How to verify that WebTools Platform is successfully installed? [message #212311] |
Mon, 14 April 2008 17:59 |
Originally posted by: under.lycos.co.uk
I downloaded wtp-S-3.0M6-20080404175400.zip
and extracted it into the appropriate directories of my Eclipse v3.2.2 installation.
Do I have to do something more to get WTP working ?
How can I verify that everything is successfully installed?
Are there any special menus in Eclipse which should appear after the WTP installation?
Jeff
Re: How to verify that WebTools Platform is successfully installed? [message #212324 is a reply to message #212311] |
Mon, 14 April 2008 19:29 |
Jeff,
Help->About Eclipse SDK and looking at features or plugins should let
you confirm the version that's active and present.
> Jeff
Re: How to verify that WebTools Platform is successfully installed? [message #212330 is a reply to message #212311] |
Mon, 14 April 2008 19:35 |
There would be additional entries in the Preferences dialog, but you
won't get a working installation mixing 3.0M6 with Eclipse
3.2.2--the 3.0 milestones are built for Eclipse 3.4 milestones. The
easiest way to get WTP it is to start with the Eclipse IDE for Java
EE Developers, available from
http://www.eclipse.org/downloads/moreinfo/jee.php . It includes
Eclipse 3.2.2 with the latest WTP release, currently 2.0.2. You can
also download WTP 2.0.2 directly from
http://download.eclipse.org/webtools/downloads/, as long as you take
note of and also install the "Required Prerequisites" listed at the top.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: How to verify that WebTools Platform is successfully installed? [message #212356 is a reply to message #212311] |
Tue, 15 April 2008 00:33 |
> Jeff
And, since it's not a commercial product, I feel safe putting in a plug
for Pulse (www.poweredbypulse.com) which will not only help you get all
this that you want (solving the very question you've just asked), but
will help you set up a profile so that you can duplicate it a) for
yourself on a subsequent development host and b) share your profile and
therefore development environment with others.
Russ Bateman
Re: How to verify that WebTools Platform is successfully installed? [message #212368 is a reply to message #212311] |
Tue, 15 April 2008 10:09 |
Assuming you unzipped the four prerequisite archives too, no.
Window > Show View > Other... Plug-in Regsitry
The now appearing Plug-in registry view displays all currently
available Plug-ins of your Eclipse instance.
You should see a bunch of org.eclipse.jst.* and org.eclipse.wst.*
plug-ins. Quickly browse through the list and check that no plug-in icon
has a red error marker.
> WTP installation?
Yes, WTP adds many things. One of the easiest to check is whether the
WTP specific project types are avialbe in the new project wizard:
File > New Project > Other
WTP is installed if project categories like EJB, Web, ... show up.
HTH
Michael
Re: How to verify that WebTools Platform is successfully installed? [message #212541 is a reply to message #212311] |
Fri, 18 April 2008 16:22 |
You should see manifestations of WTP in the Preferences dialog. For
example, "Server" and "Web and XML" top-level categories.
You can also open Help > About Eclipse > Plugin Details... and look for
plugins that begin with org.eclipse.wst.*(specifically,
org.eclipse.wst.webtools.doc.user)
Also, in the Run dialog you should see a category named "Run on Server"
Hope this helps,
Eric
FUDForum. Page generated in 0.02784 seconds
