.v200706080842) "Apache Ant Source" [Resolved]
org.apache.axis (1.4.0.v200706191647) "Apache Web Services" [Resolved]
org.apache.batik (1.6.0.v20061222-1222) "Apache Batik" [Starting]
org.apache.batik.bridge (1.6.0.v200706111724) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200706111724) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200706111724) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200706111724) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.ext.awt (1.6.0.v200706111724) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.extension (1.6.0.v200706111724) "Apache Batik Extension"
[Resolved]
org.apache.batik.parser (1.6.0.v200706111724) "Apache Batik Parser"
[Resolved]
org.apache.batik.pdf (1.6.0.v20060613-1220) "Apache Batik Pdf" [Resolved]
org.apache.batik.pdf (1.6.0.v200706111329) "Bundle-Name" [Resolved]
org.apache.batik.svggen (1.6.0.v200706111724) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.swing (1.6.0.v200706111724) "Apache Batik Swing"
[Resolved]
org.apache.batik.transcoder (1.6.0.v200706111724) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200706111724) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200706111724) "Apache Batik GUI
org.apache.batik.xml (1.6.0.v200706111724) "Apache Batik XML" [Resolved]
org.apache.cactus (1.7.2.v200606181221) "Cactus Resource Plug-in"
[Starting]
org.apache.commons_logging (1.0.4.v200608011657) "Apache commons logging
Plug-in" [Resolved]
org.apache.commons.codec (1.2.0.v200706111724) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.codec (1.3.0.v200706111738) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.discovery (0.2.0.v200706111329) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.el.source (1.0.0.v200706111724) "Apache Commons JSP 2.0
Expression Language Interpreter Source" [Resolved]
org.apache.commons.httpclient (3.0.1.v200706111724) "Apache Commons
Httpclient Plug-in" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.logging.source (1.0.4.v200706111724) "Apache Commons
Logging Plug-in Source" [Resolved]
org.apache.commons.net (1.4.1.v200709210925) "Apache Jakarta Commons Net"
[Resolved]
[Starting]
org.apache.geronimo.deployment.model (2.0.0) "Geronimo V1 EMF Models"
[Installed]
org.apache.geronimo.deployment.model (2.1.0) "Geronimo V1 EMF Models"
[Resolved]
org.apache.geronimo.deployment.model.edit (2.0.0) "Geronimo V1 EMF Edit
Models" [Installed]
org.apache.geronimo.deployment.model.edit (2.1.0) "Geronimo V1 EMF Edit
Models" [Starting]
org.apache.geronimo.runtime.common (1.0.0) "Geronimo Common Runtime
Plug-in" [Installed]
org.apache.geronimo.runtime.common (2.0.0) "Geronimo Common Runtime
Plug-in" [Resolved]
org.apache.geronimo.runtime.v1 (1.0.1) "Geronimo V1 Runtime Plug-in"
[Installed]
org.apache.geronimo.runtime.v1 (2.0.0) "Geronimo V1 Runtime Plug-in"
[Installed]
org.apache.geronimo.runtime.v1 (2.1.0) "Geronimo V1 Runtime Plug-in"
[Resolved]
org.apache.geronimo.runtime.v11 (1.0.0) "Geronimo V11 Runtime Plug-in"
[Installed]
org.apache.geronimo.runtime.v11 (2.0.0) "Geronimo V11 Runtime Plug-in"
[Resolved]
org.apache.geronimo.runtime.v20 (2.0.0) "Geronimo V20 Runtime Plug-in"
[Resolved]
org.apache.geronimo.st.core (2.0.0) "Geronimo Server Tools Core Plug-in"
[Starting]
org.apache.geronimo.st.ui (2.0.0) "Geronimo Server Tools UI Plug-in"
[Starting]
org.apache.geronimo.st.v1.core (2.0.0) "Geronimo V1 Server Tools Core
org.apache.geronimo.st.v1.core (2.1.0) "Geronimo V1 Server Tools Core
Plug-in" [Starting]
org.apache.geronimo.st.v1.ui (2.0.0) "Geronimo Server Tools V1 UI Plug-in"
[Installed]
org.apache.geronimo.st.v1.ui (2.1.0) "Geronimo Server Tools V1 UI Plug-in"
[Starting]
org.apache.geronimo.st.v11.core (2.0.0) "Geronimo v11 Server Tools Core
Plug-in" [Starting]
org.apache.geronimo.st.v11.ui (2.0.0) "Geronimo Server Tools V11 UI
Plug-in" [Starting]
org.apache.geronimo.st.v20.core (2.0.0) "Geronimo v20 Server Tools Core
Plug-in" [Starting]
org.apache.geronimo.v11.deployment.model (2.0.0) "Geronimo V11 EMF Models"
[Resolved]
org.apache.geronimo.v11.deployment.model.edit (2.0.0) "Geronimo V11 EMF
Edit Models" [Starting]
org.apache.jakarta_log4j (1.2.8.v200607172048) "Apache Jakarta log4j
Plug-in" [Resolved]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.jasper.source (5.5.17.v200706111724) "Apache Jasper 2 Source
Plug-in" [Resolved]
org.apache.log4j (1.2.13.v200706111418) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene Analysis"
[Resolved]
org.apache.lucene.analysis.source (1.9.1.v200706181610) "Apache Lucene
Analysis Source" [Resolved]
org.apache.lucene.source (1.9.1.v200706111724) "Apache Lucene Source"
[Resolved]
org.apache.oro (2.0.8.v200706111724) "Apache Jakarta ORO" [Resolved]
org.apache.ws.commons.util (1.0.0.v200706111329) "WS Commons Util Plug-in"
[Resolved]
org.apache.ws.jaxme (0.5.1.v200706111329) "Apache JAX-ME Plug-in"
[Resolved]
org.apache.wsil4j (1.0.0.v200706111329) "WSIL4J" [Resolved]
org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver"
[Resolved]
org.apache.xmlrpc (3.0.0.v200706111329) "Apache XML-RPC Plug-in" [Resolved]
org.aspectj.ajde (1.6.0.20081300000002) "AspectJ" [Starting]
org.aspectj.runtime (1.6.0.20081300000002) "AspectJ Runtime" [Resolved]
org.aspectj.weaver (1.6.0.20081300000002) "AspectJ Weaver" [Resolved]
org.codehaus.groovy (1.5.1.200801232227) "Groovy Runtime Plug-in"
[Starting]
org.codehaus.groovy.eclipse (1.5.1.200801232227) "Groovy Core" [Active]
org.codehaus.groovy.eclipse.astviews (1.5.1.200801232227) "Groovy AST
Views" [Starting]
org.codehaus.groovy.eclipse.codeassist (1.5.1.200801232227) "Code Assist
Core" [Starting]
org.codehaus.groovy.eclipse.codeassist.completion (1.5.1.200801232227)
"Code Completion Plug-in" [Starting]
org.codeh
Current Time: Fri Sep 20 03:56:44 GMT 2024
Powered by FUDForum. Page generated in 0.03704 seconds
